Old 09-23-2013, 12:10 AM   #51
Baldeagle SR
Re: Old Yeller my build 56 GMC
Run to the pines car show Sept 28 and 29 This coming weekend in Pinetop AZ.
This is a real good car show cars from all over the states.
There may be a better place to put this.
Rich
Baldeagle SR is offline   Reply With Quote
Old 10-02-2013, 11:46 PM   #52
waybad
waybad's Avatar
cool build,, love the gas filler door!! well done!
waybad is offline   Reply With Quote
Old 10-03-2013, 09:35 AM   #53
Baldeagle SR
Thanks Guys Got the bed and rear fenders painted, Painted the cab yesterday. I have painted cars before but not in pieces. What a pain. I am running out of places to put things. I will post some pic this weekend. Rich
Old 10-07-2013, 09:22 AM   #54
Baldeagle SR
Made an opening in the running board for the ex pipe. Got the stearing column mounted.
Old 10-07-2013, 09:26 AM   #55
Baldeagle SR
a few more pic
Old 10-07-2013, 09:38 AM   #56
Baldeagle SR
I cut a piece of 3/16 vacuum hose and put it around the hole for the steering column I slit the hose so it would go into the sheet metal. Maybe it will cut down on any squeaks . Not that I could hear it anyway.
The seats are out of a crysler new Yorker . They were free. The head rest have to go. The six way all work. I will change the seats later on. I just need to get the truck moving under it's own power.
Hope to get the motor in and running this week.
Rich
Old 10-07-2013, 10:33 AM   #57
Kim57
Kim57's Avatar
Looking good.
Nice idea on the hose in the column opening.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 10-09-2013, 07:40 PM   #58
Baldeagle SR
Thanks Kim.'
I really had problems with this paint. Most of it was the humidity. I am not a painter but I have painted about ten vehicles and never had this much trouble.
The glass co is to be here Friday To do the windshield. Rich
Old 10-09-2013, 08:47 PM   #59
_Ogre
_Ogre's Avatar
and to think they think modular is a new term
shop air compressor timer
Old 11-28-2013, 12:05 PM   #60
waybad
waybad's Avatar
looks killer
Old 11-28-2013, 01:55 PM   #61
Denee007
Denee007's Avatar
looks fantastic, love the color! There must be a lot of support in the cab to hold the front and rear glass in! Looking at the cab, there's only those for little supports holding the roof up! I guess the glass is part of the cab structural integrity?
dne'
'72 Ford Bronco project(July 17 2021-?)
https://67-72chevytrucks.com/vboard/...d.php?t=828015
59 Apache (sold 6-25-2021)
67 Ford Mustang (re-restored after Harvey)
1968 Jeep Cj5 (2-8-2020 to present)
1992 Jeep Yj (8-17-20 to present) (Jurassic build)
www.Classiccarsandtools.com
Denee007 is offline   Reply With Quote
Old 11-29-2013, 11:27 AM   #62
Baldeagle SR
Dne There isn't a lot of support. A roll over would flatten it pretty easy.
I will try to update this thread this evening. The last month or so has been a struggle. One step forward and three steps back.
The back glass was a bear to install. It took a friend and me 2 1/2 hours just to get the glass in the rubber in the cab. I have done in the past simmler glass with the same rubber and you could put the glass and the middle rubber in about 30 minutes and I have the special tool install the center rubber.
The glass co put the front new windshield in and didn't get the chrome in right .I have called them and even stop by and ask them when they were going to fix it. They still haven't showed up. Lucky I haven't paid them yet.
They also were going to tint the rear window when it was out and they couldn't do that .
I don't know if there is a problem with the rubber I ordered or the truck cab, cense I had so much trouble with the rear window. I will try to get some pic today.
