Old 01-25-2011, 03:39 PM   #51
jmedero
jmedero's Avatar
Re: Drop member V3- Scotts bolt in front-
I know. 0 to 60 in 8 blocks flat!!
68 BB burb build thread Scott's super slam front/rear
http://67-72chevytrucks.com/vboard/s...d.php?t=378084
jmedero is offline   Reply With Quote
Old 01-25-2011, 04:32 PM   #52
JNJchev77
Registered Cruiser
JNJchev77's Avatar
Now that's fast!!
77' Chevy SB
Dropmembered Front and Rear
5.3/4l60e combo
JNJchev77 is offline   Reply With Quote
Old 01-25-2011, 07:06 PM   #53
edflores
Originally Posted by robnolimit View Post
NEWS FLASH
Although I wasn't planning on letting this out until next month when the invites go out, You guys get the info first. Early this summer, in june, we will be co-hosting the first ever C-10 Suspension Drive-off. This will be an "invite only" event designed to showcase the different suspensions and upgrade kits avaible for these trucks. As both Porterbuilt and Scott's are on the invite list, and we want both to be there, this seems like a great place to let the word out. Entrants must bring a 67-72 short bed, with their suspension parts installed. Any motor/trans combo, wheel/tire, and brake kit are allowed. All entrants MUST provide a COMPLETE parts list of ALL chassis, suspension, brake, and drive line component. Including part #, origen, and list price. Any "custom" or "one-off" items or mods must also be listed. The event will take place in Riverside, Ca. and will feature several magazine editors, two professional drivers (well known), and a know TV personality, as test drivers. The trucks will be driven by all drivers on a 12 mile "street drive" loop, and on a Time Attack road coarse by no less than two editors two pro drivers, and the truck owner. All of the results will be published including build stats, street drive comments, and track times. Our goal is not to try and show who's is best, but to show the strengths of each product, so that the enthusiests can get the results they're after. Other invites will go to Hotchkis, ECE, Jim Meyer, Marquez Design, CPP, KP pomponents, Ride Tech and others. If you don't see your name, and you want your company invited, pm me.
Are spectators welcome?
edflores is offline   Reply With Quote
Old 01-26-2011, 01:55 PM   #54
Tony@AirRideTech
Junior Member
no... but Tony and a 12pack of cold beer is....
Tony@AirRideTech is offline   Reply With Quote
Old 01-26-2011, 01:55 PM   #55
65Gregg
65Gregg's Avatar
Smile Re: Drop member V3- Scotts bolt in front-
Can I have the beer/pizza concession rights?
65Gregg
Blue long bed
White TBSS
61 Impala
“The two most important days in your life are the day you are born and the day you find out why.” Mark Twain
65Gregg is offline   Reply With Quote
Old 01-26-2011, 04:59 PM   #56
robnolimit
robnolimit's Avatar
OK guys, my bad. No spectators due to insurance. I'll start a thread as info is avail. I don't want to "thread jack" from Porterbuilt and/or Scotts. I'll stay out of this one.
GoodGuys 2012 Pro-Truck Champion
2012 Truckin' Throwdown Champion
GoodGuys 2011 National Champion
2011 Truckin' Throwdown Champion
GoodGuys 2010 National Champion
Proud to put our products up against all others!
robnolimit is offline   Reply With Quote
Old 01-26-2011, 06:55 PM   #57
PBFAB.COM
PBFAB.COM's Avatar
No worries Rob!
I figured I would go ahead and include some more technical information in regards to the suspension/steering geometry of the Porterbuilt Dropmember and some background as to "why".
When I first designed the Dropmember back in 2004-2005 I spent a lot of time tweaking the geometry in order to make it accomplish exactly what I wanted. This system was never designed to be an "ultimate performance" suspension system... but I wanted to develop a system that was an improvement from the factory design, could be driven at an extremely low height, and plant the rails on the ground with a big wheel... without the need to "Z" the frame.
First on the list was the necessary ground clearance. The Dropmember moves the suspension up in the chassis so that the lowest part of the front suspension is actually 1.25" off the ground when the frame is resting flat (the lowest point is the lower control arm outer bushing sleeve). This allows the truck to be driven extremely low without hangin up on all the imperfections on the road.
