Old 02-02-2014, 04:41 AM   #51
jjzepplin
jjzepplin's Avatar
Re: Another 4X4 Front Sway Bar
Will these install in 72 frames and can I get in line for one? Oh I have a d60 with the plates that have the sway bar bolts in them already. Will it work?
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 02-02-2014, 10:00 AM   #52
KrazyRay
KrazyRay's Avatar
Yes it will work. Your spring plate has the same provisions for the sway bar as the others. The difference is the wider u bolt pattern for the big axle. pm sent.
Thanks,
Ray
KrazyRay is offline   Reply With Quote
Old 02-02-2014, 10:19 AM   #53
KrazyRay
KrazyRay's Avatar
Originally Posted by 72longbed View Post
Hey Ray,
I bought the sway bar and spring plates from you a while back, if you remember? Never did get the crossmember itself from you.
What would you charge me for just a crossmember itself for my 72 K20 shipped to 19525?
Thanks Ray,
72longbed
pm sent
Old 02-02-2014, 10:56 AM   #54
72longbed
72longbed's Avatar
Ray,
please resend .... Inbox was full.
Thanks,
72
72longbed is offline   Reply With Quote
Old 02-03-2014, 08:28 PM   #55
jjzepplin
jjzepplin's Avatar
I'll take one-money on the way.
Keep me in mind for a rear!
Old 02-04-2014, 09:05 AM   #56
jjzepplin
jjzepplin's Avatar
Ready to send money.
Could you post some pics of the one I will get?
I have the spring plate bolts one the dana 60
And will not need those either unless they are different for some reason.
I am kicking myself right now for leaving all this stuff in Cali when I moved...
Old 02-04-2014, 09:23 AM   #57
KrazyRay
KrazyRay's Avatar
The one you are getting is on post 46 of this thread minus the spring plates because you will need to use your dana 60 spring plates, u bolts, and bolts.
Thanks,
Ray
Old 02-04-2014, 09:44 AM   #58
jjzepplin
jjzepplin's Avatar
Originally Posted by CUSTOM/10 View Post
Ray
What if you have the stock steering box frame reinforcement plate welded in the inside of the frame rail. Will this work or would additional mods be needed ?
Thanks !
Gary
I have the inner frame plate and an outer aftermarket plate. I am sure i could make it work though. Will post pics when I get it and go for this upgrade.
Old 02-04-2014, 09:47 AM   #59
jjzepplin
jjzepplin's Avatar
Payment sent. Thank again!
Do you have the part #'s for bushing replacement?
Old 02-04-2014, 09:54 AM   #60
CUSTOM/10
CUSTOM/10's Avatar
I really like the ideal of having a front swaybar on my truck to help the handling. For the most part it will be used on the road, rarely seeing any off-road. But I'm also trying not to make to many mods to the truck that require drilling holes or cutting the frame. I also have the spring plates for the swaybar, so wouldn't need those.
How much would a set-up be shipped to 03873 with out the spring plates ?
Gary
Gary
72 SWB 4x4
My 72 SWB Build
http://67-72chevytrucks.com/vboard/s...d.php?t=259859
CUSTOM/10 is online now   Reply With Quote
Old 02-04-2014, 12:31 PM   #61
KrazyRay
KrazyRay's Avatar
jjzepplin...Thanks. It will ship out this week.
custom/ 10...Its $125 total shipped without spring plates. I have another one being pulled in the next week.
Thanks,
Ray
Old 02-04-2014, 01:23 PM   #62
CUSTOM/10
CUSTOM/10's Avatar
Let me know when you have it out !
Gary
72 SWB 4x4
My 72 SWB Build
Old 02-06-2014, 06:41 AM   #63
jjzepplin
jjzepplin's Avatar
Jumped the gun on this and another one. So could I pass this one to Custom/10?
Old 02-06-2014, 11:00 AM   #64
CUSTOM/10
CUSTOM/10's Avatar
Paypal sent !
Gary
Gary
72 SWB 4x4
My 72 SWB Build
Old 02-24-2014, 02:36 AM   #65
KrazyRay
KrazyRay's Avatar
Here's another available:
Old 02-24-2014, 10:38 PM   #66
Levi.Johnson
Levi.Johnson's Avatar
How much total with shipping to 77441?
Thank you,
Levi
Levi.Johnson is offline   Reply With Quote
Old 02-24-2014, 10:39 PM   #67
Levi.Johnson
Thank you,
Levi
Old 02-24-2014, 11:45 PM   #68
KrazyRay
KrazyRay's Avatar
pm sent
Old 02-25-2014, 02:20 PM   #69
chewysask
Active Member
Do you ship to Canada?
chewysask is offline   Reply With Quote
Old 02-25-2014, 02:33 PM   #70
Levi.Johnson
I'll take it. Payment sent.
Thank you,
Levi
Old 02-25-2014, 07:16 PM   #71
1972 Jimmy
1972 Jimmy's Avatar
I would be interested in a sway bar assembly for a 72 Jimmy!! How much to ship to 48623?
1972 Jimmy is offline   Reply With Quote
Old 02-25-2014, 07:36 PM   #72
KrazyRay
KrazyRay's Avatar
Sway bar sold to Levi...Thanks!
1972 Jimmy...Its $42 to ship to MI for a total of $132. It might be a little while before I get to the next one.
Thanks,
Ray
Old 02-25-2014, 08:18 PM   #73
1972 Jimmy
1972 Jimmy's Avatar
Thanks,
Ray
Count me in on the next one you find for a 1972 jimmy/blazer!!!
Thanks, Eric
Old 02-25-2014, 11:39 PM   #74
rusty knuckles 5
HI! I am interested in a sway bar system , will i have to drill new holes in frame or will i be able to use old existing holes? 1972 k-20 thanks
rusty knuckles 5 is offline   Reply With Quote
Old 02-26-2014, 01:57 AM   #75
KrazyRay
KrazyRay's Avatar
You need to drill some holes.
