05-22-2015, 09:55 AM | #1 |
partial frame VIN/Cab VIN don't match question
CFF395273 stamped twice in two different places on top of passenger side frame rail
my frame VIN and Cab VIN don't match... to top it off... VIN tag has been removed/reattached in the past... have to go thru redtape BS with DMV inspector curious to what the frame went to, cab is an 86 thanks guys
My build thread... http://67-72chevytrucks.com/vboard/s...d.php?t=515829 Disabled Veteran 82nd Airborne Division Operations: Desert Shield, Desert Storm, and Uphold Democracy |
05-22-2015, 10:22 AM | #2 |
Re: partial frame VIN/Cab VIN don't match question
C = Chevrolet
F = 1985 model year F = Flint Assembly plant 395273 = sequential portion of VIN
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
05-22-2015, 10:24 AM | #3 |
Did you purchase the truck in NC? Out of state transactions to NC can be a pain in the rear. Had to do one on my 63 when I purchase it in SC last year. In state....much easier.
I do know when they came out to inspect the truck VINS.....my frame and cab ID had to match.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
05-22-2015, 10:57 AM | #4 |
yeah, i have talked to a DMV inspector, and he's coming to look at it next week... since the VIN's don't match and the VIN tag has been removed/reattached... i hope i'm not in a serious situation... like confiscation.
i do have a clear NC title since i bought/titled it here in NC. i do have the glove box sticker, and the VIN on it matches with the cowl tag
05-22-2015, 02:22 PM | #5 |
if i have the truck in pieces... front clip, cab, bed.. and the frame sitting by itself... rails only, no front crossmember... if something was amiss, would they just take the cab, and or frame rails? or load all of it up (fenders, doors, bed, rear end, suspension etc. etc.)? even though none of it was put together(parts sitting in a garage so to speak)?
05-22-2015, 04:06 PM | #6 |
I don't know personally. But when they came to inspect my latest 63 that was added to the fleet I removed what I could just in case. I don't really know what their protocol is in situations like this.
I see your ex 82nd, are you still in Fayetteville area?
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer Last edited by 1963c-10; 05-22-2015 at 04:15 PM. |
05-22-2015, 04:20 PM | #7 |
Moderator
I don't see how they could justify taking the whole shebang.
This is the gubmint we're talking about tho... Many times they just do things with no justification as long as they figure they will get away with it. You can pretty well guess what the first third of the VIN might be if you have a VIN decoding card for 1985... http://www.73-87chevytrucks.com/tech.../1985truck.pdf There are only 3 digits we don't know. 5, 8, & 9. --There are only 3 reasonable Valid 1/2ton Brake types for VIN Position 5 {C, D, & E} --There are 9 possible stock engine letters for VIN position 8. C,J 6.2L - N 4.3L - F,N 5.0L - K 5.7LPG - L,M 5.7L - W 7.4L --I'm not sure how the check digit VIN Position 9 was generated so that'll add 0-9 for 10 more possible VIN#s to the guess pool. 1GCCx14xxFF395273 It could be a handful of numbers using this as the base known numbers... Some will be invalid. 1GCCC14N3FF395273 is a valid VIN# 1GCCD14N3FF395273 & 1GCCE14N3FF395273 are invalid... Get Carfax or some other VIN check subscription and run the handful you WAG.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
05-22-2015, 07:33 PM | #8 |
what is a WAG?
05-22-2015, 07:35 PM | #9 | |
i'm gonna take mine down to the bare frame, and cab separate... if all is well, won't take much at all to throw it back together
05-22-2015, 07:39 PM | #10 |
05-22-2015, 07:49 PM | #11 |
Moderator
A Wild Guess... This is closer to an edumacated guess.
05-22-2015, 08:00 PM | #12 |
I know the pieces fit
I wouldn't have that motor attached to questionable parts (ie frame) when the inspector shows up. I know its extra work but I'd play it safe.
05-22-2015, 11:51 PM | #13 |
How can they take anything? If you have a title to the cab. What if you bought a frame because the original was damaged?
2018 Audi S5- wife's ride 1980 Chevy Scottsdale http://67-72chevytrucks.com/vboard/s...d.php?t=543511 1981 Chevy Silverado- in pieces 1964 Chevy c10 2017 Jeep Wrangler JKU |
05-23-2015, 12:30 AM | #14 |
Moderator
They can do anything they want. I agree. Make sure the cab and frame are not attached to anything of value.
There are other covert VIN #s on most rigs. I'm not sure where they are on the squares. Some cars have em stamped in the firewall, strut towers, or the radiator support.
05-23-2015, 01:48 AM | #15 |
Post Whore
isn't the number on the engine part of the VIN, I did not catch what engine you have, but if the engine has a number that matches the frame then that should be enuff to register it I think, the cab you can call a replacement part sometimes the VIN plate gets lost during body work of the restoration process
05-23-2015, 02:53 AM | #16 | |
it is what it is LOL
05-23-2015, 06:56 AM | #17 |
As long as both vins come back clean and not stolen i don't think they will take your truck but who knows.It is the goverment they do some screwy things sometimes.
05-23-2015, 07:47 AM | #18 | |
i'm sure it was totaled and they just a bunch of used parts and that VIN to make a complete vehicle. i'm pulling it apart anyway for peace of mind
05-23-2015, 08:42 AM | #19 | |
K
05-23-2015, 09:58 AM | #20 | |
Moderator
If that means what I think it does then I was wrong in my assumption above... There could only be one VIN from the Flint assembly plant with that 6 digit sequential number???? If so I stumbled on it fairly quickly by just looking at the truck and guessing at the three missing digits.
05-23-2015, 11:15 AM | #21 | |
Example: I have in my records a Fremont built '65 GTO: 237375Z123456, and also a Pontiac built '65 GTO 237375P123456. Same sequential portion, different plant code. You are not correct about this truck being the 395,273rd vehicle built. In the first place, it is likely that Flint built Chevrolet nameplated vehicles started at 300001. Secondly, Flint also built GMCs, approximately one out of every nine trucks, which incremented up with their own sequence. So my guess would be 395,273 - 300001 = 95,272 + 10,585 GMCs = 105,857th or so vehicle produced for the 1985 model year. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 05-27-2015 at 10:51 AM. |
05-23-2015, 11:34 AM | #22 |
thnks for the info so far, appreciated...
i guess i'll be updating this thread next week... hopefully all will go well, at least i can share the experience, and post the right process to others here in NC thanks Keith for all the cool info i have the front clip/cab/bed all unbolted, gonna unbolt front crossmember, and the 4 leaf spring bolts and get down to only the frame rails... oh yeah, after i pull the damn engine/tranny stay tuned, wish me luck LOL
05-23-2015, 12:18 PM | #23 | |
Moderator
So there's only one valid VIN ending in FF395273... 1GCCC14N3FF395273 is the only VIN out of 8 I tried with that suffix that showed as valid. It was the first VIN I guessed too... Dang I'm good... That's probably the whole VIN of the truck that was associated with that frame.
05-23-2015, 01:59 PM | #24 |
one other question, the dash panel that the VIN tag is on, that is welded to the windshield area and bolts to each side of the cab. i removed the spot welds, and took out that whole piece, for repair near windshield, and to install my custom aluminum dash... is that considered tampering? LOL or just physically taking the tag rivets out is what constitutes tampering?
05-23-2015, 02:50 PM | #25 |
Y'all have it tough. That stuff doesn't matter in my part of NM. I also have a title clerk at the dealership I work for if it was a problem she'd just handle it for me. We don't have inspectors come out to the vehicle at all.
