09-26-2012, 12:03 PM | #51 |
Re: The Scary Truck
Chevy runs in my blood |
09-26-2012, 07:53 PM | #52 |
Re: The Scary Truck
so decide what your gonna do with your suspension yet?
75 c30 silverado drw 454/th400hd d70 soon to have d60 up front 73 c20 custom deluxe sm465 14bff parts truck |
09-26-2012, 07:58 PM | #53 |
Re: The Scary Truck
Honestly still not sure, Prolly leave it stock for now.. Considering its a 2wd I might just end up going for a lowish rider, then later on maybe get a 4x4.
09-26-2012, 10:26 PM | #54 |
Re: The Scary Truck
Will make a good project truck, I'm nearby from Yorktown..............
John Stevens, ASE master auto tech., ASE master autobody tech. I-car platinum certified '70 Chevy SWB pick up '77 Chevy SWB 4X4 PU 2 '70 Buick GS Stage-1 4-spds |
09-27-2012, 09:10 AM | #55 |
Re: The Scary Truck
So what did you use for a dash install kit for the radio in your truck? I'm assuming the 1982-2005 kit works?
Semi professional heavy equipment operator Amateur mechanic |
09-27-2012, 07:37 PM | #56 |
Re: The Scary Truck
I actually didn't even use a kit, It fits so snug in the dash it doesn't move, I did attached a bar for support in the back.
09-27-2012, 07:58 PM | #57 |
Re: The Scary Truck
I see you're good with body work! Might have to hit you up when I have some money
09-28-2012, 05:17 PM | #58 |
Re: The Scary Truck
id just level it out with spacers and throw some mud tires on it and youll be able to do much as a 4x4 i bet
09-30-2012, 01:29 AM | #59 |
Re: The Scary Truck
praise the lowered!
"As I walk through the valley of rice i fear no honda, for i have torque!" |
09-30-2012, 08:37 PM | #60 |
Re: The Scary Truck
Kind of a lazy weekend, painted my bumper and got it 1/2 way bolted on, thats just about it. Looks good, Took the head rack off tonight though. I didn't like it with the bumper, plus I don't think I'm going to use it lol. Think I made up my mind and next pay check check get some stuff to lower the truck. Also keeping an eye on craigslist for wheels, or just 4 tires for my rallies, It really bothers me that one of the rims is shallower than the others. But the matching rim has a leaking tire.
11-11-2012, 12:53 AM | #61 |
Re: The Scary Truck
11-11-2012, 10:50 AM | #62 |
Re: The Scary Truck
I love em too, my buddies always harass me about it though
11-11-2012, 10:59 AM | #63 |
Re: The Scary Truck
A little update:
Making some speaker mounts for the back corners of the cab, nothing fancy but they'll work. I'll post pics when I'm done. Also should be getting two new (used) tires for my rear. 265/??/R15. Not going to complain about sizes though, they're free. Guess it pays off to have a friend work at Goodyear Running out of things that I can do for little/no money... I'm not allowed to buy anything since Christmas is coming up soon. Any suggestions? I'll try and make a new video today.
11-16-2012, 05:36 PM | #64 |
Re: The Scary Truck
Here are some interior pics I forgot to post..
Also swung by O'rielly on my way home from school, cheaper than I though it would be, only $40 bucks I may need to get bolts though, hopefully the stock bolts come out with little to no problems More to come!
11-16-2012, 06:15 PM | #65 |
Re: The Scary Truck
praise the raised! haha! nice truck looks soildi am 14, sorta around yuor age but might be getting a blazer this weekend!
2011 Silverado ECSB LT 2000 Silverado RCSB 2WD super bad habit of not owning a vehicle for a long time |
11-17-2012, 12:22 PM | #66 |
Re: The Scary Truck
You'll like the drop shackles. I don't remember the process I went through to get them on but I put the truck on jack-stands so I could adjust the axle with the jack. I was looking at some of the pictures of your truck and I knew something looked different I just couldn't tell what. I finally realized this, you've got a 81-87 front bumper.
