Old 02-18-2015, 11:09 PM   #1
Andy4639
Old member
Andy4639's Avatar
Question Transmission temperature Gauge
Ok,
since the Scan gauge 2 I bought want read the temperature of the transmission I have been looking at kits.
I want to add the temp gauge to my 4L80E. So where do you think the best spot for it would be? Also which kit to get. I have been thinking of this one.
http://www.oreillyauto.com/site/c/de...smission+gauge
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 02-19-2015, 01:21 PM   #2
Hart_Rod
Hart_Rod's Avatar
Re: Transmission temperature Gauge
Doesn't the computer monitor the tranny temp?
Hart_Rod is offline   Reply With Quote
Old 02-19-2015, 02:28 PM   #3
solidaxel
solidaxel's Avatar
My Torque Pro App will read engine and Trans temp
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 02-19-2015, 07:53 PM   #4
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Transmission temperature Gauge
Yes it does if hooked up. I have a stand alone harness and haven't been able to get it to pull it up. I tried all the scan gauge codes but none worked even called. They said it must not be hooked to computer, I found a diagram last night on LS1 site to check it. I hope to get it sometime.I would much rather have it read through the scan gauge than adding a gauge under the dash. Any help would be great on this.
Old 02-19-2015, 08:37 PM   #5
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Hmmm, I have the scangaugeII as well and I most DEFINATELY read my tranny temp. I can't remember, but I believe I had to add the PID to the scangauge to do this.
Try this andy; Go to your scangauge and look at the firmware. Then go to their webpage and go to the "Xgauge" section. If you navigate to the GM area, you can get lists of the PID's and the codes you need to enter to get them to work. If you locate the trans temp ID, you can add it to the XGauge function and watch it on the scangauge.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 02-19-2015, 08:52 PM   #6
Andy4639
Old member
Andy4639's Avatar
Question Re: Transmission temperature Gauge
I have done this several times and it just shows a blank screen on the scan gauge. I think it's the stand alone harness may have the wire not connected. I even called Scan gauge and went through it with them on the phone. Nothing I sure wish I could get it to work though I really don't want to add the extra gauge.
For GM vehicles that use the VPW protocol
Trans Fluid Temperature (Exc Allison) 6C10F1221940(01) 046205190640 3008 00090005FFD8 TFT Degrees Fahrenheit
Allison Trans Fluid Temp (5-Speed) 6C18F1221940(01) 046205190640 3008 00090005FFD8 TFT Degrees Fahrenheit
For GM vehicles that use the CANSF protocol
Trans Fluid Temperature (Exc Allison) 07E0221940(01) 046205190640 3008 00090005FFD8 TFT Degrees Fahrenheit
Allison Trans Fluid Temp (5-Speed) 07E2221940(01) 046205190640 3008 00090005FFD8 TFT Degrees Fahrenheit
Old 02-19-2015, 10:06 PM   #7
clinebarger
Even a swap harness will be wired for the TFT, It is part of trans control.
clinebarger is offline   Reply With Quote
Old 02-19-2015, 10:41 PM   #8
Andy4639
Old member
Andy4639's Avatar
Talking Re: Transmission temperature Gauge
From my understanding not all trans missions have it installed but I maybe wrong. I sure would like to have this if any one knows the codes they use pleas post them and I'll try again.
Can a scanner tool pull the temp reading up. I have a OB2 scan tool.
Old 02-20-2015, 05:12 AM   #9
Andy4639
Old member
Andy4639's Avatar
I've been searching all night for info guy's. Does this look right to you all.
L= temp senor yellow/black goes to red connector of ECU pin #51
M = ground grey wire for 6.0 only, blue connection pin 41 per middle and bottom drawing.
Old 02-20-2015, 01:26 PM   #10
Andy4639
Old member
Andy4639's Avatar
If my info in the other post is correct I have the yellow wire in spot 51 red connection. I don't have the grey in the 41spot in the blue connector. I am also thinking it's a common ground wire though.
Old 02-20-2015, 06:24 PM   #11
ls1nova71
ls1nova71's Avatar
You can't expect the temp sensor to work if the ground isn't there, so that sounds like your problem. Add the wire from M on the trans plug to 41 on the PCM and it should work.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 02-20-2015, 08:34 PM   #12
Andy4639
Old member
Andy4639's Avatar
This is what I was thinking also. I just wanted to hear it from someone else. Now can somebody tell me where to get the wire connectors and how to install them?
Old 02-20-2015, 08:55 PM   #13
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
http://www.wiringproducts.com/genera...ectors-sockets
Old 02-20-2015, 09:24 PM   #14
Andy4639
Old member
Andy4639's Avatar
Cool Re: Transmission temperature Gauge
Couple of local guys have told me they have some old harnesses they can pull a wire off of and give me.
Old 02-21-2015, 12:15 AM   #15
clinebarger
All 4L60E & 4L80E transmissions have a TFT sensor, The 60E TFT is part of the Pressure Switch assembly, The 80E TFT is part of the internal trans harness.
Remove the trans connector & check for a ground at pin M, The harness builder may have grounded the TFT elsewhere.