Rich
Old 11-29-2013, 12:17 PM   #63
JML55
JML55's Avatar
Yes i had hard time with my back window too. The after market back window i got was already tinted but the shape wasn't quite right, with the factory type seal it wasn't too hard to put in but the glass corners were a bit short and the seal wouldn't seal the gap propely, you could see inside the cab around the upper edge of the corner, had to go with a fatter seal which work ok but still not the best fit.
Jean-Marc Lacasse
57 GMC
55 GMC
55 Belair
99 S10
http://67-72chevytrucks.com/vboard/s...d.php?t=316140
http://67-72chevytrucks.com/vboard/s...d.php?t=806011
JML55 is offline   Reply With Quote
Old 11-29-2013, 01:18 PM   #64
_Ogre
_Ogre's Avatar
I can tell you from experience that these trucks don't handle roll overs well.
Doors fly open, glass comes out, roof comes down and the occupants take a beating.
My windshield went in fast, the back Window took a while to insert the key
Old 11-29-2013, 08:52 PM   #65
Baldeagle SR
I got the Omega gauges installed in my dash panel, Made a plugin from the steering column wire loom from the Chrysler donor car. I have 2 plug instead of wiring each gauge separate.
Got my 20 circuit wiring asm installed and the interior is all set to go.
I got the wiring off of ebay and it went pretty smooth . no problems at all. There was no instructions with the wiring . All the wires was labeled.
The motor is running and so far everything is fine. Rich
Old 11-29-2013, 09:02 PM   #66
Baldeagle SR
A few more pic. Rich
Old 11-29-2013, 10:32 PM   #67
Kim57
Kim57's Avatar
You sure got it looking good.
Kim
My build thread
Old 11-29-2013, 10:46 PM   #68
Daze57
Daze57's Avatar
x 2^
Daze57 is offline   Reply With Quote
Old 12-01-2013, 11:39 AM   #69
Baldeagle SR
Thanks everyone for the comments.
Got the power ant installed and working.
Run into a problem with the steering column I got from Brothers. It didn't have a slot for the neutral safety switch and backup lights. I called the number that was with the instructions and it was Classic performance products. even though I ordered it from Brothers . The person told me that the chrome steering columns doesn't come with a set up for the neutral safety switch. I ordered a switch that mounts on the trans .
and a toggle switch for the backup lights. Rich
Old 12-01-2013, 11:41 AM   #70
Baldeagle SR
Forgot this one .
Old 12-11-2013, 11:08 AM   #71
Baldeagle SR
Got the insulation done and the carpet installed. The carpet I got from Lowes for $28.00.
Working on the headliner now. Trying to decide if the insulation will stay stuck to the roof when it sets in the sun. Any ideas? Will get some pic soon. Rich
Old 12-24-2013, 06:07 PM   #72
Baldeagle SR
Just wanted to wish everyone a Merry Christmas and a safe New Years. Rich
Old 01-02-2014, 10:51 AM   #73
59stepside
59stepside's Avatar
I am now tearing into the steering column and brake pedal project and using the camaro pedals and mounts. I got them cut and somewhat fitted and got my column where I like it, I think. Do you have any more pics of yours. I see your pedal mount is mounted pretty high, did you have to lengthen it and did you you reshape it to allow for enough travel?
USCG Aviator
C-130
1959 Stepside build - http://67-72chevytrucks.com/vboard/s...d.php?t=602386
59stepside is offline   Reply With Quote
Old 01-02-2014, 07:14 PM   #74
Baldeagle SR
Stepside I did add about 21/2 inches to the pedal asm , and I had to cut in such a way it would raise it off the floor a little. My pedal is 6 in from the floor measuring straight down from the pedal. Sorry I don't have any more pictures to show you. I still use the same brake light switch. That is what that hole is for in t6he front of the asm. Hope this helps.
Rich
Old 01-02-2014, 09:35 PM   #75
59stepside
59stepside's Avatar
That does help! I was looking at how high you mounted your master (which looks good) and then looking at my bracket and knew you had to do something. Thanks for the info.
USCG Aviator
C-130
