Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1973-1987 Chevrolet & GMC Pickups Parts Board
Old 02-24-2015, 01:54 AM   #51
1774btcrew
1774btcrew's Avatar
Re: Hydraulic pedal assemblies 1 with hydroboost, one with vacuum
Originally Posted by naphtali5725 View Post
hey 1774btcrew, do you know what I would need as far as pedal assembly to change my 86 auto to a tremec or a muncie style 4 speed etc.? do i need a manual style pedal assembly, or would it be best to convert to a hydraulic setup??
i have a Olds 455 in my truck, so i was going to use a BOP lakewood bell housing
my truck came with vacuum brakes...
thanks
I prefer a hydraulic setup but it is personal preference. It is a lot smoother operating system though. Parts wise to convert you would need a pedal assembly, clutch slave and master cylinder, factory metal and rubber line for slave cylinder and clutch reservoir
AZPartsLocators on Instagram
1972 Cheyenne Super Short Bed big block "Blackie"
1977 Crew Cab GMC Short bed with 4BT Intercooled Cummins Diesel and a 4L80e "The Junkyard Dog"
1985 Crew Cab Chevy dually with 5.9 Cummins "The Big Dog" This is what my dad liked to be called by the grandkids before he passed so it seems fitting for his old truck.
1774btcrew is offline   Reply With Quote
Old 03-09-2015, 01:33 AM   #52
1774btcrew
1774btcrew's Avatar
These are both still available! If you want one please keep in communication and don't disappear. I end up having several people want them and by the time I have given up on the first would be buyer the others have disappeared. I put a lot of time in getting these pedals ready for customers between welding the pins and building with new bushings. Not including boxing and shipping times. I sell only the best quality in these.
Old 03-16-2015, 06:30 PM   #53
1774btcrew
1774btcrew's Avatar
ttt
Old 03-19-2015, 07:28 PM   #54
bL.A.zer90045
no longer in search of the hydro set-up im gonna be using my manual set-up with a howe hydraulic throw-bearingthanks for looking out!
bL.A.zer90045 is offline   Reply With Quote
Old 03-19-2015, 09:29 PM   #55
1774btcrew
1774btcrew's Avatar
No problem! I really just need to list it on Ebay as they sell for more there. I just try and hook the members up here first.
Old 03-19-2015, 09:47 PM   #56
68Timber
I know the pieces fit
68Timber's Avatar
I had to google that to see how it worked and saw a bunch of stuff about leaking and redesigns. Is that sorted out now?
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 05-22-2015, 03:50 AM   #57
Code6charles
Interested in a hydraulic pedal assembly. Need one with the hydro boost, still have one?
Code6charles is offline   Reply With Quote
Old 05-22-2015, 10:27 AM   #58
1774btcrew
1774btcrew's Avatar
I don't currently have any in stock. I do get them in on a relatively regular basis though. If you want to send me a PM with your email address, I can contact you if I get one pretty quick
Old 05-31-2015, 11:40 PM   #59
Code6charles
I currently have an auto trans with a hydro boost brake system. I want to put a dodge nv4500 with a cummins into my 91 suburban. Would you happen to know what master clutch cylinder would work best with the dodge slave cylinder?
Old 06-01-2015, 10:25 AM   #60
1774btcrew
1774btcrew's Avatar
I honestly don't have any idea when it comes to the Dodge stuff. You could probably start a post on here. There are a lot of members that are very knowledgeable about the manual trans stuff that can steer you in the right direction. Sorry I couldn't be of any help!
Old 06-01-2015, 12:15 PM   #61
Code6charles
Good idea, please let me know if you get a set of pedals. That's what I need to start my project going, I don't want to install the engine/trans without the pedals. Thanks again,
