12-16-2008, 08:24 PM | #51 |
#16876
Re: What are you using to heat your garage?
My two Kerosene heaters. Had them on today. They kept it about 55 degrees. I think thats pretty respectable considering it's been in the 20's just on the other side of them garage doors.
Posted via Stationary Device '71 Custom Deluxe C-20 402. '67 Buick Special 455. '49 Plymouth Special Deluxe. "I love that old car smell" Some people are like Slinkies... not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs. |
12-16-2008, 08:31 PM | #52 |
I have a 24X24 two stall garage & have two 220v electric heaters AND a 60,000 BTU propane heater keeping me pretty warm. The propane heater is set at 65 degrees & runs about half the time now that we are having north pole temps. I think you might need a little bit more...
12-16-2008, 08:38 PM | #53 | ||
PITbut
12-16-2008, 08:43 PM | #54 | |
Trueman |
12-16-2008, 08:51 PM | #55 |
for the shop two 220vac 4800 kw construction heaters will do the trick. 4800kw = apx 16000 btu each. in my 26'x26' 10'wall (walls r20 attic r 40 ) shop i have 3 of these. 2 work and the third is a extra for the faster warm ups at -30 and colder. with the electric heat the chance of a explosion (gas fumes) is all but eliminated. i am getting to old for close calls.
Trueman Last edited by 463; 12-16-2008 at 08:53 PM. |
12-16-2008, 09:14 PM | #56 |
#16876
The propane heater you have, do you have to open the doors when you are in the middle of using it so you dont die from the fumes???[/QUOTE]
I think that any fuel type heater should be used with some caution. Maybe crack a window to draw in some fresh air. Carbon monoxide poisoning is hardly detectable w/o a monitor.
12-16-2008, 09:27 PM | #57 |
That's what I'm using ,as well
'58 SWB Fleetside...Front & Rear Porterbuilt Dropmember, 6.0 LS /4L60E. Accuair E-level, 20 Billet Specialties (Vintecs) '63 Buick Riviera ... AccuAir E-level, 20" Billet Specialties (Vintecs) http://67-72chevytrucks.com/vboard/s...=528853&page=5 Last edited by Painter D; 12-16-2008 at 09:27 PM. |
12-16-2008, 09:42 PM | #58 |
Windy Corner of a Dirty Street
Yeah, I vented it. I didn't feel like waking up dead.
Current vehicle collection: 1978 Chevrolet K10, 8.1L, NV4500, NP205 1989 Chevrolet Suburban, 8.1L, NV4500, NP241 1993 Chevrolet C1500 Sportside, TBI 7.4L, 4L60E 2001 Chevrolet K2500HD, Ext Cab, SWB, 8.1L, ZF 6 speed 2014 Chevrolet Impala LTZ 3.6L Vortec 8.1L because life is too short to tolerate underpowered vehicles
12-17-2008, 12:11 AM | #59 |
No dain brammage so far.
Ive done it this way for @ 10 years now with no problem, but my garage is less than air tight. |
12-17-2008, 12:28 AM | #60 |
12-17-2008, 03:32 AM | #61 |
The sun. It's free and you can count on it everyday.
12-17-2008, 12:29 PM | #62 |
It's a catastrophic success.
If I had a small area and nat or LP Id use an Infrared, they are ventless and put out around 30,000 btu depending on the number of grates.
I use this 165 btu because its cheaper to run and have 2160 sqft to heat. Reddy Heater R165DT Heats up to 3,900 sq. ft. 165,000 Btu/Hr. 13.5-Gallon Tank Runs Approximately 11 Hours Per Tank Patented HSI Technology Fuel Gauge Built-in Thermostat Lighted Power Switch 10" Rugged Pneumatic Tires One-Year Warranty For Large Construction, Commercial and Industrial Last edited by sneakysnake; 12-17-2008 at 12:31 PM. |
12-17-2008, 01:18 PM | #63 |
Corn: mty or full no difference.
Trueman |
