07-31-2016, 10:19 AM | #51 |
Re: Cutting 3 cabs up...
Jimmy Hoelzel |
07-31-2016, 04:13 PM | #52 |
Last call on cab cuts... Will be outside finishing up with them. Shoot me a text at 309-231-4082 if ya need something!
Thanks to all of the guys that have bought pieces! Jimmy
Jimmy Hoelzel |
07-31-2016, 04:28 PM | #53 |
thanx Dustmaker65 i found my plate, mine has many coats of paint and i hope i can strip it off . i;ll pass. hang on to it!
07-31-2016, 10:07 PM | #54 |
Roto Reuter thats the name...
Any chance of getting a cut of the lower rear window channel?
~ Dan My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232 My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394 1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt 1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project "Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977 |
08-01-2016, 07:44 AM | #55 | |
Thanks! Jimmy
Jimmy Hoelzel |
08-01-2016, 09:07 AM | #56 | |
Let me know how much and shipping to 14036. Thanks.
08-02-2016, 06:13 PM | #57 |
Here is a pic of one that is solid. It does have a little surface rust, but metal is solid. No problem cutting this off for you, but shipping may be expensive?
Let me know. Jimmy
Jimmy Hoelzel |
08-02-2016, 07:48 PM | #58 |
I might be interested in the door pillars. Would need both sides. A few of my door hinge plates that hide in mine are stripped out. All depends what shipping would be
My Build Thread Here http://67-72chevytrucks.com/vboard/s...d.php?t=457417 |
08-02-2016, 10:04 PM | #59 | |
Thanks, Jimmy
Jimmy Hoelzel |
08-03-2016, 05:59 AM | #60 |
If you have them and it's not too late... I'm looking for solid toe kick panels. Both passenger and driver side. Mine have a bit of rust through on the panel right where it meets the floor.
Thanks! |
08-03-2016, 07:22 AM | #61 |
Are any areas rusted through? Bottom right looks like it might have holes through it. I would need an idea of price with shipping before I can say. Otherwise if its too expensive I'll have to pass.
08-04-2016, 05:35 PM | #62 |
Got it today. Thanks Jimmy
08-04-2016, 10:41 PM | #63 |
I'm looking for the drivers side A-pillar, mainly where the lower hinge bolts to...if it isn't too late. Can get pics of what I need.
08-05-2016, 01:01 AM | #64 | ||||
Thank You! Quote:
Jimmy Hoelzel |
08-05-2016, 09:54 PM | #65 |
08-06-2016, 07:59 PM | #66 | ||
Door pillars are all rotted. Sorry.
Jimmy Hoelzel |
08-06-2016, 08:01 PM | #67 |
Ok, thanks for looking.
08-10-2016, 10:57 PM | #68 |
I'm looking for driver side door retainer arm that comes out of the cab to keep door from opening up all the way. mine broke off my 1965 C10
08-11-2016, 09:32 AM | #69 |
Are you looking for the top hinge? I am not sure what you are wanting. You have a pic?
Jimmy Hoelzel |
08-12-2016, 08:47 AM | #70 |
I'm looking for the piece that comes out of the cab.
08-12-2016, 09:41 AM | #71 |
Sorry, mine are totally different than yours.
Jimmy Hoelzel |
08-12-2016, 05:04 PM | #72 |
Dustmaker, I know you said earlier in the thread that the floors are pretty gone, but just checking on this - I would like a low hump with enough "meat" around it so that I can bolt it into where a high hump was. I have one that I purchased from a board member but when I went to test fit it last night, I would need to weld sheet metal onto it to make it fit.
Do any of the cabs you have left have good sheet metal in this area that could be cut out? I could send you some pics and dimensions if needed. |
10-07-2016, 08:12 PM | #73 |
I need both rh and lh back window frame corners 2 inches wide, 6 inches up and 6 inches in, inner and outer.
10-07-2016, 08:45 PM | #74 |
Sorry...all the cabs are gone.
Jimmy Hoelzel |
