05-01-2011, 01:47 PM | #1 |
What type of oil do you use?
I am coming up on 500 miles on my rebuilt engine. I used an engine breakin additive and was trying to decide what brand/weight/synthetic or non-synthetic oil to use.
Any advise???? Thanks
1968 C10 LWB 327 bored 40 over, RHS heads, KB pistons, Eagle rods, Edlebrock carb & intake 1968 C10 flatbed 307 w/ 4 spd manual (dads old ride) 1936 1/2 tn pickup, 400sb 350 turbo (partially restored) 1949 1/2 tn, needs complete restore (future project) 1969 Chevy impala 4 dr no post (wifes future car) 2010 GMC Serria 4x4 crew, leveling kit |
05-01-2011, 01:48 PM | #2 |
~Rest In Peace~
Re: What type of oil do you use?
royal purple and wix filter
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex |
05-01-2011, 02:06 PM | #3 |
Brad Penn 10W30
Build Threads: "JED" 66 GMC C1000 http://inliners.org/ubbthreads/ubbth...1857#Post61857 "Cropwell" 66 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=587639 |
05-01-2011, 02:21 PM | #4 |
my current fill in the '67 is NAPA 10-30 conventional ( made by Valvoline ) with 1/2 pint of GM EOS and a WIX filter.
05-01-2011, 02:43 PM | #5 |
Thanks guys, I also searched the engine forum and found a few other options.
I appriciate the input.
05-01-2011, 03:07 PM | #6 |
PROJECT 7DEUCE
Valvoline
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
05-01-2011, 03:09 PM | #7 |
20' Daredevil (Ret)
I used Chevron 10W-30 for years (on sale and with a rebate, it was dirt cheap) but it's probably gonna be NAPA 10W-30 (by Valvoline, like lilred67 said) from now on. With a NAPA Gold (Wix) filter.
05-01-2011, 04:00 PM | #8 |
Chemist under the hood...
Valvoline 10W-30, Napa Gold Oil Filter. Just changed the oil yesterday.
Current fleet: 2013 GMC Sierra, 5.3L, 4x4 1988 GMC Sierra, 305, Auto 1984 Jeep Grand Wagoneer, 360 V8 1997 VW Cabrio, 2.0L 2017 Toyota Rav4, 2.5L Stuff I wish I still had: 2013 Toyota Matrix [RIP] 1967 GMC 910 Fleetside, 283 V8 [1st Love-SOLD] 1987 Jeep Cherokee Laredo 4X4, 4.0 I-6 [SOLD} 1994 Chevrolet Caprice Classic, 5.7LV8 [SOLD] 1995 Chevrolet Astro AWD, 4.3L V6 (RIP) 1998 Chevrolet Suburban 4x4, 5.7L V8 [SOLD] |
05-01-2011, 04:36 PM | #9 |
lubriplate super gpo 15w-40
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
05-01-2011, 04:44 PM | #10 |
Valvoline and red line additive. Newer oil does not have the zinc in it that the older engines need.
05-01-2011, 04:47 PM | #11 |
Moderator
mobil 1 synthetic with a k and n oil filter
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
05-01-2011, 04:56 PM | #12 |
lucas and a k & n oil filter
my build thread -- (http://67-72chevytrucks.com/vboard/s...d.php?t=438604) |
05-01-2011, 05:23 PM | #13 | |
Description: LUBRIPLATE SUPER GPO OILS are formulated with ZDDP (Zinc and Phosphorus) for maximum anti-wear protection. Recommended for heavy-duty applications, high-performance and classic car engines. They help protect flat tappet lifters, camshafts and other components from premature wear. Turbo and diesel approved.
05-01-2011, 05:33 PM | #14 |
Valvoline vv855 and a k&n filter
Fuzzy |
05-01-2011, 05:34 PM | #15 |
my truck has over 358,000 miles on it,i started using the recycled oil as i call it from advance [you know the cheap oil]. started using hastings oil filters then changed to wix but can't get them from advance so i use fram.but at 250,000 i started using a quart of lucas with every oil change. my combo is 1qt lucas to 4qts 20w50. been good for me keeps me at 50lbs of oil pressure when driving down the road. idles at 35lbs pressure.
05-01-2011, 06:34 PM | #16 |
The Niner
Kendall 10W-30 and AC Delco filter.
"A good racer is one whose head is in communication with his balls." - Richie Evans 1970 C/20 - 402/TH400/3.54s - 74K miles 2003 GMC Sierra 2500 - Wheatland Yellow Niner Progression Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=697183 Classic Trucks article: https://www.motortrend.com/features/...et-c20-driven/ |
05-01-2011, 06:43 PM | #17 |
DON'T TREAD ON ME
Don't know if you saw this thread or not but I've been digesting it for the last 24 hrs. http://67-72chevytrucks.com/vboard/s...d.php?t=381780
Assuming you still have a flat tappet cam the biggest issue is with the amount of ZDDP being decreased from the modern oil formulations at the request of the car companies in order to cover the federally mandated catalytic converter warranty. The decrease in ZDDP isn't as big an issue for stock cams and spring loads. High lift cams with heavier springs can run into trouble without enough ZDDP. The modern formulations without enough ZDDP are designated API SM whereas the older formulations with enough ZDDP are designated SL or SJ. I just put Mobile 1 synthetic in Old Yeller right before finding out it doesn't have enough ZDDP so I'm going to add a bottle of ZDDP Plus and at the next oil change switch to Royal Purple. PS: It's nice to see a fellow formite over in the next county.
Old Yeller |
05-01-2011, 07:07 PM | #18 | |
05-01-2011, 07:40 PM | #19 |
Castrol 10-40 with comp cam and lucas additive for flat tappet cam.
05-01-2011, 08:01 PM | #20 | |
If you google there are distributors but the price seems to be the same. I bought a case last time. http://www.lubriplate.com/webstore/detail.aspx?ID=27
05-01-2011, 08:05 PM | #21 | |
05-01-2011, 08:09 PM | #22 |
Royal Purple oil and filter. Would run nothing else. I did run Castrol Synthetic oil for 20 years before switching.
The more I learn, the more I find out I don't know. 69 Chevy SWB w/67 front end 4 wheel discs 468 BB 700R4 Bagged Coming around slowly |
05-01-2011, 10:24 PM | #23 | |
I do have a flat tappet cam, before I read your info and the thread you referred to I bought Valvoline VR-1 which several board members said they use (at least in the engine drivetrain section). It is 20W 50, will this cause any problems with my engine? After reading more about the VR-1 it says it is for race engines or engines that are exposed to extreme heat and loads and not recommended for street applications. It seems there is so much info out there I don't know what to believe. You refer to the next county over, how far are you away from Lubbock? I just moved to this area and actually live in Wolfforth.
05-01-2011, 10:36 PM | #24 |
Grandpa in the rustmobile...
Ive been using a wix filter and valvoline 10 30 with the lucas engine oil break in additive
Is this ok? is there another additive I can use? I wish I went roller..
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
05-01-2011, 10:57 PM | #25 |
Valvoline 50 weight racing oil and purolator oil filter.
'72 Nova '71 C10 '63 VW Beetle ...............................____ .................________-|___\____ ..;.;;.:;:;.,;.|__(O)___|____/_(O)| _______________________________________ |
