Closed Thread
Old 06-14-2012, 06:15 PM   #51
raic65
raic65's Avatar
Re: cpp modular 2" drop spindles
Originally Posted by chevy_mike View Post
So, wanted to keep out of the drama side of this, I will share info I have about these spindles. I am going to try to get some actual measurements of these and the stock '65 drums I pulled off.
A happy side note for those wanting to run 15x8" rally or stock style wheels and typically have clearance issues with the lower A arm lip, around the lower ball joint, these give you enough clearance to not rub or require you to trim the A arm (which I don't like). Here is a pic to show the clearance and I did cycle the steering from lock to lock and no issues anywhere.
Chevy_Mike,
You may want to check the clearance with weight on the suspension. A the suspension goes into bump, that clearance will decrease. I had a similiar situation when I installed the CPP spindles on my truck only to find out after putting the truck down, my lower control arms would contact the wheel before full lock.
raic65 is offline
Closed Thread
