#51 |
Re: 67 ls-rrrr
Did the porterbuilt cross members have much of a weight difference over the stock pieces? I'm not interested in laying frame, but at the cost if they are lighter it may be worth buying versus trying to resto my stock pieces.
FUZZY1 |
#52 |
67cheby
![]() Join Date: Sep 2008
Re: 67 ls-rrrr
he can custom make them for you out of chrome moly if you are looking for weight savings ! at least he told me he could when i was ordering mine
#53 |
![]() Join Date: Apr 2011
Re: 67 ls-rrrr
I dont think there is much if any weight savings, but they sure are nice and really will stiffen the frame up, much better quality and design then the stock crossmembers. after doing my first build, I knew this was the way to go!! Much cleaner!!
Check out my other build http://67-72chevytrucks.com/vboard/s...d.php?t=457288 http://67-72chevytrucks.com/vboard/s...d.php?t=517089 |
#54 |
Re: 67 ls-rrrr
Wow! You rolled through that in a hurry! Looks great.
#55 |
Re: 67 ls-rrrr
Thanks, its amazing when how much you can get done when no one is around to interupt you all the time. Still have a little sanding and grinding to go, I thought I had the spot welds down enough, but a few are showing a little high.
#56 |
Re: 67 ls-rrrr
Heck, I spent two days fooling with mine at least... and I missed the cluth rod on mine... bummer. So you skimmed it over the welds already but still have a few high spots?
#57 |
Re: 67 ls-rrrr
Yeah, not that you can see, but I know ! Im the worst critic!!!
#58 |
Re: 67 ls-rrrr
looks great man
1969 C10 425hp Shortbed My build: http://67-72chevytrucks.com/vboard/s...=520406&page=3 |
#59 |
Re: 67 ls-rrrr
Thanks Guy's , Ran into a major road block today. My compressor motor bit the bullet this morning. So just ordered a new one, $ 700.00 later and a week with out a compressor really puts a halt on things!!!! Of course almost everthing I have requires air to run it.
#60 |
Re: 67 ls-rrrr
@ 67Cheby, thanks for the heads up about the chromoly, I will keep that in mind.
@ Timbo1, it sounds like a good move to keep the chassis solid, the prices are low and it seems like a nice upgrade.
FUZZY1 |
#61 |
Re: 67 ls-rrrr
Powder coating is back, Hard to tell in the picture but the frame is black and all the crossmembers and suspension are charcol grey. I will get some better pictures later.
#62 |
67cheby
Re: 67 ls-rrrr
looking GOOD !
#63 |
Re: 67 ls-rrrr
looks amazing! very nice work.
'72 C10 deluxe long bed, 350 auto project in the works http://67-72chevytrucks.com/vboard/s...d.php?t=513464 Now accepting donations towards the Wade needs hot rod parts fund. all applicable donators will be thanked hospitably with a 12 pack of any alcoholic beverage of their choosing ![]() |
#64 |
Re: 67 ls-rrrr
keep up the good work
#65 |
Re: 67 ls-rrrr
Thanks guys, took the weekend off to go to the lake with the family
#66 |
Re: 67 ls-rrrr
Sorry guys, no pictures tonight, a little update, back from vacation and getting things back in order @ work. Picked up a Ls2 motor. Ordered the new oil pan set up, the no limits rack n pinon came in. Will get busy on installing all suspension and steering. Called the differential shop and told them to cut the rear end down 2 inches per side. Hopefully back this week, they had to order the axles from Mosher. Still missing 1 set of air bags also. Portebuilt said I should have them soon!! Pictures soon!!!!!!
#67 |
Tasty Cakes!
Re: 67 ls-rrrr
So how did you come up w/that 2 inches per side figure?
I'm a little ![]() ![]() Ground beef: A cow with no legs. ---------------- '66 Chevy SWB "Penny" '67 Chevy Big Window SWB- aka "Pearl" '72 Burb- "Betty" "It's not a hearse dammit" '99 Chevy Ext. cab Silverado |
#68 |
Re: 67 ls-rrrr
I knew you were going to ask!!!!
Looked thru a bunch of threads and found some other builds going the same direction I'm going. Wasnt rocket science but I came up with that figure after a lot of research. Posted via Mobile Device
#69 |
Re: 67 ls-rrrr
looking fantastic! which PBF front and rear kit are you going with?
#70 |
Re: 67 ls-rrrr
Thanks it is the stage 2 kit
#71 |
Re: 67 ls-rrrr
Here are a few picture of the No Limits rack, everything is just put on loose at this time.
#72 |
Still Learning
Re: 67 ls-rrrr
Very nice suspension parts! Love R and P setup. How many turns of your steering wheel lock to lock? What kind of investment if you don't mind saying? I want to upgrade mine
Some day. Need to get it on the road first. Posted via Mobile Device |
#73 |
Re: 67 ls-rrrr
Thanks I have not checked the lock to lock yet, was getting late last night when I finally got it in. I will let you know when I get there. Also I think the rack kit was around $870.00 the only thing to finish the install you will need p.s hoses.
#74 |
Re: 67 ls-rrrr
Wow awsome stuff there man!! Great spot to work outside too, gotta love that.
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
#75 | |
Tasty Cakes!
Re: 67 ls-rrrr
