Old 03-31-2012, 11:42 PM   #1
05crewcab
05crewcab's Avatar
rattle rattle thunder clatter boom boom boom...
Strange thing started happening this week...
When my truck is moving and under load, (accelerating, driving up a hill, etc.) I have this rather loud clattering noise coming from someplace in or near the engine bay. It doesn't happen if I don't have my foot in it, and won't make the noise in Park.
I crawled under the truck tonight and checked everywhere for things touching the drivetrain...exhaust hangers, trans cooler lines, kickdown cable, speedo cable, PS lines, loose brackets, starter, etc. I also checked and greased my u-joints and the carrier bearing is in good shape.
Anyone have any ideas on what to check next? The motor sounds fine when revving in Park, and doesn't make this noise at idle or over 3000 RPM... I'm stumped.
1971 C-20 350/350
05crewcab is offline   Reply With Quote
Old 04-01-2012, 12:32 AM   #2
oldschool18
oldschool18's Avatar
Re: rattle rattle thunder clatter boom boom boom...
does it seem to be missing when its doing this
_________________________________
62 Impala
70 C-10 LWB
71 K-10 SWB
85 C-10 LWB==SOLD
01 2500 HD
Members Met......2003Silverado (Dave)
oldschool18 is offline   Reply With Quote
Old 04-01-2012, 12:41 AM   #3
05crewcab
05crewcab's Avatar
I don't think it is missing/stumbling, etc. the power seems normal as near as i can tell.
1971 C-20 350/350
Old 04-01-2012, 12:42 AM   #4
steves1967
steves1967's Avatar
Detonation?? What's the engine timing?
'71 Chevy 3/4 Ton Longbed
'22 Chevy Tahoe RST
'67 Firebird- 8 sec street car
'24 GMC CC 4x4 Duramax Dually
steves1967 is offline   Reply With Quote
Old 04-01-2012, 12:45 AM   #5
oldschool18
mine was doing that then it started to miss and it was a bad plug wire, and mine only did it when it was under a load....going up hill.....accelerating quick
62 Impala
70 C-10 LWB
71 K-10 SWB
85 C-10 LWB==SOLD
01 2500 HD
Old 04-01-2012, 12:46 AM   #6
05crewcab
05crewcab's Avatar
No idea what the timing is unfortunately...I haven't touched it since I bought it two years ago.
1971 C-20 350/350
Old 04-01-2012, 01:08 AM   #7
05crewcab
05crewcab's Avatar
That's intersting. I'll have to check the plug wires...I didn't think such a loud noise could be a bad wire. it literally sounds like something is banging off the fan.
1971 C-20 350/350
Old 04-01-2012, 02:47 AM   #8
hotrod100
hotrod100's Avatar
Check for a broken flex plate. I just got done replacing one in a Suburban that was doing the exact same thing. It ended up having two small cracks around the mounting bolts and wouldn't make any noise until you got on it a bit then it would start snapping and popping. We really heard it when we were towing the boat! Unfortunately you may not be able to visually find the cracks until you pull the trans. I even used my borescope and couldn't see it. On a more positive note though, the parts are fairly cheap.
My build thread.
hotrod100 is offline   Reply With Quote
Old 04-01-2012, 03:46 AM   #9
MikeyMan
Maybe a bad motor mount? Inspect the fan shroud to see if the fan has rubbed it.
MikeyMan is offline   Reply With Quote
Old 04-01-2012, 09:02 AM   #10
Nova_Cobra64
Nova_Cobra64's Avatar
I've experienced something similar in the past, turned out to be loose torque converter bolts.
2004 Silverado - Beater
1969 GMC - In progress http://67-72chevytrucks.com/vboard/s...d.php?t=441683
2011 Aveo - Work commuter
2013 Crestliner Fish Hawk 1650 - The reason no work gets done on the project truck.
Nova_Cobra64 is offline   Reply With Quote
Old 04-01-2012, 09:32 AM   #11
jocko
jocko's Avatar
is it getting louder as time goes by? (hate to suggest a rod bearing...) Hopefully not.
Old 04-01-2012, 11:19 AM   #12
Lee H
Lee H's Avatar
U Joints?
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 04-01-2012, 11:25 AM   #13
RexDodge
I think Mikey got it! I'd have to vote motor mounts too...
