Old 01-26-2010, 11:49 AM   #51
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
Re: Another LSx/4L60e Swap
No issues really, something in my head just wanted to use the sending unit that was correct for the truck, so I drilled and tapped the bypass and put it there. The factory wire was just long enough to reach down there.
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 01-26-2010, 12:03 PM   #52
Jonboy
Slots go on anything!
Originally Posted by joe231 View Post
I believe that is a 90-91 cluster.
I have a 1989 sub that i'm parting and it has a speedo cable with an optical sensor for the computer.....I will look and see what the exact date is on the sub, maybe it was a mid year change?
The optical sensor should be the same one they used for years. It reads the pulses and buffers the signal for the VSS. There are two black marks on the back of the speedometer head, and that breaks the light reflection and counts as a pulse. IIRC, it is 1000 revoultions per mile x 2 pulses per revoultion = 2000PPM. The 90-91 electronic cluseters function with 4000 PPM.
1974 Jimmy- 5.3/4L80e/NP241
Old 01-26-2010, 12:06 PM   #53
joe231
joe231's Avatar
so is it basically for the cruise to function? or does the computer use it for the engine controls also?
CHEVY ONLY
Old 01-26-2010, 12:12 PM   #54
soule64
soule64's Avatar
Originally Posted by glock35ipsc View Post
soule64 - Is that a tach in the bottom left hole in your cluster? If so, what kind is it? Things are looking good!
Yup, it's 2-1/8" that I found at (ok, I'm ashamed...) Harbor Frieght for $20. I wasnt going to put one in, but my son talked me into it. Works just fine though...
soule64 is offline   Reply With Quote
Old 01-26-2010, 12:18 PM   #55
glock35ipsc
Nice! Nothing to be ashamed of, I need to get down there and get me a new floor jack real soon!
Bob
Old 01-26-2010, 12:28 PM   #56
Chevyman350
Originally Posted by Chevyman350
I just though I would post an FYI that the "electronic" speedos actually still need a cable drive from the transmission and the speedo it self has a signal generator for the computer (engine only during these years).
I hope that this saves you some time.
Ummm sorry, but you are wrong.
The electric speedo we use for these swaps come from a 90-91 Blazer, Suburban or dually. They are true electric speedometers, and only require the one signal output from the PCM ran to the cluster. You must re-pin the cluster connector, but there is NO speedo cable.
Just look at the back of the speedo yand you will see the cable fitting.
Look at the back of my cluster and you will see no cable fitting
Edit - Corrected the date.
Well you learn something new every day!
Chevyman350 is offline   Reply With Quote
Old 01-26-2010, 12:34 PM   #57
glock35ipsc
Around here, that is a guarantee!! Looked like a came off a little harsh there at the beginning of my post, sorry 'bout that! Wasn't intended that way.
Bob
Old 01-26-2010, 02:29 PM   #58
joe231
joe231's Avatar
Mom (AKA: Liz),
Bob is being mean to us!
CHEVY ONLY
Old 01-27-2010, 11:12 PM   #59
BGRAFX
Nice Build!
BGRAFX is offline   Reply With Quote
Old 01-31-2010, 06:46 PM   #60
soule64
soule64's Avatar
As promised - a few pics with the Dallas Cowboy edition power doors. Also some new Goodmark inner/outer fenders.
Old 01-31-2010, 06:48 PM   #61
soule64
soule64's Avatar
Also added a Vintage Air kit.
Old 01-31-2010, 06:50 PM   #62
soule64
soule64's Avatar
Last one
Old 01-31-2010, 07:12 PM   #63
joe231
joe231's Avatar
This thing is coming together nicely!!!
How do those fenders compare to the OEM stuff?
CHEVY ONLY
Old 01-31-2010, 09:40 PM   #64
Jonboy
It also controls TCC and charcoal canister purge valve, and probably a few other things I can't remember off hand.
The goodmark fenders fit as well as their hoods. I used them on my '73, and they worked great.
Old 01-31-2010, 11:03 PM   #65
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Absolutely beautiful job with the LS swap. Looks factory.
--Josh
Old 02-01-2010, 09:51 AM   #66
soule64
soule64's Avatar
The d/s dropped right in but the p/s was a real bear to get lined up. Both are much thinner than original, though. There was just too much rust in my originals to warrant saving them.
Old 02-01-2010, 07:40 PM   #67
79gmc5.3
6.0L power.........
79gmc5.3's Avatar
Originally Posted by soule64 View Post
Last one
I really like the way you have the factory air cleaner installed!!! Is it mounted to the battery box? Does it line up with cut-outs in the fender? And you just used a D/S Battery box?
What ever the mind of man can conceive......... he can achieve!
My built thread http://67-72chevytrucks.com/vboard/s...d.php?t=375914
1979 GMC Sierra 6.0 L 4L60E
1995 Mustang GT 347
79gmc5.3 is offline   Reply With Quote
Old 02-01-2010, 08:40 PM   #68
Str8Ugly
can you do a parts list of what all is needed to complete this swap?
Str8Ugly is offline   Reply With Quote
Old 02-02-2010, 01:36 PM   #69
soule64
soule64's Avatar
Yup, mounts flat on the battery tray. I had to trim the vertical piece of the tray, then lined it up with the p/s fender and drilled three holes - two for the mounting 'feet' and one fairly large hole for the drain. Even used the factory plastic push-pins to mount it. You do have to stretch the inlet hose a little, but it works. I have not cut the inner fender for the inlet yet. The fender still has to come off for paint and I'll do it then. I ordered an auxilary battery mount/tray from LMC to mount the battery on the d/s. It works out perfect for the wire harness since the battery cables are designed for that side of the truck, anyway.
I'll see what I can do about a parts list, but it's pretty much a rip-off of project "Fred", just at a much slower pace.
Old 02-02-2010, 10:23 PM   #70
79gmc5.3
6.0L power.........
79gmc5.3's Avatar
This is what I want my engine bay to look like! From the outside looks like a normal 1979 Sierra.......... Lift the hood and looks like a 2003 Sierra........ Looks Great! If you have any pics of the air cleaner install I would love to see them........ Thanks
1995 Mustang GT 347
Old 02-05-2010, 12:04 AM   #71
STOCKISH
STOCKISH's Avatar
x2 on the air cleaner install pics please.
--Josh
Old 03-03-2010, 02:10 PM   #72
soule64
soule64's Avatar
Whoa! Bumped back to page three already! I have not spent too much attention on the truck due to work and school lately. Also is not much fun in the garage when it's flippin' 20 degrees. Regardless, I managed to get the Vintage Air kit finished and the power doors wired up and tested.
Here is the interior AC unit:
Old 03-03-2010, 02:21 PM   #73
soule64
soule64's Avatar
I found the crossover harness at a pick-and-pull in Tucson a while back and used a schematic to strip out the un-needed wires (2nd pic). Still amazes me that I can use a 1990 harness and 1985 doors on a 1976 truck. Thanks GM! The power windows worked great right off the bat, but the locks were a different story. I troubleshot for a few hours and became frustrated and quit to break out the laptop. Found a post where it was mentioned that the relay has to be grounded. Doh! Grounded it and it worked fine!
Old 03-07-2010, 09:15 PM   #74
fpjr0
fpjr0's Avatar
that vintage air look good in there
ONCE YOU GO LS, YOU NEVER WANT LESS!!
fpjr0 is offline   Reply With Quote
Old 03-08-2010, 03:18 PM   #75
soule64
soule64's Avatar
Thanks - it was pretty easy to install, but a little pricey... The original unit was toast... We'll see if it works...
