11-25-2009, 05:32 PM | #51 |
6>8 Plugless........
Re: '72 Cheyenne Project - Kansas City
Very nice! Keep up the good work, don't give up on it.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
12-01-2009, 02:28 AM | #52 |
Thanks, I need all the encouragement I can get. I can see the light at the end of the tunnel.. at least for getting the top end bolted back together and running.
1972 Long Bed Cheyenne Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=285282 Waste my bandwidth and listen to some great tunes >> http://www.radioxenu.com (Live Shows with yours truly every Friday) |
12-04-2009, 03:06 AM | #53 |
Here's the new intake all clearcoated with some Eastwood Diamond Satin Clear. I love that stuff for bare metal. I topped it off with some ARP carb studs and a 1" spacer.
Info on the EPS intake.. Dual-plane Edelbrock Performer EPS intake manifolds deliver dyno-proven horsepower gains from idle to 5,500 rpm, when used with Edelbrock's Performer series square-bore or Thunder series AVS carburetors. Dyno tests showed an extra 5 HP and 9 ft.-lbs. over their own Performer manifold. The secret's in the all-new runner design, which is tuned to produce substantial torque increases in the 3,000-4,500 rpm range--with peak torque at 3,500 rpm. That's power where you need it the most!
1972 Long Bed Cheyenne Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=285282 Waste my bandwidth and listen to some great tunes >> http://www.radioxenu.com (Live Shows with yours truly every Friday) Last edited by 420am; 12-04-2009 at 03:08 AM. |
12-04-2009, 06:40 AM | #54 |
I've been wanting to do the same thing to my intake, have you done this before on engine parts? Does the Eastwood clear hold up to the heat?
Keith SOLD - 1963 C10 Short Fleet 350/700R4 4/6 drop 1967 GMC Super Custom - Short Fleet COPO concept w/427 BBC T-400 w/Doug Nash overdrive 4/6 Drop, Buddy Buckets, etc... Frame Off (In Progress) I call it "Vulgar Display of Power" 1980 Silverado Original paint 49k Original miles 4/6 drop Check out my build thread here: http://67-72chevytrucks.com/vboard/s...=1#post6209941 |
12-04-2009, 10:54 AM | #55 | |
I coated my old polished intake with it before I sold it and I coated my valve covers with the high gloss version. I like the way everything has turned out. It's nice to not leave fingerprints on my polished aluminum valve covers.
12-04-2009, 10:57 AM | #56 |
oh.. and just a note.. the hood in that pic is scrap. Just so the rust on it doesn't confuse people. I'll likely end up using it for patch panels.. right now it's serving as a workbench.
12-07-2009, 09:50 AM | #57 |
Just got some stuff removed and painted.
12-07-2009, 09:55 AM | #58 |
Tot Roddin'
Lookin' good, nice progress!
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
12-20-2009, 02:17 AM | #59 |
Gasket on and Copper Sealed.. about to make the mistake of bolting the heads on before we checked for TDC. haha. While I'm tightening down some of the head bolts Brian notices something peculiar about the cam we pulled out. Which reminds me that one of the pushrods was a little worse for wear. I thought maybe I'd roughed it up taking it out.. I sometimes employ Gorilla strength and it's well within the realm of possibility that I could have bent it.. that lobe tells otherwise though. Ahhhh.. heads are on. Time for some pizza! Decided to set most everything on the motor before we called it a day to see how it'll all look. I dig it, even though the timing gear is on backwards. Thanks for the help B!
1972 Long Bed Cheyenne Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=285282 Waste my bandwidth and listen to some great tunes >> http://www.radioxenu.com (Live Shows with yours truly every Friday) Last edited by 420am; 12-20-2009 at 09:42 PM. |
12-26-2009, 01:44 PM | #60 |
Engine looks great, what brand are those valve covers? I think im gonna have to get me a pair.
12-26-2009, 02:11 PM | #61 |
I bought them off of ebay. Those are the tall ones. Here's a link to the valve cover section of the seller's store that I bought them from:
http://stores.ebay.com/abad71camaro_...34Q2ec0Q2em322 In case that link doesn't work here's the link to the store, seller's handle is abad71camaro : http://stores.ebay.com/abad71camaro He had a lot of cool valve covers.. it was hard to choose between these and the ball milled ones.
1972 Long Bed Cheyenne Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=285282 Waste my bandwidth and listen to some great tunes >> http://www.radioxenu.com (Live Shows with yours truly every Friday) Last edited by 420am; 12-26-2009 at 02:11 PM. |
12-26-2009, 05:27 PM | #62 |
Between Trucks...
Build's looking good. I just got some valve covers from that guy on E-bay. He has some nice stuff.
Beat it to fit, Paint it to match... |
04-25-2010, 02:36 AM | #63 |
12-10-2013, 09:14 PM | #64 |
Sold.
12-10-2013, 10:39 PM | #65 |
Tot Roddin'
Bummer. I had thought about you a week or two back.
