Old 08-17-2010, 11:09 AM   #51
bigsnookmaster
bigsnookmaster's Avatar
Re: Who's running power windows?
Originally Posted by 68 TT View Post
Anybody tried making their own using some square body power window regulators?
I have a spare set of beat up power window doors for a square body and was thinking it might be pretty straight forward to take the parts needed from the donor doors and merge them with some 67-72 regulators.
I am going to try it but need to pick up a spare 67-72 door to work on as I don't want to ruin the ones on my 67 if it doesn't work out for some reason.
Might try to install the power locks too.
I did this about 20 years or so ago. I think I used the regulators out of about an 82 Impala. From what I can remember the regs look similar. I cut the arms off the truck reg and welded them to the car reg and not sure if I had to re-dril mounting holes. It worked out real well though.
bigsnookmaster is offline   Reply With Quote
Old 08-18-2010, 11:18 AM   #52
68 TT
Still plays with trucks
68 TT's Avatar
That is good to hear. My fear was that the door shell was set up in a way that there was no clearance for the power window motor on the stock regulator.
Once I find a decent driver side door to work on I will do a write up on the process and post up some pics.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 09-27-2013, 05:18 AM   #53
stringpickin
stringpickin's Avatar
Location: Northern Ca. at the base of the valley just entering the sierra foothills
Hello and good day.. You had said: [/QUOTE]I have a custom interior so I went with a double switch mounted in the console and used a set of stainless "hot-rod" style wire looms to run the wires out the front of the door into the cab which turned out quite well.[/QUOTE]
Question. How did you decide where to run the wires through the door and the post. Did you drill the hole for the loom in the door and the post with the door closed from the inside of the door?
I remember years ago when I ran the speaker cables through the side panel. What a pain.. It appears to me that the loom has to be able to remain completely through the side panel when the door is closed and open.. so that is feeds in and out without hitting the inside of the door panel wall if it was too short?
Sure would appreciate a picture if possible, if not I am sure I can visualise what you did if you explain it to me..
It is the one thing that has been stopping me from putting the conversion in for so long.. Can't remember the brand off hand, but 6 years ago it was considered the best on the market, with true delco motors and oem duplicate factory switches.. I have the doors part way apart getting ready to put regulators in and I am thinking, hmmmm,, I have the conversion kit.. should I put it in? I thought it might even be necessary to remove the doors to drill the holes in the post, and possible even the door..
appreciate your time and input.. thank you..
1970 Chevy 4x4 pickup w/72 running gear. 2 1/2" custom spring lift. Brand New 383 stroker-360hp. by Smeding. Edelbrock EFI Fuel Injection. Rostra Cruise Control, 700r4 conversion. ARB Locker/373.
Disciple of our Father YHVH and the Lord Jesus Christ.
stringpickin is offline   Reply With Quote
Old 09-27-2013, 06:39 AM   #54
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
Would love to send pics, but I am in Afghanistan for a few more months. The previous owner drilled holes in down in that area. I would put in power windows every chance I get. I love the mod.
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
71 C20 Longhorn/Ole Yellor
69 C30 Former Motor Home, Flat Bed time
71meangreenc10 is offline   Reply With Quote
Old 12-08-2015, 02:13 PM   #55
elf w/capital T
I'm stoked. Thanks everyone!
elf w/capital T is offline   Reply With Quote
Old 02-26-2016, 05:02 PM   #56
71meangreenc10
Get Some!!!
Smitty
71 C30 Wrecker
Old 02-26-2016, 05:13 PM   #57
kehstr
kehstr's Avatar
subscribed
kehstr is offline   Reply With Quote
