Old 11-05-2014, 01:14 AM   #51
Andy4639
Old member
Andy4639's Avatar
Talking Re: What type of oil do you use?
Well I just did the LS install back this past January and have been running O-Riellys synthetic 10w-30 the whole time. For the price of name brands it's, it's not worth it if you change your oil regularly like everyone says they do! Your wasting $10.00 everytime you buy brand name oil. $10.00 cheaper which is the same price as regular name brands oil. So I figured it's a good deal! I run AC filters.
$26.99:
$39.99
$37.99
$37.99
$26.99
$26.99
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 11-05-2014, 02:32 AM   #52
leddzepp
Moderator
leddzepp's Avatar
Autozone has a special now and again on a Mobil 1 synthetic jug, and matching oil filter for $32.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 11-22-2015, 04:24 PM   #53
70cst
70cst's Avatar
Just some good reading on engine oils.
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 11-22-2015, 06:55 PM   #54
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Durablend and Zddp oil additive. Preferably 10/40 in the cold, 20/50 in the heat.
I've only used 10/40 the last few years. The engine is quite fond of the 20/50, but I can't justify two oil changes a year when I only average 500-600 miles during that time span.
Usually take whatever filter is available. AC/Delco preferable.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C.
I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 11-22-2015, 06:59 PM   #55
71CHEVYSHORTBED402
Thinking about switching to full synthetic. The parts stores no longer carry Durablend, so order only and no deals. Any considerations using full synthetic in one of these "old" motors?
Tony
Old 11-22-2015, 11:14 PM   #56
Steeveedee
Who Changed This?
Steeveedee's Avatar
$26.99:
$39.99
$37.99
$37.99
$26.99
$26.99
I've seen people get into flame wars over which brand of filter to use. Some guys think Fram is the worst ever, but I've been using them for decades without an oil related failure. I change my oil according to the best information, so I suspect that which brand of filter is probably pretty low in terms of worry.
Then again, back in the early '70s, I knew this hippie guy who had an old '61 Pontiac that all he did was add oil when it was low. Never learned what happened to it, as I wasn't at that job all that long. He'd had it for years and had never changed the oil. Some machinery is pretty much bullet proof.
~Steven
Simi Valley, CA
Steeveedee is offline   Reply With Quote
Old 11-22-2015, 11:37 PM   #57
BossHogg69
motor exploder
BossHogg69's Avatar
https://540ratblog.wordpress.com/201...-test-ranking/
That link will give you some good reading and help you decide. With that being said, I've used Mobil 1 oil & Mobil 1 filters for the past 15 years in everything I've had -
92 C1500 (flat tappet cam) 350 that had 263,000 miles on it when I sold it and still ran great and never had one engine issue - 5w-30
05 GMC Sierra - 5.3, currently has 148,000 miles on it and it runs like new, I pulled the valve covers at 116k to do a cam swap and the inside was like new, 5w-30.
'69 C10 - 454, has about 600 miles on fresh rebuild, used Valvoline VR1 conventional to break it in, and Mobil 0w-40 at the first oil change and will from now on.
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 11-23-2015, 12:34 AM   #58
Alex V.
Alex V.'s Avatar
Stock, carb'd flat-tappet 350: Valvoline Max-Life 10-30 or 10-40 w/ZDDPlus.
Stock, carb'd flat-tappet 454: Schaeffer's 10-30 syn. blend, switched from their 15-40 on the last change and see no undesirable affects so far. Zinc additive every few changes.
Turbo 1.4L in my Cruze: Valvoline full syn. until 52,000 then switched to Schaeffer's full syn for better peace of mind in extending my OCI to 7,500 mi.
Wix, Napa, or Delco filters on everything. I've seen two 350's (one flat-tappet Q-jet, one roller Vortec) pass the 350,000 mark with a healthy, tight bottom end and little or no oil consumption on Valvoline products, so I'm pretty confident in them.
Alex V.
1967 C10 Suburban, 350/NP435, Green/Green, PS, PB, HD cooling, charging, shocks, and springs.
1985 GMC C3500 SRW, Sierra Classic, 454/TH400, white/blue.
Alex V. is offline   Reply With Quote
Old 11-23-2015, 02:24 AM   #59
toolboxchev
Valvoline VR-1 50K on complete top end re-build. No issues! Now if the local auto parts stores would just stock the 10-40.
toolboxchev is offline   Reply With Quote
Old 11-23-2015, 08:23 AM   #60
hamjet
hamjet's Avatar
To the original poster, Red68, are you confused yet?? NEVER debate politics, religon, or best oil...
Thanks, Joe..
1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB.
hamjet is offline   Reply With Quote
Old 11-23-2015, 12:29 PM   #61
Econman
Econman's Avatar
I opted for Lucas' 10w-30 Hot Rod Oil in my son's 350 crate motor. It's done fine so far.
