#51 |
Re: Lowrie's 69 Shop Truck
Nice nice work!
#52 |
Once everything was painted, I through the cab on and a fender to see where it sat with the air ride deflated.
#53 |
awesome build and great progress, if you dont mind...what is the paint code of the green?
#54 |
#55 |
A320 Pilot/USAF Retired
Great build!!
JJ My 1957 build: http://67-72chevytrucks.com/vboard/s...d.php?t=334552 http://www.trifive.com/forums/showthread.php?t=22037 Instagram - Chuckdriver57 |
#56 |
#57 |
look,s good , great color choice on paint..job.
#58 |
Next was to lay down the sound deadener. Also installed most of the interior wiring, brake pedal assembly, and the dash pad. Sound deadener was Fat Mat, it was a shame putting it down on fresh paint..
![]() This is a bad pic, but all of the sound deadener is down. Installed the Ididit column and the new reproduction '69 steering wheel. ![]() |
#59 |
![]() Join Date: Aug 2011
Man that is going to be one beautiful truck!!!!!!I am along for the ride on this one for sure. I have a 69 I bought that has already been painted, but after more inspection once I got it home It still needs more body work/rust repair that was covered up.
Thanks Joe Hester |
#60 |
67cheby
![]() Join Date: Sep 2008
WOW, sorry it took me so long to find this ! IT IS A BEAUTY !
#61 |
Sweet build
Posted via Mobile Device |
#62 |
Next up was to begin installing the vintage air system. My cab was originally non-ac, so before it was painted I had cut the holes in the dash for the factory air vents. On the interior side of the firewall, I had welded studs to mount the evaporator so I wouldn't have bolts sticking through the firewall.
#63 |
Only 2 pictures!?!
Project Double Tap http://67-72chevytrucks.com/vboard/s...d.php?t=555901 69 Olive Verde http://67-72chevytrucks.com/vboard/s...d.php?t=734720 |
#64 |
#65 |
While I was at home with our newborn son, I was able to rebuild and recover the bench seat. I had blasted and painted the seat frame/brackets earlier.
![]() So, I just needed to build up some of the worn foam, put new burlap backing on the foam, and put the new cover on. ![]() ![]() |
#66 |
Got back into the shop this morning, so I took some pics of where the truck is currently at. Once I got the cab back on the chassis, parts were going on pretty quick so I don't have many pictures..
At some point, I had replaced the intake and valve covers with freshly painted chevy orange pieces. Accessory brackets are Alan Grove. ![]() |
#67 |
Not much explanation needed for these.
#68 |
I posted earlier about the clips that I used to secure the fuel and air lines, but here is a pic. Quick clips. Sorry about the chassis being so dirty, hasn't been washed since being painted.
#69 |
Here is the current state of the interior.
![]() ![]() RideTech supplied all of the air ride components. Compressor is mounted on the outer driver side frame rail, near the rear of the cab. ![]() |
#70 |
A/C lines cut, crimped, and installed. Try to ignore the masking tape..
#71 |
Great job! Looks better than new!!
#72 |
![]() Join Date: Jul 2012
Looks amazing so far, I love to see these quality builds.
#73 |
Man you do great work!
#74 |
Nice work.
#75 |
Love the interior color choice. Awesome build. I've got some friends that live by you. Next time in your neck of the woods I'll have to check it out.
