Old 01-16-2012, 12:07 AM   #51
85Bowtie
85Bowtie's Avatar
Re: Bars Leak Transmission Stop Leak?
Yes you can use carb cleaner, just make sure you get everything clean. You'll probably want to scrap off any large collections of gunk first...I usually use 2 or 3 cans to get a transmission that's been leaking clean. Then dust it well with baby powder and leave it alone. You'll find any leak easy that way.
If you've taken apart your speedo housing, you will probably need to check the indexing on it when you put it back in. If you didn't do this, recheck it.
'69 Dodge Charger R/T 440, 727, 3.55 Sure Grip
'68 Plymouth Road Runner 383, 727, 3.23 Sure Grip
'89 Dodge Diplomat ex cop car 408, 727, 3.55 Sure Grip
'77 Dodge Monaco ex cop car 440, 727, 2.71
'79 Dodge 'Lil Red Express pickup 360, 727, 3.55 Sure Grip
'12 Dodge Challenger SRT8 392, M6, 3.92
'85 Chevrolet C-10 SWB 2wd 305, TH350, 2.73
85Bowtie is offline   Reply With Quote
Old 01-16-2012, 12:07 AM   #52
IOWNATRUCK
when i had a speedo cable leak, i was noticing huge spots of transmission fluid on my driveway that randomly showed up, from the pictures you posted it looked like the drips were coming from the exact place mine was when it was leaking from the housing, so id continue to check into that as well.
IOWNATRUCK is offline   Reply With Quote
Old 01-16-2012, 12:09 AM   #53
JRANGER
JRANGER's Avatar
Ok, awesome...I am def going to replace the speedo housing but i wont get to that until the weekend...I may try to start the cleaning process tomorrow after work
JRANGER is offline   Reply With Quote
Old 01-16-2012, 12:10 AM   #54
IOWNATRUCK
good luck with pinpointing everything.
Old 01-22-2012, 06:00 PM   #55
JRANGER
JRANGER's Avatar
Ok, So in trying to replace the speedo gear housing I managed to push the entire gear into the tranny....How do I get it back out? Do I need to remove the back end? I know I have to remove the 4 bolts, replace that gasket to get the back part off but that about as much as I know....UGH!!! Im such a newbie
Old 01-22-2012, 08:16 PM   #56
IOWNATRUCK
haha it shouldnt be a problem man, just either try to maneuver something in there to get the gear out or just drop the pan, your going to have to fill er back up with fluid anyway so taking the few bolts out and draining the rest of fluid wont make a difference.
Old 01-22-2012, 08:22 PM   #57
JRANGER
JRANGER's Avatar
OK OK one more ?...My gear housing looks way diff then the new one....Is there a difference or was it just changed over time???
New:
OLD:
Old 01-22-2012, 08:28 PM   #58
IOWNATRUCK
you confirmed you had a th350 correct? as long as you do and the gear fits snugly in the new housing, youl be great, good luck getting the gear out, and keep us posted on the install come back if theres any more questions!
Old 01-22-2012, 08:30 PM   #59
JRANGER
JRANGER's Avatar
yeah it was a 350 and it fits pretty well...now to find the gear...About that...To replace the gear It would just pull straight out or would the transfer case have to be removed?
Old 01-22-2012, 08:35 PM   #60
IOWNATRUCK
the plastic gear would just come out with the housing, you mustve just accidentally pushed it back in, so just get the little plastic gear out which shouldnt be a problem, pop the gear in the new housing, make sure its pushed in all the way, then screw the new housing to the end of the cable, then put it in the side of the trans, pop it in as far as it will go, it should pop a little as the o ring will hold it in, then put the retaining clip back on and fill it back up with the correct trans fluid, dexron, and you should be good.
Old 01-22-2012, 08:36 PM   #61
JRANGER
JRANGER's Avatar
dexron 3?
Old 01-22-2012, 08:38 PM   #62
IOWNATRUCK
yeah 3 is good, it says on your dipstick, as long as its dexron your good the numbers are just the newer formulas, make sure its dexron on your dipstick and good luck, once you find the gear it should go pretty quick.
Old 01-22-2012, 08:48 PM   #63
JRANGER
JRANGER's Avatar
ok thanks!
Old 07-19-2012, 01:08 AM   #64
CEE1NG_RED
Any updates??? Also, if the plastic gear is worn, how will you know what plastic gear to replace it with according to the driveshaft size????? Are the O-rings accessible to local autostores (via. Autozone, Oreilly, Pepboys, Napa)?
- 1967 Chevrolet C/10 SWB fleetside (New Project).
- 1969 Chevrolet C/10 SWB fleetside (SOLD)
- 2000 Ford Mustang 232 (DD)
- 2003 Ford SVT Cobra "Terminator" 281 (Once in a blue moon driver/weekend driver)
CEE1NG_RED is offline   Reply With Quote
Old 07-19-2012, 09:52 AM   #65
JRANGER
JRANGER's Avatar
I just bought a new Gear housing was cheap and fixed the issue...As far as the gear you can match it by color usually...but you can count how many points on it