Second was to narrow up the trac-width. The Dropmember narrows the track width right at 1.5" per side (from stock) allowing more tire clearance while riding and turning when extremely low.
Third, we wanted to move the wheel center-line forward to center the wheels in the wheel wells... mission accomplished. You can run a 22" wheel and not even worry about cutting into the firewall for tire clearance.
And while striving to accomplish these key points we also wanted to make some "improvements" to the C10 geometry.... as in it's factory design there is a lot to be desired. As many have been learning, thanks to Rob from No Limit and his "make it handle" thread, one of the key points to making these trucks handle better is to add caster. The Dropmember has 6.97 degrees of caster in its design.
Another key point we implememted was to design the camber curve to where it didn't gain a lot of camber through compression. We didn't want the truck to have extreme camber when aired out and have that "broken" look. Some might argue that camber gain is essential to a performance suspension... and it is... but that was not the overall goal of the Dropmember. The Dropmember only gains 1 degree of negative camber through 6 inches of compression. Doesn't make it stick in the corners like a porsche, but looks good at the show.
We also wanted to adapt a rack and pinion steering gear to the design, not just because we had to in order to get the trac-width narrowed, but it also decreased the sprung weight considerably. We mounted the rack high on the crossmember in order to accomplish all we wanted (with it being a factory replacement rack we didn't have the liberty to put it anywhere else). The downfall to this was the necessity to notch the frame for the rack's tie-rod clearance. Not too big of a deal for most guys looking for this type of product, as they would expect a little cutting and welding. The big upside is the angle for the steering linkage. On most motors and header combos its a straight shot. It was important to keep the bumpsteer in check as well, and we were able to hold to the standard of .1 degree of bumpsteer per inch of wheel travel.
If anybody has any more technical questions they can feel free to ask, as I will be more than happy to answer any questions.
On a side note... keep your eyes peeled for our performance version of the Dropmember as it is just around the corner.
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 01-26-2011, 07:22 PM   #58
jimmydean
jimmydean's Avatar
Nate, post a picture of the prototype you had buried in the corner compared to the V3. Or just have Dino post up his fleet. He has one of each version by now, right?
<edit> Rob, as long as you get enough video of the event and make it available, that would be awesome.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 01-26-2011, 07:24 PM   #59
SCOTI
SCOTI's Avatar
You're not fooling anyone here..... If you didn't have that cold 12pk, you wouldn't be invited either .
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now   Reply With Quote
Old 01-26-2011, 08:29 PM   #60
edflores
Darnn.. can I "volunteer" that day? lol
I passed by your shop today, dropping of parts to your nieghbor.. I never realized you were so close. If you ever need a tow, let me know. We are off arrowhead and central.
Back to the topic, I vote porterbuilt, mainly because off the fact that you can reuse stock arms, and upgrade as you go. Both are quality pieces with great reputations. Realisticly, they are both at a good price for what you get.
Old 01-26-2011, 09:37 PM   #61
gringoloco
A guy with a truck
gringoloco's Avatar
Way to sneak that one in Any hints? Stock arms? Coil over? Anything to correct that camber issue?
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 01-26-2011, 10:21 PM   #62
PBFAB.COM
PBFAB.COM's Avatar
Don't know if I would refer to it as an "issue" as I designed it that way for a reason.
However, the "DM Touring" is a different animal... I can actually call it a "performance suspension". 6" ride height with a 2" spindle and 28" tall tire (measured from flat section of frame-rail under cab to ground) Wider trac-width, coil-over... tube arms. That's all I will say for now...
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 01-26-2011, 10:49 PM   #63
65Gregg
65Gregg's Avatar
This thread is really getting good...
65Gregg
Blue long bed
White TBSS
61 Impala
Old 01-27-2011, 12:09 AM   #64
gringoloco
A guy with a truck
gringoloco's Avatar
Crap! My original draft of that post had quotations around "issue", though I think I originally was calling it a "problem". Oops...
