02-05-2015, 09:03 AM | #51 | |
Re: Pink's 68/72 - Dropmember Equipped Build
http://67-72chevytrucks.com/vboard/s...d.php?t=633212 |
02-05-2015, 10:28 PM | #52 | ||
02-08-2015, 11:35 PM | #53 |
Worked on welding up the back half. I also decided to weld in the rear body drop and I have an idea for the front bracket as well.
02-11-2015, 10:58 PM | #54 |
Almost done with one side. I decided that it would look better if I blended the body drop bracket with the step notch. It's not done yet but I'm liking the way it's turning out
Before After |
02-11-2015, 11:12 PM | #55 |
A320 Pilot/USAF Retired
Nice touch!
JJ My 1957 build: http://67-72chevytrucks.com/vboard/s...d.php?t=334552 http://www.trifive.com/forums/showthread.php?t=22037 Instagram - Chuckdriver57 |
02-11-2015, 11:46 PM | #56 |
Looks killer, glad you did it because it kind of stuck out to me. Now it flows really good and looks like it belongs there.
02-12-2015, 12:00 AM | #57 |
Looking good so far, im glad I got the weld in also, just didnt want the bolts all over the place and have zero chance of ever unbolting it once installed.
02-12-2015, 03:53 AM | #58 |
02-12-2015, 10:36 PM | #59 | ||
Sorry, I should have specified SoCal South Bay not NorCal (Redondo Beach/Manhattan Beach area) |
02-14-2015, 01:10 PM | #60 |
Here's a good overall pic of the rear setup now. Hours and hours of work but it was worth it. I started modifying the front body drop brackets. No pics yet but I should be able to make some progress on it this weekend.
02-14-2015, 02:32 PM | #61 |
Looks way better done that way, hours well spent!
02-15-2015, 09:04 AM | #62 |
Great work so far- I like all the little details. This might be a little late and maybe you already know. If you use a heavy piece of copper to back the holes when you weld them shut, it makes it a lot easier. The weld won't stick to the copper and it will save a lot of gringing on the back side as it will be smooth and flush. I've got most of my frame holes welded up too- man there was a bunch.
02-15-2015, 05:58 PM | #63 | |
02-15-2015, 06:07 PM | #64 |
So here's an update on the front body drop brackets. Hope you guys like it.
I started off by tack welding the frame horns in place with the brackets still on. Then I removed the bracket and sliced and diced the front horns so I could bend it how I wanted. Once in place, I started welding it up. I worked on blending in some of the welds, not done yet though. Then I trimmed down the bracket. I have a little more massaging to do but it's close. |
02-16-2015, 09:34 AM | #65 |
Looking Good
02-16-2015, 12:32 PM | #66 |
Looking good! Nice touches to the frame!
Ryan 1967 Red Stepside..."Laymond" http://67-72chevytrucks.com/vboard/s...40#post6441840 1972 Medium Olive SWB-Chester http://67-72chevytrucks.com/vboard/s...d.php?t=759628 1967/71 Blue SWB C10..SOLD 1977 SWB K10..my grandpa's.....never should have sold |
02-28-2015, 08:33 PM | #67 |
I appreciate the compliments. Thanks guys!
02-28-2015, 08:42 PM | #68 |
I made progress on the drivers side body drop bracket. This one took a lot less time since I had learned my lesson on the passenger side.
I've also been thinking about boxing in the notch for a while. Since I spliced two frames together, I was worried about the strength of the front end. I had those old PBFab frame boxing plates so I decided to put them to use. I still have a lot of work left on this but these pictures should give you an idea of what I'm trying to do. |
02-28-2015, 09:23 PM | #69 |
That looks like it will work out great!
my build threads '86 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415628 '67 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=635078 '63 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=674682 |
09-05-2015, 12:22 AM | #70 |
It's been a while since I was able to work on the truck. We sold our place, lived in a temp house for a couple months and finally settled in our new house. I got myself a new project (72 Nova) which has also taken some time away from the truck.
Here's a few pics of the new project Flipped over the frame to start working on the bottom side Started filling more holes on the bottom side Also started welding up the bottom side of rear notch |
09-07-2015, 07:20 PM | #71 |
Nice looking Nova, and a beautiful German Shepherd (maybe rottweiler? Looks like a shepherd body, but rottweiler markings on the face). Looks like some nice welding happening on the C10 frame too.
-Duane C/10 Club Texas member 1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project) 1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby) |
09-09-2015, 12:02 AM | #72 |
Right on actually, rott/shepherd mix, about 5 months old
09-09-2015, 12:08 AM | #73 |
Glad to see you're back at it, congrats on the house. The Nova looks to be in pretty good shape. I had a 70 years ago, it was an ugly yellow and had 50 lbs of bondo in both rear quarters. Haha it was a real beater.
Back on that frame, I need some inspiration for when I get cranking on mine. |
09-11-2015, 05:41 PM | #74 | |
As far as the truck goes, I got some more welding done on the rear notches. Drivers side is done Passenger side is almost there |
10-13-2015, 12:13 PM | #75 |
Not much of an update, just a bunch of welding and grinding lately. There are way too many holes on this thing to fill.
Here's what the back of the step notch underside looked like before. and after here's a pic of the other side too I also picked up this 5.3l & 4l60e combo for the nova. |
