#51 |
Re: Barn find resurrection
#52 |
Still chipping away. I would like it on the road by the end of July.I'm still painting piece by piece and installing it. I got most of the front clip on and saw that me and Bud Wiser got the strip on the cowl to big. I'll have to re do it. I found out the hard way new bolt clips on the inner fenders are the only way to go. Installed new black carpet and painted a tilt wheel silver. I installed a red dash pad but dont know if I like it. might go back to black. Installed Red and black hounds tooth bench seat. Seams to sit to high so I,m going to lower the rails.
#53 |
more pictures. Can't decide if i'm going to paint the grill or leave it stock.
#54 |
Are you really going to sell that truck? I think your crazy!
"TURNIN WRENCHES FOR FREEDOM" SSGT USAF 72 GMC Short Bed EFI Vortec 383 Stroker |
#55 |
Started on the bed. Went from a complete bed to small chunks in a hurry. Loaded it up and will haul it to the sand blaster tomorrow.
#56 |
#57 |
They get none from me...that casting is very prone to cracking. Now the block...that's a good one...hang on to it!
Kelly '05 GMC Sierra SLE Z71 Bone stock except for new bed rail caps. |
#58 |
I would hang onto the block if I could. It was what I had at the time and this project needed it. Who ever ends up with this pickup will have a good 4 bolt block that they can install better heads if they want.
#59 |
![]() Join Date: Apr 2005
Great progress in such a short time!! I wish I worked at that rate,
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
#60 |
Very cool build. I don't normally like stripes like that, but those look really nice. Just be careful of Bud Wiser, he's not your friend when it comes to painting!
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD ![]() Click here to support the board Philippians 4: 6-7 |
#61 |
I have a bad habit of trying to make things to perfect. So I never get things done. I thought Bud Wiser would help things move along. It did help things move along. Now I need to repaint the cowl. As for useing strips, I hope I didn't screw up by making them to wide. ==Do you think I should run the stripe into the grill and paint it silver? How about Red? How about Black?? Or Origional?
#62 |
Today I sent the bed parts off to be sandblasted. Tonight after work I straightened the grill. This has been very time consuming. So instead of polishing it out I decided to paint it black like the lower half of the pickup. I took the seat out and the tracks off so I can cut and lower them this week.
This I don't get--When I went to install the driveline, it was to long. Same one that came off. Would lowering it 3 inches cause this?? Last edited by Ilike 72"s; 07-17-2008 at 12:30 AM. |
#63 |
Still chipping away.Finished rough install of the front clip. I still need to adjust the gaps.
Straightened the grill. Taking to long to polish, so I painted it black with the insert painted silver. Installed the grill. Installed the tilt and tranny linkage. Hooked up some wires, added fluids and fired it up. Go@#^#n tranny cooler line wasn't tight at the radiator and sprayed oil all over. Cleaned up and tried again. Turned onto the street and had all the lug nuts fell off the front wheel. I don't know why it stayed on. I used the wrong nuts for that mag wheel. Found a pin hole in the radiator spraying water on me while I put the jack under it. Real nice day. Took the radiator out and called it a day!! |
#64 |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Damn thats a quick build... Looks pretty sweet...
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
#65 |
I know you had some hesitations about painting the grill, I think it looks pretty damn good!
#66 |
After I pounded out the crushed area on the drivers side--filed==sanded- filed--etc. It became clear to me it was getting painted. I lucked out that the hood stripe falls right into the grill insert corner. So I painted it silver to continue the silver flow of the hood stripe. Thanke for the compliment..
#67 |
Just can't quit. Aligned the front clip gaps and installed the front bumper. I'm just winging it as I go. What do ya think so far.
#68 |
THE VILLIAGE IDIOT
looks great.. nice paint job.....
honestly honey,,i have no idea how that truck got here. ![]() |
#69 |
So, you rebuilt that whole truck in like a week? I guess that's normal for you huh? I've been on my son's truck now for three months and it is still a pile of parts in the garage floor. I feel mentally retarded now. Thanks
#70 |
It's for sure been longer than a couple weeks, and no it's not normal for me. I don't know why but the timing was good and things seemed to fall in place. You can't be retarded if you like these trucks. The body style is great and their easy to work on. Dennis
#71 |
Houston---we have a problem!! This will be a setback. Red oil on the floor. Damaged front seal in the trany.
#72 |
![]() Join Date: Aug 2004
That will keep you busy for a little while.
Awesome progress.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
#73 |
truck is looking good, keep the progress going & pictures coming, you're almost there, again looking good
#74 |
I put on a set of 18 inch wheels after work. Ordered my trany parts today. Took the cowl off and am fixing the stripes as we speak. I'm waiting between clear coats. It's getting dark in my (paint booth) gravel driveway.
#75 |
Fixed the cowl stripe to line up with the door and hood
Didn't like my new 18 inchwheels with 50 series tires, so I took them back and ask them to put 60 series on. They were real nice about it.TALLER SIDEWALLS. They had to order them. Got my radiator back and installed it tonight. Put the pickup up on the hoist so I can remove the tranny to replace the pump seals. |