Hmmm... 2" drop spindle. Does anyone make a C10 spindle in a 2" drop? Tuned-in. This could be cool
-Chris
Old 01-27-2011, 12:10 AM   #65
SCOTI
SCOTI's Avatar
I know of one . . ....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-27-2011, 12:42 AM   #66
54Caddy
GM Addicted
54Caddy's Avatar
dang hats off to porterbuilt and scotts hot rods for laying out all the differences of eachothers kits with explanations with why chose the products they have for there kits. Soon i hope ill be able to order one of them when my wallet will allow. Nate the dm touring kit sounds very interesting will stayed tune for that for my 68 and still awaiting more info on the rear trailing arm kit for the 79. Keep this thread up can get very interesting with more developments from each company.
..Mac’s Garage..
73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd
My 73 GMC Truck Build Pic
2010 Silverado 4/6 on 24s
IG:MacsGarage
54Caddy is offline   Reply With Quote
Old 01-27-2011, 01:18 AM   #67
PBFAB.COM
PBFAB.COM's Avatar
No worries Gringo... I know what you meant.
CPP's modular spindle is a 2" drop... it's the spindle that comes with all the large diameter Wilwood kits.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 01-27-2011, 11:50 AM   #68
SCOTTMO
powdercoater
Nathan,
you are always up to something...
SCOTT
SCOTTMO is offline   Reply With Quote
Old 01-27-2011, 06:14 PM   #69
gringoloco
A guy with a truck
gringoloco's Avatar
Hmmm... Now I'm contemplating the "wider track-width" comment. A standard DM narrows it by 2" and the CPP spindles another 1.5". Longer arms? Wider mounting points? Different R&P?
-Chris
Old 01-27-2011, 06:59 PM   #70
PBFAB.COM
PBFAB.COM's Avatar
Well... keep in mind the previous posts stated regarding what narrowing the trac-width did to the placement of the rack and pinion on the regular Dropmember. We had to mount it high to get the steering geometry where we needed it. This moves the motor up slightly, and necessitates notching the frame rails for clearance... big bonus was the steering linkage angles.
This new version I am discussing, has a wider trac-width built in. This allows us to mount the rack a bit lower than the original Dropmember (almost 3 inches") and will also mount the tie-rod ends on the bottom of the steering arms. The ground clearances of the Dropmember V3.2 and the new "Dropmember Touring" are both the same, as we needed to design the "Dropmember Touring" to be as high in the chassis as possible, to achieve the combination of a low ride height an an acceptable Roll Center (this is more of a challenge than one would think). We are also able to keep the motor from being moved upward (this keeps the center of gravity and roll center closer together).
Longer arms will also be an option to widen the trac-width even more. I will eventually open up a new thread to discuss this new product as it has still not yet been officially released. Until then, if there are any questions feel free to contact me via e-mail: nathan@porterbuiltstreetrods.com
Don't want to let the entire cat out of the bag... yet!
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 01-27-2011, 07:42 PM   #71
jimmydean
jimmydean's Avatar
Not to go too far off topic, but besides the use of Corvette arms/spindles, what are the differences in the C4 vs. the V3 dropmember in terms of steering, stance, and perfomance?
I guess I always thought of the C4 DM as the touring model.
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
Old 01-27-2011, 08:30 PM   #72
SCOTI
SCOTI's Avatar
DM-C4 = Touring Lite .
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-27-2011, 08:38 PM   #73
gringoloco
A guy with a truck
gringoloco's Avatar
Coolness Thanks for the info you have provided thus far. Sounds like a good addition to the lineup, with the possibility of not welding in frame notches. I like the possibilities here and look forward to more updates.
-Chris
Old 01-28-2011, 01:01 PM   #74
jimmydean
jimmydean's Avatar
Nathan, any plans for a C50 DM for Dino's latest acquisition?
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
Old 04-03-2012, 08:51 AM   #75
gostranger
65 suburban vortec 5.3 bagged
gostranger's Avatar
No worries Rob!
????????????i didnt notice 1.5" narrower tracking on mine
gostranger is offline   Reply With Quote