RexDodge is offline   Reply With Quote
Old 04-01-2012, 11:33 AM   #14
sanford66
sanford66's Avatar
X2 on this theory. When the flexplate is cracked it will make a lot of clatter and racket sometimes. Also the sounds can change with the RPM. Joseph
1970 Chevelle Nomad station wagon
1966 C-10 lwb,250-six,granny 4speed
1966 C-10 lwb,factory A/C,Custom Cab
1954 Delray 2-door sedan [rat rod project]
sanford66 is offline   Reply With Quote
Old 04-01-2012, 01:06 PM   #15
Critter
Future TOTM Winner
Critter's Avatar
I'm in the broken flex plate crowd, had them do weird things before. Also the torque converter bolts as mentioned, either way still need to look at the same area of the truck.
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces)
72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts
2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver
Check it out www.lsdyno.com
Critter is offline   Reply With Quote
Old 04-01-2012, 06:44 PM   #16
05crewcab
05crewcab's Avatar
Flexplate might make sense. I took the fan shroud out to make sure and it still does it. Here is a quick video I took this afternoon. (sorry for the poor camera skills)
http://youtu.be/n4gX-dlJxVk?t=1m
1971 C-20 350/350
Old 04-01-2012, 09:56 PM   #17
FLEET72
FLEET72's Avatar
Tried to look but all I got was:
This video is unavailable
This video is private.
Sorry about that.
Oscar
'72 Shortbed Fleetside
'95 Jimmy 4X4
'69 GMC Custom Camper
FLEET72 is offline   Reply With Quote
Old 04-01-2012, 10:18 PM   #18
05crewcab
05crewcab's Avatar
whoops... here is the correct link:
1971 C-20 350/350
Old 04-01-2012, 10:32 PM   #19
old Chevy guy
old Chevy guy's Avatar
Sounds rough,whats the oil preasure look like when it does that? Is the presure good overall? Seems like mostly under a load,is that right? Does it get worse as it gets hotter?
old Chevy guy is offline   Reply With Quote
Old 04-01-2012, 10:49 PM   #20
05crewcab
05crewcab's Avatar
Overall oil pressure seems fine, and I have only driven it far enough to get to operating temp, but i would say it does get more consistent as the truck warms.
1971 C-20 350/350
Old 04-01-2012, 11:02 PM   #21
jsbgump
Gone Fishing
jsbgump's Avatar
You have a broken flywheel or loose torque converter bolts. I have had this problem serveral times on my 68 and that was the problem. You probably can't tell the flexplate is broken until it's unbolted
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop Frame of resto has been started
2022 Hyundai Tucson Limited
2019 Chevy Traverse Redline Edition Wifes Ride
Build Thread
http://67-72chevytrucks.com/vboard/s...=1#post3483616
jsbgump is offline   Reply With Quote
Old 04-01-2012, 11:30 PM   #22
oldschool18
Thats nothing like I thought you were talking about, i would go with the above and say flywheel-flex plate..........had a 76 camaro sounded kinda like that, missing one fly wheel bolt and the other two were loose
62 Impala
70 C-10 LWB
71 K-10 SWB
85 C-10 LWB==SOLD
01 2500 HD
Old 04-01-2012, 11:55 PM   #23
FLEET72
FLEET72's Avatar
I concur, the flexplate is where I would start looking.
Oscar
'95 Jimmy 4X4
Old 04-02-2012, 12:33 AM   #24
05crewcab
05crewcab's Avatar
I got real curious tonight after hearing a couple more yeh's for flywheel so I crawled under took a look. From the surface the flywheel looks pristine, so i checked the torque converter bolts. two were really tight, and the third i could turn maybe a 1/2 turn. I'll take the truck out tomorrow and see if this was the smoking gun. If not, I guess the flywheel comes out...
1971 C-20 350/350
Old 04-02-2012, 12:52 AM   #25
shawno72
C/10 junkie
shawno72's Avatar
I got the same sound right now and I believe it to be the flex plate to.
Shawn
70 LWB C10 current driver/project
http://67-72chevytrucks.com/vboard/s...d.php?t=663051
68 SWB C10 Work in progress.....SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=559520
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
http://youtu.be/kbB0QrBIs9k
My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!"
shawno72 is offline   Reply With Quote
