#51 |
Re: partial frame VIN/Cab VIN don't match question
this should have an interesting out come w/ all the comment(s) posted in the thread ..
hope that it ll work for the best =0)
dont want to hear excuses, i want to hear solution(s) |
#52 |
alright here's the scoop from the NC DMV inspector...
cab VIN was valid, not stolen etc. 1986 long wheel base truck frame 1985 short wheel base, and was stolen in 1987, legally recovered, then used to build my truck he confiscated the VIN tag that was on it they will issue 2 new VIN tags, with a NC issued VIN... (with the same number affixed in different spots... one in door jamb, and one under the hood) one will be affixed underhood near the brake master cylinder one will be affixed inside the drivers door jamb on the cab NOT necessary to re-VIN the frame, but those numbers will be on the title record with the new VIN's to tie them all together in one vehicle he said it was good that I had taken it back apart, if the cab or frame was in an active theft case, and the truck was assembled, they would have taken the whole thing. however, since everything was apart, all they would have done was either take the cab or frame by itself if either was an active theft case once they come back in 2 weeks with the VIN's and apply them, then I can go get it re-titled in my name, whilst i wait for the title to come back, it will have to be bonded as proof of ownership until title is in hand once title is in hand with the new VIN's, that's it, all is ok, nothing to worry about anymore so i'm glad i went through the correct procedures, if it would have been found out during a traffic stop, or whatever... it would have been impounded, legal fees, lawyer fees etc. etc. etc. you know the deal... that's about it. inspector suggested getting stuff like this taken care of before you drop a ton of money into it, he's seen guys heartbroken when they tow their **** away, and it takes about a year for the judicial process to get it back FWIW
My build thread... http://67-72chevytrucks.com/vboard/s...d.php?t=515829 Disabled Veteran 82nd Airborne Division Operations: Desert Shield, Desert Storm, and Uphold Democracy Last edited by naphtali5725; 06-02-2015 at 02:43 PM. |
#53 |
Your truck is going to have 2 VINs? That doesn't make sense. Are you gonna have 2 titles?
2018 Audi S5- wife's ride 1980 Chevy Scottsdale http://67-72chevytrucks.com/vboard/s...d.php?t=543511 1981 Chevy Silverado- in pieces 1964 Chevy c10 2017 Jeep Wrangler JKU |
#54 | |
nope just 2 VIN tags, same number affixed in different spots... in door jamb, and under the hood
My build thread... http://67-72chevytrucks.com/vboard/s...d.php?t=515829 Disabled Veteran 82nd Airborne Division Operations: Desert Shield, Desert Storm, and Uphold Democracy |
#55 |
Ok that makes perfect sense. Sorry
#56 |
np, hope all this info helps someone else!
#57 |
Glad it all worked out for you!!!!!!!
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
#58 |
Good information. I had a feeling DMV was going to re vin the truck.
Was the inspector easy to deal with? How much do you think it will cost to bond the truck?
68 4wd Stepside 69 2wd Stepside Project 71 2wd Blazer Project 72 2wd 3/4 Ton Project or Parts? 73 4wd Blazer |
#59 | |
about 100 bucks
#60 | |
I kept forgetting to mention: a Flint built '85 pickup - I probably built that truck (if it came through on second shift). Part of it, anyway... K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
#61 |
Cruzin
Cool, all worked out
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8 Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U Proverbs 3:5,6 "Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt In memory of our first baby daughter, daddy and mommy love you. Danica Grace 6/26/14
#62 | |
#63 |
Post Whore
![]() Join Date: Aug 2014
Should have used better rivets on that darn cab VIN plate and this could have all been avoided, JK
#64 |
That's funny. Keith, you have some explaining to do!
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
#65 |
Glad it worked out for you. I always get nervous with situations like this, since the whole thing is out of our control.
Greg 64 GMC Suburban - 283, NV3500, 14 bolt 77 C10 swb - 292, SM465, 12 bolt |
#66 |
Glad it worked out. I always get a title on a project before I put a dollar in it. Here in CA we can get a title with out registration by putting the vehicle in to non-op status.
I used to do VIN verification work and got to see a lot of projects in different states of repair. I would be nervous about a vehicle and putting money in it with out that piece of paper on my hand.
My Chevy habit is paid for by Ford diesels... Here is my SLOW LS install: http://67-72chevytrucks.com/vboard/s...55#post6456355 Caliper Rebuild: http://67-72chevytrucks.com/vboard/s...d.php?t=613748 Upper Control Arm Bushings: http://67-72chevytrucks.com/vboard/s...d.php?t=616974 IG mattcrp1 |
#67 |
lol
#68 | |
all is well now, hope the info helps others in NC!
#69 |
i believe you worked on the fenders too? something about cross threaded wheel well bolts? LOL
#70 |
me too, i was sweating bullets big time!
#71 |
I know the pieces fit
Congrats, I know you had to be sweating that a little. I would have been.
#72 |
Moderator
![]() Join Date: Oct 2008
That's great news. It had the possibility of going very much the other direction.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
#73 |
yeah man, i'm glad it was all good to go!
#74 |
78K & 79C Jimmys
Glad to hear it all worked out in your favor,
bet it's worth the sweat now to enjoy the breeze later
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
#75 |
DMV inspector called, the new VIN number has been assigned to my truck, and he is supposed to be coming today to affix the 2 new VIN tags...
i'll update and post pics of them when it's done