Also saw your post about doing a 5/5 drop. Not sure you want to do that. The back will be higher than the front. Would need to do a 5/7 for levelness. I think that might be too low for you. If you wanted you could get a lowering hangar for the rear (since you got the shackles) and that'd give you a 4ish drop in the back. Could get 3" front spindles or 2.5" spindles to get the front level. Just a thought. What are your other plans for the truck?
Michael Re-starting the neglected '77...http://67-72chevytrucks.com/vboard/s...=425464&page=9 |
11-17-2012, 07:23 PM | #67 | |
Re: The Scary Truck
11-17-2012, 10:03 PM | #68 | |
Re: The Scary Truck
11-17-2012, 11:29 PM | #69 | |
Re: The Scary Truck
11-18-2012, 06:47 PM | #70 |
Re: The Scary Truck
Hey Zirk.
I'm outta town right now but these are some of the pics that I have stored on my computer. You will probably have to notch your bed supports. Don't worry it shouldn't hurt the integrity of the bed. I was able to get around this because my truck has the HD rear suspension which comes with 56" leaf springs. You probably have the standard 52". 52" means you'll have to cut to make room. My 56" gave me enough room so I didn't have to cut anything. Here are some pics. I don't have any real good ones of the shackles but you can tell if you have the longer springs by eyeballing to see how close your spring mounts are to the bumper brackets. You can tell in the pics there isn't much room between the bumper brackets and the spring mounts on mine. Hope this helps, Michael
12-07-2012, 06:05 PM | #71 |
Re: The Scary Truck
Little side I project I've had for about 2 years, Yamaha Blaster 200 bored .80 Putting new gaskets on this weekend! This will be the second time tearing it down all the way, hopefully this time takes just a few hours and not two weeks
Hopefully I can work on lowering my truck Christmas break, might have to go to my uncles for some more room inside, we've been spending every weekend stocking up on firewood..
12-16-2012, 07:33 PM | #72 |
Re: The Scary Truck
Probably the first time doing some real work to the truck..
Sneak peak
12-22-2012, 06:03 PM | #73 |
Re: The Scary Truck
Welp ran to town today to pickup some parts that I ordered from O'rielly's, they sent them back because we didn't pick them up within a week. So we ordered them again, should be here tomorrow..
But on a positive note, I finally convinced my dad to let me try and get a 350 that has been in our barn since the mid 90's running.. Should be fun. He said when he bought it the only thing wrong was the starter bolts were stripped. Time to start saving money again I might just play around with it a little and see how it goes, probably will just stock pile some cash so I can send it to a shop.. Things are finally starting to heat up
01-14-2013, 06:56 PM | #74 |
Re: The Scary Truck
Its been a few weeks, got my drop shackles installed, notched the bed support rail in the way half way on one side so that way there would still be some support, but the shackles still hit it. So looks like we'll have to cut the whole thing. But of course the cutting torch ran out of oxygen... Might try and use a sawz-all..
Here's some pics, i measured and the truck only sits about an inch or so lower than stock on the passenger side because the shackles can't move and on the driver side sits a good 1.5 inches higher than stock.. Also installing some stuff I got for christmas That Rake!
02-02-2013, 12:40 AM | #75 |
Re: The Scary Truck
Coming along nicely on the truck Zirk! Out of curiosity what kind of shape are those stock tailight covers in? and what did you do with them? I wouldnt mind having some in nicer shape then mine and well as some trim but i don`t want to the spend the money on new ones. id rather get used ones for a decent price.
My build Lil` Red http://67-72chevytrucks.com/vboard/s...d.php?t=551373 1984 Chevy C10 short bed 2001 Chevy Impala police cruiser 2001 Chevy Silverado 1500 Z71 4wd extended cab dd |
