Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 03-12-2015, 02:16 PM   #51
fattyarbuckle
Re: Project "Olive-U2"
more progress,
Installed the new grill.
Seat should be done tomorrow, glass going in this weekend!
fattyarbuckle is offline   Reply With Quote
Old 03-16-2015, 08:12 AM   #52
fattyarbuckle
glass is in.
Not as hard to do as we thought but a pain in the butt. Fingers hurt this morning from trying to work the gasket in place...
Old 03-16-2015, 09:37 AM   #53
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
That is an awesome looking truck! Nice Job!
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 03-20-2015, 11:26 AM   #54
fattyarbuckle
seat and steering wheel installed....
Almost ready for the road!
Old 03-20-2015, 02:03 PM   #55
MyDad'sTruck
Wow!
MyDad'sTruck is offline   Reply With Quote
Old 03-20-2015, 10:17 PM   #56
fattyarbuckle
pretty amazing work from a young man of the ripe ole age of 27.....(24 when started)
Good Job son!
Old 03-22-2015, 02:27 AM   #57
swamp rat
swamp rat's Avatar
Not just amazing work but how quickly its getting done!
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 03-25-2015, 09:38 PM   #58
71Sixer
71Sixer's Avatar
I just want to say thanks for the good words on the truck. Finally took it for a test spin and it did great. I've still got several things to finish up before it's road worthy but it's getting there.
Still need to get the door glass and vent windows rebuilt and installed. I had an issue with my turn signal switch, and my wiper switch, also. Just a few more small things to button up and it'll be back on the road! I just want to thank my dad for posting pictures for me. Between work and the truck, I'm not on here as much as I'd like.
71Sixer is offline   Reply With Quote
Old 03-26-2015, 05:30 PM   #59
Yukon Jack
Post Whore
Yukon Jack's Avatar
Awesome build!
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 03-29-2015, 09:23 AM   #60
fattyarbuckle
drove the truck yesterday....going to be sweet when complete!
Are there any alignment points on the front other that toe? Seems like truck wants to wander and is loose. I thing the old gearbox may be the problem and some toe settings but just looking at it the camber seems off too.
Old 04-02-2015, 07:09 PM   #61
fattyarbuckle
new pictures!
Got to get the door panels on.... just about done (are they ever really done?)
Old 04-20-2015, 01:05 PM   #62
fattyarbuckle
Can anyone tell me what this bracket is?
Is there supposed to be one on each side or just driver side like this picture shows.
I found this picture from another frame that is the same as Sean's, there are holes in the frame in same spot on passenger side but not bracket like this one.
Sean's truck seems to be steering strange, like wheels not wanting to center when a bump hit and when you correct it seems to over correct. Something seems wrong and we can't figure it out.
Tried different toe settings nothing seems to work.
Old 04-20-2015, 01:10 PM   #63
fattyarbuckle
you can see on Sean's truck there is only one bracket on driver side too.
Old 04-20-2015, 01:43 PM   #64
CUSTOM/10
CUSTOM/10's Avatar
There's just the one on the drivers side. You should also have a plate that's welded on across the front of the spring also. These keep the spring somewhat in place ( and allows you to steer ) in the case your main leaf should brake. And it does work !!! I had my main leaf brake 400 miles away front home on a hunting trip up in northern Maine. I new something had broken, but it wasn't until I got home that I found out what. The mane leaf broke off just behing the front eye bolt bushing so it was difficult to see.
Gary
Gary
72 SWB 4x4
My 72 SWB Build
http://67-72chevytrucks.com/vboard/s...d.php?t=259859
CUSTOM/10 is online now   Reply With Quote
Old 04-20-2015, 01:48 PM   #65
CUSTOM/10
CUSTOM/10's Avatar
Here in your own pic you can see the other bracket in front of the front eye bolt !
Gary
72 SWB 4x4
My 72 SWB Build
Old 04-20-2015, 02:00 PM   #66
fattyarbuckle
Got any ideas on why steering is so bad? The truck is real squirrely and almost hard to drive right now.
Goes straight on smooth road but real touchy and hard to keep in lane faster you go.
Could tires be problem?
Power steering is real easy and doesn't seem to have a lot of play....
Old 04-20-2015, 02:00 PM   #67
swamp rat
swamp rat's Avatar
What i read here on the forum is that frame bracket and on the front shackle mount should have a steel plate going across the front, they are there so in the event of a broken spring on that side it gets captured so you can still steer the truck off the road, passenger side won't have them.
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 04-20-2015, 02:10 PM   #68
fattyarbuckle
We'll get some better pictures to post to see if anyone can see something wrong.
Old 04-20-2015, 02:14 PM   #69
swamp rat
swamp rat's Avatar
All new ball joints, tie rod ends, spindle bearings right? Rag joint? steering column tight?
Did you replace the steering box and pump? could you have gotten a bad one?
try setting the toe in a little narrow in the front, when you drive down the road it will want to try and widen a little.
Did you get an idea what the camber is? i cant recall the spec but check it to see that its close.
my truck was darting allover the road untill i rebuilt the Dana, it still wants to wander a bit but i will be replacing the steering box soon with a init from Readhead steering.
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 04-20-2015, 02:25 PM   #70
fattyarbuckle
Everything new except power steering box.
Maybe another steering dampers is needed.
Old 05-13-2015, 03:40 PM   #71
67chevy1series
67chevy1series's Avatar
One day while driving my k10 I noticed I lost a significant amount of turning radius for turns and it was intermittent as well so finally after navigating my way through a housing area that I was in I pulled off the road and looked under the truck as my friend turned the wheel. 2 things were at fault (mind you my k10 is equipped with the same bracket behind and the bracket welded to the front driver spring hanger) 1 the steering gear box had stripped inside causing really bad turning radius and a horrible response until it caught on some splines and that caused it to be intermittent. 2 due to the extra stress from the steering going bad my front axle and the lower separate leaf spring actually shifted back while steering also causing really bad steering. So my advice is double check recheck triple check your "pitman arm" adjustment and insure that your gear box is turning accordingly in relation to the steering column. Just my advice from my experience.
67chevy1series is offline   Reply With Quote
