03-15-2012, 03:45 AM | #51 |
Re: I hate some previous owner because.....
pulled out my carpet today to find that my truck probably used to have a manual transmision,, i wish it still was. and to seal off the hole the PO just screwed some ugly looking patch sideways over it. thanks for nuthin
also left some other random hole open above the pedals... anyone know what this could've originally been for....? |
03-15-2012, 03:54 AM | #52 |
of coarse, however it helped my cause to lower the price and i replaced them for less than $100 form the junk yard. = WIN!
The price of cool aint cheap. |
03-15-2012, 08:23 AM | #53 |
One my '66....
- Replaced front lower hood panel(great), cut out all brackets for mounting turn signals and hood latch.... - Screwed in cab corners with one screw instead of cutting out old and replacing with new. - Cut the wiring for the headlights, had to rewire. - Upgraded to power brakes/5 lug(great), horrible/****ty welds in which I will be fixing soon. I'm sure I'll find more.... |
03-15-2012, 09:50 AM | #54 | |
The PO of my '64 went the fiberglass route in the kick panel/floor corner, after buffing the rust w/wire brush on a drill-the glass peeled right off like a orange peel. He also fiberglassed the bed stake holes up. Truck had a camper so there were many holes drilled around the stake holes. I welded it all up. |
03-16-2012, 03:28 AM | #55 | |
But Found Her 25yrs Later!
No, wait. maybe not. The hole above the e-cable I think is for the clutch.
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
03-16-2012, 08:12 AM | #56 |
Yes, it`s for the rod going down to th e Z-bar.
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
03-16-2012, 05:01 PM | #57 | |
Lifes journey is not to arrive at the gate well preserved, it is to slide in sideways all used up and wore out yelling.....God what'a ride! Where patience fails, force prevails Stapp's Ironical Paradox "The universal aptitude for ineptitude makes any human accomplishment an incredible miracle." |
03-17-2012, 02:23 PM | #58 |
Repaired EVERYTHING with electrical tape...including the leaking fuel line
Posted via Mobile Device |
03-17-2012, 09:55 PM | #59 |
Wiring, my PO had used 12/2 house wiring for the rear lights !@#$
03-17-2012, 11:03 PM | #60 |
hacked out dash for radio, rt motor mount gone and secured with a piece of chain,hacked out center cross member when po swapped to a v8 th350, under hood toggle switch attached to the alternator, 3 different sets of side mirror holes. and must of had at least 10 different bed caps or camper tops by the looks of all the holes in the top bed rails
Due to financial constraints, the light at the end of the tunnel will be shut off until further notice |
07-01-2012, 02:46 AM | #61 |
As most of us know; the V-8 Motor Mount Perches are a tad tall for the 60-62 'X-Frame'.
Some previous owner solved this issue with cutting the bottom of the perch off.
07-01-2012, 01:25 PM | #62 |
holes holes holes. i have 28 holes on the outside and a few more on the inside. some from the big mirrors some from the hooks on the sides of the bed and the ones the bug me most are the large ones to mount the tool box to the side rails.
Hand Made Factory reproduction A/C vents text or call 602-361-6421 Website for A/C vents https://coolc10.com/ |
08-01-2012, 10:41 PM | #63 |
It's like rivets, tin, and bondo are the next best thing to sliced bread.
Some previous owner riveted tin to the inside of the stepside fender. Then some future owner (or maybe the same person) put another layer of tin over the previous layer. There was actually three layers of riveted tin holding who knows how many years of dirt. Argh!
08-02-2012, 07:28 AM | #64 |
Mine was original red/white top, bbw,all the chrome.... Some DUMB S painted it blue inside and out, stripped the chrome... and tried his first time welding skills at filling in the holes....
High School Project I ---http://67-72chevytrucks.com/vboard/s...d.php?t=639174 High School Project II ---http://67-72chevytrucks.com/vboard/s...27#post7290427 High School Project III ---http://67-72chevytrucks.com/vboard/s...d.php?t=715832 High School Project IV (Tyler) ---http://67-72chevytrucks.com/vboard/s...d.php?t=780186 |
08-11-2012, 08:02 PM | #65 |
po used two unequal diameter exhaust pipes welded to a t under the transsmission with nothing but spatter for a bead hooked a line from the vacumn on the hei to the brake cylinder wtf but a piece of aluminum foil over the crappy gaskets on the manifolds installed the spark plugs 125643 order on the 230 zip tied the fender to the frame moved the horn to under the dash and rattle can primer over all of the chrome trim, bed wood and turn lights
08-12-2012, 02:43 PM | #66 |
P/O tried on like 3 or 4 sets of dorky Dumbo mirrors before he settled on something that looked like they came off a Peterbuilt, and left 7 million holes in the doors. Also, cut a huge gas filler hole for an auxillary fuel tank mounted in the bed.
Seems to be the common thing on this thread; HOLES. |
08-12-2012, 03:36 PM | #67 |
[QUOTE
Put lots of dents in odd places, and the rust is unbelievable! I went to Wichita to get this truck, I can't believe how much more rust a truck up there has than an Oklahoma truck![/QUOTE] I didn't think that was possible after getting my POS out of Oklahoma..... |
08-12-2012, 04:24 PM | #68 |
Hollister, CA.
.........they cut out an otherwise perfect dash for a DIN radio, as well as the doors for speakers.....
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" |
08-12-2012, 05:00 PM | #69 |
Same here John except it was for a real cheap radio...I cleaned up the radio area with a dremel, put in a cd player years back, got some old rusted out doors for my patch panels, one day I`ll get a pic of the inside of the door show you guys what one does with a torch so he can get the windows out. HE SHOULD HAVE BEEN LINED UP AND......OH sorry no violent actions here....
08-12-2012, 08:24 PM | #70 |
My truck was used to push other trucks around with no oil in the motor by a 19yr old. He was real energetic about it too. My '69 Camaro on the other hand had romex house wire under the hood which promptly melted when it touched the header. Started small fire, ruined battery, wire harness, and started a wild goose chase until I finally lost the car in a divorce.
08-12-2012, 08:49 PM | #71 | ||
Wire nuts should be illegal to use on trucks. I hate when they ran out of electrical tape and used masking tape, which is now a white powder. |
08-12-2012, 09:49 PM | #72 |
You guys with the small holes cut in your tranny tunnel have nothing to complain about, here's mine!
Here's what I cut out to repair it Here's what it looks like now, I still have holes to patch!
65 Chevy short fleet 350 5 speed, soon to be LSX powered 65 F100 short fleet 91 Heritage softail 94 Fatboy 11 Softail Deluxe [wife's bike] 13 Streetglide http://www.youtube.com/watch?v=yMFMw...eature=mh_lolz |
08-30-2012, 03:58 PM | #73 |
I love this thread! Tonight I am posting why I hate the previous owner of my truck... I have a few good ones
08-30-2012, 06:27 PM | #74 |
The wiring in my 66 is all messed up. The PO installed a cut off switch like you see on the rear of sub 9 second drag cars. See pic. Then he put in a toggle switch on the dash that turns on the ignition. See pic. So the starting procedure goes as follows- lift the hood turn the big switch, close hood get inside flip the small switch on the dash, turn key to start. Nice!
66 shorty |
08-30-2012, 07:13 PM | #75 |
^Very Nice.
Be sure to post a step by step on how one might do that same wiring tip. ;-p Posted via Mobile Device
