Old 11-10-2007, 10:33 PM   #51
tubbed 68
Re: post 1/4 mile times
the sportsman tires arent in the best shape there not the sportsman pros just the sportsmans. Track was unprepped at little local track on a thursday night. i will be getting ethier some et streets or the et street radial but cant decide yet. Both should have good traction but ive hered mixed reactions.I know the truck has a lot left in it but the 60' and it being just a quick mild tune really killed the time. Were getting it dialed in and then when we go back we will mess with the jets.
tubbed 68 is offline   Reply With Quote
Old 11-11-2007, 06:13 AM   #52
chevy72blu
chevy72blu's Avatar
RicksRat, I appreciate the response. I actually am not to concerned with what it runs on motor alone, as long as its <13.99 so I can run in pro class this year and preen my skills a little. This will be my first time playing with N2o
It has an Eagle steel 4.25" crank in it, bored .040. I actually did the bore and line hone on it myself (with the help of a few skilled machinists... of course) while I was working at an engine shop my senior year of high school. I should be somewhere around 500 cubes. It IS the first motor I've ever built on my own from a bare block... so im a little nervous to spray the funny gas into her. But, I promised myself I wont ever go past 150 hp, and that is on 100 octane with adjusted timing and plugs - soley for the purpose of carrying the time slip around in my glove box. Hell Ill trailer the thing to CA if I need to for an 11 second slip.
Im suprised to hear such a jump in times from the bottle - most people I have heard from running in the 11-13 second range talk about a .5-.7 second improvement with a similar amount of spray.
djracer - Trailing arms? Hahaha.... I would love to have ever once had them on my truck - but im a 3/4 ton LWB to 1/2 ton SWB convert, my friend. Still has the stock half ton leafs in the back of the 76 I took the whole rear out of (basically got my 12 bolt for free). Not to mention a pair of broke-all-to-hell shocks. A friend of mine has built 2 4-links in some pretty nasty off-roaders, and if they can stand up to Nevada desert, I should be alright. Im looking forward to the tuneability of the 4 link setup.
RIP EastSideLowLife
'72 C20 SWB convert. 5 lug, LS1/4l60e
chevy72blu is offline   Reply With Quote
Old 11-11-2007, 08:03 AM   #53
djracer
djracer's Avatar
how about some pics of these trucks?
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 11-11-2007, 10:08 AM   #54
Myself
I love to see big block trucks running scary fast. But, I'd like to know what some 350 trucks are running too. I don't mean stroked or power adders either. I mean 3.48 stroke 350 naturally aspirated, balls out. Anybody have some numbers? I'm thinking my wife's truck is capable of low 14's at around 98 mph.
Myself is offline   Reply With Quote
Old 11-11-2007, 01:01 PM   #55
chevy72blu
chevy72blu's Avatar
SBC launch from about 2 years ago
RIP EastSideLowLife
Old 11-11-2007, 03:00 PM   #56
Jim_PA
What are the specs? I'll have some numbers on mine next Friday, weather permitting
Jim_PA is offline   Reply With Quote
Old 11-11-2007, 03:11 PM   #57
RICKSRAT
RICKSRAT's Avatar
Picture of a little grudge match a few years back. The '65 didn't showup however.
'72 SWB 3,600# Indigo Blue , Sunset Racing Pump Gas 582" 1,002hp / 833tq ,Transking 400 W/ Transbrake, Moser Dana 60 w/4.30
Old Motor: 60'. 1.43
1/8 6.58@104.64
1/4. 10.42@127.10
Nitrous: 60'. 1.28
1/8. 6.15@ 112.02
1/4. 9.75@ 136.32
RICKSRAT is offline   Reply With Quote
Old 11-11-2007, 05:04 PM   #58
tubbed 68
these are my truck pictures 355 rhs alum. heads comp roller full msd igniton 10.3:1 shorty headers 6 inch rods forged pistons ,now has proform holley 750 soon to have mickey thompson drag radials.Name:  100_0587.jpg
Old 11-13-2007, 09:26 AM   #59
Myself
.040 over 4 bolt 350 with polished factory nodular crank. Re-sized factory rods, weight matched. 9.5:1 Speed-Pro flat tops. Crane Powermax 278/284 dual pattern cam. 305 HO heads with reshaped combustion chambers and enlarged runners (about 20 hours a piece by me). Wyseco needle fulcrum roller rockers. Performer RPM intake. Pro Comp HEI distributer. Holley 600 carb. 1/58 long tube headers and Dual exhaust with chambered mufflers. Th350 trans with a full B&M overhaul and 2000-2200 converter. And 3:73 rear end.
Old 11-13-2007, 10:28 AM   #60
djracer
djracer's Avatar
I had a 71 Swb street strip truck. It had a 350 with vortec heads zz4 cam and flat tops with 1.6 roller rockers turbo 350 with a small stall 3.73 gears a posi and coilover rear shocks 12.5 inch wide M/T Sportman pro's It went 8.56 @ 80 mph eigth mile and 13.55 @ 97 mph in the quarter here's a link to it on dragtruk http://www.dragtruk.com/ENTRIES/U1G6UF5XJGYS.html
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 11-14-2007, 10:35 PM   #61
69trk
69trk's Avatar
just bought fiberglass cowl hood for my truck. Just need to get it painted to match. should save a few pounds. also found sombody that can put a chrome moly cage in it for me also, just need to call him. He done a great job on my budy's ferd.
