Grand PooBaa Member
Shock Relocation
Im sure a few of you have done this with a kit. My question, how did you get the old mounts off without taking the bed off? Used my 4.5 inch grinder and lowered my exhaust and I have one side off, but now how do I get the old rivets out?
Re: Shock Relocation
Grind them flush & drive them out w/a air chisel (easy way
Grand PooBaa Member
Junior Member
I used a center punch to ding the rivit head in the center, then a 3/8 drill bit to drill through the head. Then punch the rivit out with a punch and bfh
_______________________________________ 62 SWB BBW (under construction) 86 Vette Convertible |
Grand PooBaa Member
67-72 Addict!
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
Watch out for your cornhole !
![]() Join Date: Jun 2003
Get a flap wheel for your grinder at Home Depot and you'll be able to grind those flush in about 30 seconds each. Then, like mentioned, they will punch right out.
Also, fit a block of wood between the flange of that crossmember and the bottom of the bed, right next to the rivet while hitting the rivet. The crossmember is flimsy enough that it springs a bit when struck with the hammer and than takes away from the effectiveness of your force.
I'm on the Instagram- @Gearhead_Kevin Last edited by Tx Firefighter; 04-19-2007 at 01:23 PM. |
#8 | |
#9 | |
Grand PooBaa Member
That was the first thing I tried, my air hammer did not make a dent. So I used the grinder. Just have to get back under it, and finish the job. |
Grand PooBaa Member
Got the old shock mounts and installed the new ones. Unless I did something wrong, the new shock relocator parts are not as great as I thought. I'll post the pictures within the hour.
Grand PooBaa Member
Are the shocks bushings supposed to be slanted at the bottom?
Also the kit has a mounting bolt that hits the shock as you can see in the picture. You have to install the upper screw with the nut half way then install the shock then tighten the screw the rest of the way. PIA!! |
Wow! That bottom shock does look waaaaaay out of align.....
#13 |
Flip that upper bolt over to where the head is on bottom and the nut is above the crossmember. That will fix that problem at least.
#14 |
![]() Join Date: Apr 2005
Do you have an adjustable panhard bar? Looks like your rearend is misaligned.
R
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
#15 | |
Weekend Warrior
Yeh what he said ![]()
-'07 GMC Sierra K2500HD -'66 C10 Suburban -'68/'71 K20 Service Bed Project -'69 Chevy C30 Mason Dump -'33Ford P/U 396ChevyPowered ![]() ![]() ![]() |
#16 |
![]() Join Date: May 2005
My lower shock mount kit from ECE has a spacer between the shock and the mount. Don't know if that would solve the mis-alignment problem though. I'll take a pic tonight when I get home and post it for you.
Pete |
#17 |
Next project: 1970 K10
What does the other side look like? Can you post pics of the opposite side? If we could see how that shock sits on the mounting stud, that would tell us alot.....
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
#18 |
Here are some pics of mine. I hope they help. They are the best pics I could get with the truck still on the ground. Not easy for a guy my size getting under a lowered truck
1969 Chevrolet C-10 SWB |
#19 |
Grand PooBaa Member
Looking at PunkRocks pictures, I think my shock mounts were made wrong. His mounting bolt is nowhere near the shock where as mine hits the top of the shock.
#20 |
There are definately some difference here, but nothing is jumping out at me right now except for the rear end not being centeres. VDOG, some pics of the left side would tell us a bunch.
Also VDOG, who made your kit? And how much is your truck lowered in the rear?
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE Last edited by glock35ipsc; 04-25-2007 at 01:21 PM. |
#21 |
FYI...I got mine from Early Classic Enterprises
#22 |
Grand PooBaa Member
I will get you a picture of the passenger side in a few minutes. I got mine from Classic Performance Parts or CPP.
Look at the screw that in the old shock mount hole. Do you see it next to the shock? Its pressing against the shock. |
#23 |
67-72 Addict!
vdog- the part that your bottom mount attaches to looks bent to the left. Look at the angle compared to punkrocks!.
#24 |
Grand PooBaa Member
The truck has a 3" drop in fron and a 4" in the rear.
Maybe I should install the panhard bar, maybe that will align the shocks. So where do I mount the adjustable part of the panhard bar? On the axle or on the driverside mount? Pictures are the driverside of the truck as requsted. |
#25 |
Commander Taco Bello
i'm not sure why your having the issues you are, but i would definitely run a panhard bar. at least the factory one, if not an adjustable one.
all of the adjustable panhard bar setups i've seen has the adjuster on the D side mount. |