If no ground is found, You can also "Case Ground" it somewhere, Doesn't necessarily have to be wired to the PCM low reference, A Low Reference is just a PCM supplied low amp "sensor" ground.
A scan tool should show a trans temp reading (Not sure on generic scan tools though)
The odd thing is...Even if the TFT is not grounded, The PCM will read it as -40 degrees because the TFT is not pulling the voltage down on the TFT sensor signal wire with resistance to ground.
The PCM sends out 5-volts on the TFT signal circuit (Pin 51)
The TFT sensor is a resistor (thermistor), which changes value based on temperature. The sensor has a negative temperature coefficient. This means that as the temperature increases, the resistance decreases, and as the temperature decreases the resistance increases. The PCM supplies a 5 volt reference signal to the sensor and measures the voltage drop in the circuit. When the transmission fluid is cold, the sensor resistance is high and the PCM detects high signal voltage. As the fluid temperature warms to a normal operating temperature, the resistance becomes less and the signal voltage decreases. The PCM uses this information to control shift quality and torque converter clutch apply.
If the PCM detects the TFT sensor resistance has no change, or an unrealistic change in a short amount of time, multiple changes within seconds, then DTC P0711 sets.
Conditions for setting DTC P0711.....
•No ISS DTC P0716 or P0717.
•No OSS DTC P0502 or P0503.
•No ECT DTCs P0117 or P0118.
•No component slipping DTC P1870.
•System voltage is 8 - 18 volts.
•The engine is running for greater than 35 seconds.
•The TFT is -40 to +70°F at start up.
•The Engine Coolant Temperature is greater than 185°F.
•ECT has changed at least 99°F since start up.
•The vehicle speed is greater than 5 mph for at least 12.5 minutes.
•The TCC slip speed is greater than 60 RPM for at least 8.3 minutes.
You can monitor voltage on the yellow/black wire at PCM & diagnose the circuit is pretty easy using this chart.
Old 02-21-2015, 07:51 PM   #16
Andy4639
Old member
Andy4639's Avatar
Wink Re: Transmission temperature Gauge
clinebarger,
Thanks for the info. I have been sick since yesterday and haven't felt like doing anything else to the truck. I will check the connector at the transmission and hope I can just ground it there some where without having to run it back to the ECU.
Yes, it being a stand alone harness they could have deleted it.
Old 02-22-2015, 08:21 PM   #17
Andy4639
Old member
Andy4639's Avatar
If he grounded somewhere else it should pick it up on the scan gauge I would think?
Old 02-23-2015, 09:03 AM   #18
Andy4639
Old member
Andy4639's Avatar
OK so now what. The "M" connection has the ground wire in it. Do I tap into it and ground it to the case are do I run a wire to the correct plug on the back of the ECU?
I don't understand why it's not picking it up if it's grounded though.
Here is the connector.
Old 02-23-2015, 09:28 AM   #19
solidaxel
solidaxel's Avatar
Can you check for continuity from the M side of the trans plug to the corresponding pin at the ECU, or have you already completed this?
LS 3 4L70E
Old 02-23-2015, 09:35 AM   #20
Andy4639
Old member
Andy4639's Avatar
Unhappy Re: Transmission temperature Gauge
Nope haven't done that. I just got started.
I don't know where the black wire goes to since it's not in the connection it suppose to be in. It should be in Blue 41 but it's empty.
I would have to tear the whole harness a part to do that which I don't think would be wise.
Old 02-23-2015, 10:01 AM   #21
Andy4639
Old member
Andy4639's Avatar
Lightbulb Re: Transmission temperature Gauge
This are the locations for all the black wires at the ECU. I'll have to take the ECU out again to verify them though.Info here.
http://lt1swap.com/99-02_vortec_pcm.htm
Blue connections.
41 BLK 407 Sensor Ground (Trans) w/Case grounded o2 Sensors
53 BLK 470 Fuel Tank Pressure Sensor Ground
54 BLK 452 TP Sensor Ground
Red connections:
57 BLK 552 IAT Sensor Ground
Old 02-23-2015, 10:08 AM   #22
solidaxel
solidaxel's Avatar
Test all of them.............with the VOM, power OFF, one of them should give you continuity
LS 3 4L70E
Old 02-23-2015, 10:29 AM   #23
ls1nova71
ls1nova71's Avatar
Not positive, but I believe you need to run the sensor ground back to the PCM and not just to ground. Try adding a wire from M to pin 41 and see if it reads. You would only have to do it temporarily to see if it works or not, and if it does, then worry about running the wire a little better.
Old 02-23-2015, 10:42 AM   #24
Andy4639
Old member
Andy4639's Avatar
Tap into the black wire at M and run it to 41 on the ECU right. Leave it as is just tap into it.
I will be taking the ECU back out to try it.
Old 02-23-2015, 11:20 AM   #25
ls1nova71
ls1nova71's Avatar
NO, don't just tap into it, that would just ground the low reference circuit to the PCM. Take the M wire out and run a dedicated single wire between there and pin 41. The pins in the trans connector and the PCM are the same, so if you have two extra ones, they will work in either connector.
