02-09-2013, 10:14 PM | #51 |
Old member
Re: PS bracket issue on '71
OK, after looking at all these again I suggest a new crank pulley yours has seperated from the rubber mount on the inside. I see what you were hammering now. You had the pulley seated but the balancer has seperated. It's junk.
There is no way to fix this that I know of I don't think.
02-09-2013, 10:15 PM | #52 |
67-72 parts collector,…
You can tell in the older pics that n2billet posted,... that the pulley was farther back at the time he took his picture.
The pulley has moved forward,... just like the outer ring of a SBC harmonic balancer moves forward, when it goes bad. I think you are going to need to find a new balancer pulley combo.
02-09-2013, 10:20 PM | #53 |
Thanks for the help guys. Not to hammer this point, but what are the chances of significant damage?
02-09-2013, 10:23 PM | #54 |
The only damage would have been if it had come off.
http://www.oreillyauto.com/site/c/de...2316&ppt=C0332
02-09-2013, 10:32 PM | #55 |
Old member
I doubt it did any harm to the motor at all. If it had not thrown the belt then it could have wrecked the motor. It throwning the belt was a good thing.
02-09-2013, 10:39 PM | #56 |
I just looked at some photos from my build progress, and I have no space on mine.
02-10-2013, 01:30 AM | #57 |
Thanks again. If I go with that harmonic balancer can I go with a crank pulley that bolts up like most or do I need to stay with the one piece unit that has both? There is a wrecking yard near me that apparently has some old Chevy vans and trucks so I'm hoping there are some 250's in there.
02-10-2013, 05:47 AM | #58 |
Old member
The crank pulley should be by it's self with the other's bolted to it with 3 bolts. The balancer should have the center bolt in it to hold it to the crank shaft.
Here is my 305 after install. There is plenty of clearance but the picture angle makes it look very close. After I took the picture I went bck out and checked it.
02-10-2013, 06:52 AM | #59 |
Old member
Here is a post in the " What did you do to your truck today"
By, "ctorres25" He needs to install a bolt in the center mounting hole also in this picture. Here is the link. http://67-72chevytrucks.com/vboard/s...01176&page=301
02-10-2013, 10:28 AM | #60 |
Thanks, those pics help a lot. That last pic is the exact PS/Alt mounting bracket I have so I think once the crank is back in place I will finally be good to go. The picture of those two set ups are what I was used to seeing for crankshaft pulleys. I had never seen one like mine before I did some googling yesterday.
I can switch to a setup like yours right? |
02-10-2013, 11:40 AM | #61 |
I don't think the crank is "drilled and tapped" for a bolt.
02-10-2013, 11:50 AM | #62 |
That was my fear as well. I'm not sure if the link to the HB you gave will work. I'll do some digging, I appreciate the input as this is something I haven't done before.
02-10-2013, 12:16 PM | #63 |
Do you even need the "add-on" pulley?
All you are driving is the alternator and the P/S pump.
02-10-2013, 12:20 PM | #64 |
That link was for a 1971 C10 with a 250.
02-10-2013, 12:29 PM | #65 |
Not sure about the other pulley Keith. I have an O'Reiley's close, I'll stop by there today. My guess is it will need to be ordered regardless as I doubt they have one in stock.
02-10-2013, 12:30 PM | #66 |
Village Idiot....
Sorry for coming in late on the discussion (work is getting in the way)......I never pulled the balancer off while I had the truck. I went back and looked at all my pictures and it looks like it's slide forward like everyone else has said..
http://www.hubgarage.com/mygarage/n2billet -67 SWB Custom Porterbuilt Front and rear 20/22's Hazel Sold -71 StepSide Porterbuilt Stage 2 with 20/22's Stella Mae Sold |
02-10-2013, 01:23 PM | #67 |
There's lots of info on the internet where people drill and tap the crank for a 7/16-20 balancer bolt.
This would also help install a new balancer with the correct installation tool. There is also equal amounts of info abount not drilling the crank and just "hammering" on a new balancer. (do not beat on the outer ring)
02-10-2013, 01:37 PM | #68 | ||
02-10-2013, 05:04 PM | #69 |
Old member
I don't know about the 250's but all the V-8 I have ever seen had the center bolt in them. I can't say 100% of them do but I would think they should have it.
02-10-2013, 05:13 PM | #70 |
Early 265's, 283's, some 307's, and even some 327's had press on balancers with no drilled hole in the crank.
Here's a good thread: http://www.crankshaftcoalition.com/w...ve_and_install
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 02-10-2013 at 05:19 PM. |
02-16-2013, 03:11 PM | #71 |
Got it off. The outer piece came off by me pulling by hand, that could have been nasty if the belt hadn't come off. The inner piece was tough, crows foot got it though.
So that link to the Dorman HB is the only part I need? I'm not sure how I'm going to get it on without pulling the radiator as it will need to be tapped into place since it's a press fit unit. |
02-25-2013, 12:35 PM | #72 |
Well that's just great, backordered 60-90 days!
02-25-2013, 12:57 PM | #73 |
02-25-2013, 02:05 PM | #74 |
Just ordered one off rockauto. Thanks! If that one is back ordered I'll go to summit.
02-25-2013, 05:25 PM | #75 |
Rockauto came through, in stock and shipped today. I will post some after pics once I get everything back together.
