Old 05-09-2012, 03:45 PM   #51
05crewcab
05crewcab's Avatar
Re: rattle rattle thunder clatter boom boom boom...
Originally Posted by Vintage Windmills View Post
Depends on what your goals/budget/timeline are, if its just to get it driveable I would just bolt them back on and run. If I had the time and money and knew I wanted to keep the truck I'd rebuild everything.
i have time, but limited budget (<$200) and I am definitely keeping the truck. I just don't know what it would cost to have a shop inspect/clean the heads...i know for a complete rebuild i'd be looking at close to the cost of a complete crate longblock 350, so i'd go that route instead if push came to shove.
currently the truck doesn't smoke, and runs well, so i'd think internally things are in fairly good shape and i'd get away with just making sure nothing is warped and throwing gaskets at it and slapping her back together. then i could save the cash for a crate 350 or core big block to rebuild for when this motor pukes again in the future.
i guess i am asking if i am setting myself up for a short term disaster if I DON'T have the heads inspected while they are out of the truck? I'd like to get a couple years down the road before having to pull the top end again.
1971 C-20 350/350
05crewcab is offline   Reply With Quote
Old 05-09-2012, 03:59 PM   #52
webfoot
Having the heads magnafluxed (aka "magged") is not that expensive. Most of the time involved is removal of the valvetrain parts.
Running in place gets you nowhere fast.
-me
1968 GTO 4-spd covnvertible
1970 K-20 4-speed, factory AC.
webfoot is offline   Reply With Quote
Old 05-09-2012, 04:09 PM   #53
Dunenutt
Newbee
Dunenutt's Avatar
Clean the big chunks off with a razor scraper, gasket scraper, or a sharpened putty knife. Take your time, and do not remove any metal, dont gouge anything. Then clean it up with your scotchbrite. I wouldn't go crazy trying to remove a bunch of carbon from the heads. Make sure to remove all of the scrapings from the cylinders, and lifter valley before bolting it back together.
If nothing is obviously wrong, put it back together as is. The most you will lose is a few gaskets. Small blocks are pretty darn tough.
Dunenutt is offline   Reply With Quote
Old 05-09-2012, 06:01 PM   #54
yfs200p
E.H.F.D Engine #2
yfs200p's Avatar
One time on my 03 2500HD, CarQuest sold me a new starter, the part number on the box was correct, but the part number on the actual starter was wrong. It bolted up and worked fine, but when you got into it, or had a load, the flex plate was hitting the starter gear. (The gear on the wrong starter didnt retract far enough) Sounded similar to that. Whether its the starter or not, i'd definitely say you have an issue with the flex plate or something in that general vicinity
-NICK
'72 K10 SWB Fleetside. Avocado Highlander 350-4speed-NP205 Frame Off Re-Creation
'89 GMC V3500 C/C Flatbed Plow Truck 454/SM465/Np205
'15 Chevy 2500HD CCSB High Country Duramax
'22 Tahoe Premier Duramax
yfs200p is offline   Reply With Quote
Old 05-09-2012, 08:43 PM   #55
Ackattack
Ackattack's Avatar
What do I win for having the right answer? :-) glad you found the issue
Ackattack is offline   Reply With Quote
Old 05-10-2012, 10:28 AM   #56
05crewcab
05crewcab's Avatar
Thanks!
I'll fashion a trophy for you out of the old copper gaskets
I was working on cleaning up the mating surfaces last night and also noticed a very small area between #2 and #4 on the other gasket that looked suspect. that could also be the reason for the lower compression on those two cylinders. I think the mystery is all coming together.
I also ran a straight edge over all the mating surfaces and they are flat as can be, so no warpage.
now i guess it's time to get it all put back together...
1971 C-20 350/350
Old 05-10-2012, 07:04 PM   #57
yfs200p
E.H.F.D Engine #2
yfs200p's Avatar
DUH i somehow thought this post was new yesterday, and missed the part where you found the head gasket problem. Disregard my post!
-NICK
Old 05-14-2012, 11:15 PM   #58
05crewcab
05crewcab's Avatar
Well, got her all back together and she won't stay running. I think I adjusted my valves too tight, or the timing is way off... I installed a new balancer and thought I got top dead center on the intake stroke before setting the valves, but maybe not? TDC should be just after the intake valve closes right? I think i am going to use the EOIC method tomorrow and see if that helps. right now I am too dejected to try anything tonight.
Can anyone tell if the timing is off based on which valves are open/closed in the following picture? You can see the black mark on the distributor body that lines up with the rotor, and the white TDC mark on the balancer... i'm stumped.
1971 C-20 350/350
Old 05-15-2012, 01:21 AM   #59
Boog
laying low
Boog's Avatar
How long does it run when started and is it smooth or missing?
True the valves appear to be closed, the rotor is close to that mark and the harmonic balancer mark is on.
If the engine starts cold but after getting up to normal temp it shuts down it may well be tight valves.
You could loosen each one 1 turn or so then try startup again and see how it runs. If it stay running or runs longer then you are on to it.
I've always preferred the hot running adjustment method. I've always had great results with it. It is messy but it will clean up. Are you familiar with this method?
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 05-15-2012, 01:25 AM   #60
webfoot
How did you adjust the valves this time?
-me
Old 05-15-2012, 01:39 AM   #61
05crewcab
05crewcab's Avatar
[quote=Boog;5381295]How long does it run when started and is it smooth or missing?QUOTE]
It doesn't run...sounds like it is hitting on a couple cylinders if i keep my foot on the pedal but it won't idle...just dies.
I adjusted the valves according to the Haynes manual. found TDC on #1, took out the lash + 1 full turn on both, then turned the crank 90* to the next one in the firing order.
1971 C-20 350/350
Old 05-15-2012, 09:10 AM   #62
Boog
laying low
Boog's Avatar
1. Make sure you have the plug wires in the correct firing order.
2. Loosen each rocker one full turn and give it a try.
Boog
primer is finer
Old 05-15-2012, 11:28 PM   #63
05crewcab
05crewcab's Avatar
She's alive!
I re-did the rocker adjustments using the EO-IC method and she fired right up! I hear a little tiny bit of chatter in the top end, so to sleep easy i am going to adjust the valves while it's running...
Now, the timing was set dead on the nuts @ 0* so it ran like crap, and the hand me down timing light that must be 35 years old and i have never used didn't work (go figure) so I timed it by ear just to smooth it out until i can rent a good light. I think I understand the timing processes, but can you guys offer up any tips?
1971 C-20 350/350
Old 06-06-2012, 11:58 PM   #64
BD70CST
Did you ever get this running? If so, were the head gaskets the only problem? I have the same noise...going to get a compression tester tomorrow.
BD70CST is offline   Reply With Quote
Old 06-07-2012, 12:28 AM   #65
05crewcab
05crewcab's Avatar
Yep, she runs like a champ (mostly). The head gaskets were the smoking gun. Blown fully between 3 and 5 and slightly between 2 and 4. (compression test indicated both) I bought a timing light and re-timed it but now it's fairly rough at idle and the timing mark isn't crisp under the strobe so i think maybe the mechanical advance needs to be replaced. Haven't had any time to work it out, and it is driveable, so we'll see when I get to it.
Good luck with yours. I had never had an engine torn down to the block and I got her back together again in just a couple nights of wrenchin.
1971 C-20 350/350
