Old 05-11-2016, 07:02 PM   #51
Andy4639
Old member
Andy4639's Avatar
Lightbulb Re: Transmission temperature Gauge
Per most people it's plumbed before the radiator so in the winter it heats up a little before going into the transmission.
These are readings straight off the ECU through the scan gauge 2 monitor not mechanical gauges.
I have the trans cooler in between the condenser and radiator. I've never seen it more than 200 and that was last spring on a trip to the mountains. It always cooled right back down after pulling a long grade.
Normally it's in the 165-185 temp range. Depending on how hot it is outside.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