69trk is offline   Reply With Quote
Old 11-18-2007, 11:23 PM   #62
Jim_PA
Oddly enough, my first run was my best. 14.4 @ 97.86. Best 60' was a 2.5 Did 2 runs on 295/50/15 radials, and 2 on 285/70/15 radials. I thought the 285's would help me with the traction problem, but they actually felt worse.
I had a pair of slicks at my disposal, but we already had a broken Cobra Torino on the trailer. I got a little worried about bolting on the 28.5" slicks and breaking mine.
If I had more practice getting off the line with the 4-speed, I think I could break into the 13's.
P.S. -- Met up with franks72 there, he was putting out some good numbers, The time he beat me, he layed down a 13.8 @ 98.03. But he had drag radials, so I'll use that excuse
Old 11-18-2007, 11:45 PM   #63
franks72
Junior Member
franks72's Avatar
Hey Jim ,after talking to you I got back in line to make another pass and watched another car mess up the track ,I got out of line and loaded up.I made 7 runs with a best ET of 13.76 mph97.98 60ft 1.945
72 cheyenne super BB402 TH400 Air Tack Tilt Posi P/S P/B AM/FM 12.96 @ 101.82 mph 60ft 1.82
12.39 @111.33 With a 180 shot nos
69 Camaro RS http://s94.photobucket.com/albums/l117/fdelcoglin/
email fdelcoglin@hotmail.com
franks72 is offline   Reply With Quote
Old 11-18-2007, 11:53 PM   #64
Jim_PA
Yeah, I noticed as we were packing up nobody was running --
Old 11-19-2007, 12:11 AM   #65
franks72
Junior Member
franks72's Avatar
Jim , I got a pic of you and your buddy, kinda dark.
Old 11-20-2007, 09:47 PM   #66
Super73
Super73's Avatar
New guy here.. Thought Id start off by posting some links to some things regarding my truck.
Here are pics of the build process to its current life giving fairly accurate info on the set up. I need to update this some time: http://ls1tech.com/forums/showthread.php?t=644566
Here is a dyno graph overlay between the first heads cam package and the one that is in it now: http://73-ls1.com/63truck/new_vs_old.JPG
Here is a dyno overlay locked converter vs unlocked which is how it runs down the track: http://73-ls1.com/63truck/locked_vs_unlocked.JPG
Here is a quick video of it’s first test and tune track day. These runs are all motor right now: http://73-ls1.com/63truck/sac_10_27_07_low_res.wmv
As you can tell I am in to performance At some point I will start going through the truck making it look like something, but for now the goal is 11.9x on the motor and 10.9x on the bottle. I had 4 of these trucks at once so I kept the best of the best parts and the worst of the worst. What you see is the worst.
I hope you enjoy and if you have questions about the LS1/4L80E swap, I’d be more than happy to answer them. Now it’s time to look around some more and start asking questions in areas I need help
Shaun
Super73 is offline   Reply With Quote
Old 11-20-2007, 10:01 PM   #67
djracer
djracer's Avatar
pretty sweet welcome to the board from Alabama!
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 11-20-2007, 10:06 PM   #68
Jim_PA
Hey -- thanks! still cool I'm already planning my approach for next spring. Some sort of slicks, either drag radials or full slicks are the only way I'm going next time. I don't think I can improve much on a street tire.
Old 11-20-2007, 10:48 PM   #69
djracer
djracer's Avatar
Sticky tires help a bunch!
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 11-20-2007, 10:56 PM   #70
bigjimzlll
bigjimzlll's Avatar
What track is that? and welcome from Northern CA
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 11-21-2007, 12:30 AM   #71
Super73
Super73's Avatar
Sacratomato.. Sat there was no one there. 10 people making passes. It was awesome.
Old 11-21-2007, 02:24 AM   #72
Super73
Super73's Avatar
What are you guys doing for front springs? I pulled some 17.5" springs from a late 80's 6 cyl cherokee today. They are just a little too light as it goes to the bumps. However, with what seems like 150-200lbs of force lifting on the fenders, I can lift it 6.5" with the shock set to 80/20. I'm searching for a set of V8 Grand Cherokee springs right now. From what I'm told on the 4x4 forums they have a little more spring rate to them.
I have a hard time with weight x-fer with the 1" lowering spring in it. I slapped some S10 springs in it today (650lb 14") and it's a touch higher than I want with a little more stored energy than the 1" lowering springs but nothing like the Cherokee springs.
I'm tempted to put weight jacks in with the 6cyl cherokee springs but I'm not sure how safe that would be for street driving ect..
Old 11-21-2007, 10:06 AM   #73
djracer
djracer's Avatar
I have mustang II stuff on the front of my truck but I tried some moroso trick springs from a camaro on my old 71 street truck. They definitely help with the weight transfer but the didn't fit well in the pocket with the aftermarket lower control arms I had!
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 11-21-2007, 11:32 AM   #74
Super73
Super73's Avatar
I'm assuming you don't have them anymore laying around in the garage do you?
Old 11-21-2007, 06:13 PM   #75
djracer
djracer's Avatar
I sold them I think? they are pretty cheap at summit and jegs
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
