#1 | |
Re: HELP! First truck, need to be back on the road
For the disc conversion, that's up to you, properly working drum brakes are just fine. Why do you think they used them so long?
71 K20 64 GMC mud truck |
#2 | |
Posted via Mobile Device |
I'm not sure, we're in the middle of doing mine right now and the back is done and it cost roughly $200. Got the drums turned but we replaced the wheel cylinder, pads, springs etc. Front will probably cost about the same but it will be so much easier since there are less parts.
What do you mean less parts? Because its disc up front and drum in the rear?
Yes sir. It's a lot less complicated than drum brakes.
![]() If you don't replace the calipers, only push the piston in (using a C clamp) as far as you need to otherwise the rust on the piston could get hung up on the caliper and not come back out. Hopefully that makes sense, I'm not the best at explaining things
Haha that was good, and thanks for the responses!!
Brake jobs usually won't break the bank. And like stated better safe than sorry. There are some idiot drivers out there. Sticky drum brakes are a bad story too
72 GMC super custom.
| Bookmarks |
| Tags |
| 350, 4wd, automatic, restore, stepside |
