#51 |
Re: i need help
the engine serial number on chevy engines is on the (i believe) passenger side of the engine directly in front of the head...there should be a portion of the block not covered by the head that will have a number stamped on it..there is also the block casting number on the drivers side rear on the bell housing flange and it will be raised not stamped like the serial number. I wouldn't worry about the oilcooler in the radiator. I once had a suburban with a towing package that came with the same thing.
#52 |
Re: i need help
i'll try to find it.
i did some work on it today. it fired few times but only with help of start spray, i think i conected something wrong. i belive that when i identify engine i'll find some good diagram....
Go tell that long tongue liar Go and tell that midnight rider Tell the rambler, The gambler, The back biter Tell 'em that God's gonna cut 'em down You can run on for a long time Sooner or later God'll cut you down |
#53 |
Re: i need help
you should be able to start her with all the vaccuum lines plugged. don't forget the tried and true "fuel, air, Spark" if you've got all three at the right time she'll fire up
#54 |
Re: i need help
problem is that i didn't plugged all lines. there is still line from egr, and from pcv i showed in pics, and that two lines also from pic...maybe i did all wrong. when i see it i only plug fuel right. and fuel is ok.....but else....i'll take pic of that later and post it...
#55 |
Re: i need help
i think you mis understood me....all the lines don't have to always be connected for the vehicle to run. just make sure the ones that aren't are capped off so there is no loss of vaccuum or pressure. the vaccuum loss can keep the engine from starting even if all the lines are connected properly
#56 |
Re: i need help
yes you are right.i miss understood you.
only one that i'm sure is conected proppely (at least i hope so) is one from distributor. but you gave me a good hint her. i'll try it today
#57 |
Re: i need help
yaaaaahooooooooooooooooooooooooooooooooooooooooooooooooooo
I FIRED HIM UP ![]() ![]() ![]() JAMES GAVE SOME GOOD HINTS AND I DID IT O YEAAAAAAAH LOL now just some few adjustments and then on the road
