Old 12-30-2012, 12:21 AM   #1
M.Lowrie
Lowrie's 69 Shop Truck
I'm sitting at home with our newborn son, born 12/20/2012, and thought I would start a build thread on my C10 since I'm not allowed to work in the shop for a few more days. A little background on the pickup, purchased in 2011 in Oklahoma at night. It was pretty solid, but had what seems to be an unusual amount of rust in the cowl area compared to the rest of the truck. We'll get into the sheet metal work later, but I wanted to build something cheap and cool that I could cruise around in while working on "bigger" builds. When I got it home.
M.Lowrie is offline   Reply With Quote
Old 12-30-2012, 12:31 AM   #2
M.Lowrie
Re: Lowrie's 69 Shop Truck
It sat for 6 months or so and then I dragged it into the shop. This was around the fall of 2011. So, plan was the following: fix some rust, inside of cab would be nice (new paint and upholstery), air ride, power disc brakes, and leave the original paint on the exterior.
Engine/trans out, sheet metal coming off. Firewall just about fell off..
Old 12-30-2012, 12:56 AM   #3
M.Lowrie
I'll try to get the build thread to where I'm currently at within just a few days, so it will look like the build is moving crazy fast.
When I bought the truck, the previous owner had riveted some sheet metal over the drivers side fresh air vent in the kick panel (he said it had a little rust and had removed the vents and didn't like the air blowing on him so he had riveted a panel over it. Once I started to tear it down, most of the kick panel was missing without a remnant of where the fresh air vent was at.
Didn't take any pics of the driver side, but here is the new metal going in on the passenger side.
Old 12-30-2012, 01:05 AM   #4
M.Lowrie
Some of this may be a little out of order in which it was actually performed, but I kind of did the kick panels, floor pans, and the lower fender mount/A pillar all at the same time. I worked on the driver side first, then the passenger side.
Old floor pans out, lower fender mount repaired.
Old 12-30-2012, 01:14 AM   #5
M.Lowrie
Driver side in and lower kick panel.
I left the front floor pans a little long where the flange would be that meets the firewall until I started to put the firewall back in.
Passenger side in.
Also, had to move the location of the front cab mount hole in both floor pans.
Old 12-30-2012, 01:21 AM   #6
M.Lowrie
Passenger lower fender mount/ A pillar repaired.
Also, you may have noticed that when I built the new kick panel (with the small lower kick panel patch) on the passenger side, I made it with the same radius as the driver side where it meets the firewall. This is where the blower for the heater would be mounted in the stock location, but I decided to go with Vintage Air so I didn't need the externally mounted blower anymore.
Old 12-30-2012, 01:50 AM   #7
67c10rustbuket
67c10rustbuket's Avatar
Nice job so far, you have done some serious rust repair! Where in Ok did this truck come from? Looked pretty solid in the first two pics.
Dan <---(my name)
67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car
67c10rustbuket is offline   Reply With Quote
Old 12-30-2012, 01:57 AM   #8
M.Lowrie
Up next was to repair the area that is below the inner cowl. I had to replace the entire flange where it meets the firewall and where the wiper motor bolts to (the wiper motor was "glued" in with RTV).
Also, had to rebuild the pieces that seem to collect all the leaves just outside of the fresh air vents, the entire lower half of these pieces were missing, these are clamped to the kick panel in the pic below.
Old 12-30-2012, 02:07 AM   #9
M.Lowrie
Thanks. Truck was real solid other than the front half of the cab, everything else was good even the original cab corners. The cowl must have filled up with leaves and left for some time. I got the truck from the Poteau area, just north of it if I remember right.
Old 12-30-2012, 11:57 AM   #10
builtbyKane
builtbyKane's Avatar
Wow that is a lot of rust repair. I love that stock color scheme.
builtbyKane is offline   Reply With Quote
Old 12-30-2012, 12:09 PM   #11
M.Lowrie
Yeah, there was more rust than I had originally thought especially since I looked over the truck in a dirt driveway at night. I really like the light green/white but it made it challenging picking a color for the interior. The original interior has kind of a hunter green and the green that they repop is a olive green, after buying a complete "olive" green interior I decided I didn't like it and went with saddle.