With Purolator PureOne filter.
Econman is offline   Reply With Quote
Old 11-23-2015, 12:39 PM   #62
71CHEVYSHORTBED402
WOW......... I've only added Zinc one time (currently, "board advise") and the message in this weblink is DON'T USE. I'm changing the oil today. A few things I got out of this:
1. CONCLUSION: No matter what anyone else tells you, the “Ideal Lubrication Setup” for most traditional engines, is a high volume/high pressure oil pump with a thinner multi-viscosity motor oil such as 5W30.
2. If not high mileage, you don't use an additive and aren't racing, then for wear protection, 5W30 Mobil 1, API SN synthetic is a good way to go. I'm sold.
Thanks for the info.
Tony
Old 11-23-2015, 12:54 PM   #63
mmiddle
mmiddle's Avatar
Royal Purple with A/C filters or Wix or Baldwin or sometimes Fram. I change the filter according to the DIC readout % of oil life remaining and run the grape juice two to three filter changes. Other gas engines that don't like RP I run Valvoline All Climate. I do use Rotella T in my Duramax.
Asking gear heads about oil brands usually starts a big fist fight.
Mark
Jesus is the Way!
2003 2500HD CCLB Duramax/Ali (Clifford)
2014 2SS/RS black on black Camaro (Betty)
2006 Pontiac SOLSTICE silver/black (Lula-Bell)
1970 C/10 Short Wide (Peggy)
1964 C/10 Short Step (Hambone)
RIP Jimmy Hamilton Thank you for the trucks
mmiddle is offline   Reply With Quote
Old 11-23-2015, 01:15 PM   #64
71CHEVYSHORTBED402
Anyone else remember when oil was $1 a bottle? So was a gallon of gas, a pack of cigarettes, etc. etc.
Tony
Old 11-23-2015, 01:28 PM   #65
leftybass209
leftybass209's Avatar
Beautiful reading. I love unbiased testing. 5w30 Mobil 1 proved it's worth in testing, so I can't discredit the info in any way shape or form. However, thousands of other oil and filter combinations used throughout the course of the gasoline engines' history have proved; the best can be best, but the line is finer than the thinnest human hair that separates at least a dozen motor oils.
That being said, I feel a 1/4 turn +- on valve lash over the course of a Gen I II SBC BBC engine's life has more of an impact on the wear of valvetrain components, than that of 90% of the motor oils tested.
leftybass209 is offline   Reply With Quote
Old 11-23-2015, 05:34 PM   #66
71CHEVYSHORTBED402
Just replaced with 5/30 Mobile 1 and a Bosch filter and she purrs like a kitten. After 20 plus years, Durablend and I are officially divorced. And sure as heck no *%*&%*% Zinc additive. Glad I only used that BS once, maybe 150 miles.
Tony
Old 11-23-2015, 08:44 PM   #67
RickDeVon
RickDeVon's Avatar
I run 15/40 Rotella oil in my 139000 mile I250...It has zinc in it...
71 C10 I6 250 TH350 power steering and power breaks...
RickDeVon is offline   Reply With Quote
Old 06-13-2016, 08:19 AM   #68
RestoreAmerica
Too much info to read at one time from the engineer.
Bottom line don't use additives.
Thinner oil is better.
IMO Ultimate Durability Quaker State 0w-20 or 5W-30 seems to be the best.
Just went to 3 stores and could not find any.
I guess I will use Mobil 1 since you can acquire it just about anywhere.
RestoreAmerica is offline   Reply With Quote
Old 10-31-2016, 10:30 AM   #69
70cst
70cst's Avatar
Very informative thread ...
Old 10-31-2016, 10:41 AM   #70
OregonNed
OregonNed's Avatar
Been using the Royal Purple 10W-30 with some Lucas oil additive
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline   Reply With Quote
Old 10-31-2016, 01:35 PM   #71
toolboxchev
Valvoline VR1, nuff said.
Old 10-31-2016, 02:18 PM   #72
leddzepp
Moderator
leddzepp's Avatar
Five years later, still using the same oil. Still no engine failures. Parts is parts
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 10-31-2016, 10:06 PM   #73
Craftsmen
Valveoline VR1 racing oil 5w30. K&n filter. This oil has the high zinc content for my 350 crate motor flat tappets.
1970 C10 SWB
Craftsmen is offline   Reply With Quote
Old 11-24-2016, 02:38 PM   #74
70cst
70cst's Avatar
Just ordered a case ... LUBRIPLATE Super GPO 15W-40
Old 11-24-2016, 02:59 PM   #75
projectking
projectking's Avatar
I use valvoline diesel oil 10/30 or Rotella T 10/30
68 GMC C3500 Longhorn DRW
67 Chevy C10 LWB
90 Mustang Gt
90 Mustang Notchback
projectking is offline   Reply With Quote