Old 12-30-2012, 12:22 PM   #12
M.Lowrie
Then the inner cowl went on, I could have repaired the original but at this point I was tired of doing metal work on it. So, I bought a replacement panel and modified the passenger side so that it would have the same radius as the driver side (eliminating the area for the heater blower motor).
Welded on.
Old 12-30-2012, 12:25 PM   #13
M.Lowrie
I'm getting a little out of order here, but before I put the inner cowl in I mocked up the new firewall so that I could put the flange in the front of the floor pans.
Old 12-30-2012, 12:30 PM   #14
M.Lowrie
Filled the ac/heater holes in the passenger side of the firewall and made up piece for the blower motor area.
Firewall welded in and started to put the dash back in.
Old 12-30-2012, 12:34 PM   #15
Gus350
68 C 10
Gus350's Avatar
Looks good i'll be watching this one i have one in just about the same condition.
Kevin
"Life is Hard But its Harder when your Stupid"
John Wayne
68 C10
70 C20
http://67-72chevytrucks.com/vboard/s....php?t=602326#
Gus350 is offline   Reply With Quote
Old 12-30-2012, 12:39 PM   #16
M.Lowrie
Then the dash was put back in for good.
After this, the only sheet metal that I had not welded in was the rockers. I had mocked them up with the doors hung, but I didn't want to fully weld them until I got a little further with the body work. Sorry for the blurry pic, not sure what was going on..
Old 12-30-2012, 12:54 PM   #17
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Awesome skills!
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 12-30-2012, 01:52 PM   #18
M.Lowrie
Originally Posted by 72BlckButy View Post
Awesome skills!
Thanks!
Old 12-30-2012, 01:59 PM   #19
M.Lowrie
I then pulled the cab off and set it aside so I could work on the chassis. There were only a few modifications to the frame, so I did these before it went out for blasting.
CPP notch in.
Notch roughed in for side fill/rear mount gas tank, also a CPP unit. I guess I didn't get a pic of it fully welded before paint.
Old 12-30-2012, 02:10 PM   #20
Rust_phoenix
Rust_phoenix's Avatar
Nice work! it's amazing what some of these trucks can be hiding underneath their outer skins, your truck looked pretty solid before you took it down. looking forward to seeing more of your build.
Rust_phoenix is offline   Reply With Quote
Old 12-30-2012, 02:12 PM   #21
bigguy69
dazed and confused
bigguy69's Avatar
Wow amazing work!
members met: redbaron69, billsbowtie,nc67
bigguy69 is offline   Reply With Quote
Old 12-30-2012, 04:17 PM   #22
gearys 5600
gearys 5600's Avatar
Nice work...What are you using for engine and trans?
MY BUILD THREAD http://67-72chevytrucks.com/vboard/s...d.php?t=423629
1969 custom/10 swb--SOLD
1968 swb 50th anniv.--SOLD
1967 camaro ss/rs..LS-6-speed, 16-year long project
1956 chevy nomad
1955 chevy 210 2-dr sedan
1978 el-camino ss 1-owner
gearys 5600 is offline   Reply With Quote
Old 12-30-2012, 07:00 PM   #23
M.Lowrie
Just a carb'd 350/TH350. It had a freshly built 383 in it when I bought it, but the previous owner put metric starter bolts in and cracked outward mounting hole in the block. I had another engine in the shop that wasn't being used, so that's what is going in it.
Old 12-30-2012, 07:17 PM   #24
M.Lowrie
Frame and suspension pieces back from blasting and being primed.
Black going on.
Chassis going together.
Old 12-30-2012, 07:27 PM   #25
M.Lowrie
Building rear axle. New drum brake components and 5 lug axle shafts.
Rear axle and front disc brakes installed. Front brakes, drop spindles, and booster/master are McGaughy's.
