Old 07-28-2016, 09:36 AM   #1
Dustmaker65
Dustmaker65's Avatar
Cutting 3 cabs up...
I am cutting 3 cabs up this weekend. There is no titles to these. There is lots of good metal left. One has a really nice firewall, I just don't know how to cut it out to be able to reuse it. So I will cut pieces out of too. I will get pics up later today or tomorrow.
I also have a 1969 GMC LWB chassis that will get cut up to be hauled away...
Thanks!
Jimmy
Jimmy Hoelzel
Dustmaker65 is offline   Reply With Quote
Old 07-28-2016, 10:15 AM   #2
rlfletc
Re: Cutting 3 cabs up...
Looking for the jamb tag below the vin.
rlfletc is offline   Reply With Quote
Old 07-28-2016, 01:46 PM   #3
Dustmaker65
2 of the cabs are GMC's...not sure if the other has any tags on it.
I will check tonight.
Thanks!
Jimmy
Jimmy Hoelzel
Old 07-28-2016, 05:58 PM   #4
57larry
how's the floors?
57larry is offline   Reply With Quote
Old 07-28-2016, 06:11 PM   #5
michael bustamante
michael bustamante's Avatar
looking for good kick panals, both sides and the floor on the driver side foot area
1967custom
michael bustamante is offline   Reply With Quote
Old 07-28-2016, 06:20 PM   #6
Dustmaker65
This what your looking for?
Jimmy Hoelzel
Old 07-28-2016, 06:24 PM   #7
Dustmaker65
Originally Posted by 57larry View Post
how's the floors?
Sorry Larry, most of the floors are gone.
I have a cab that has perfect kick panels, but I am not sure how to remove them?
Jimmy Hoelzel
Old 07-28-2016, 06:32 PM   #8
michael bustamante
wow is thst a hornets nest?? i need all that floor too thats in the pic all the way to the seat mount riser.
you could just sawz all it all off in one piece
1967custom
Old 07-28-2016, 06:39 PM   #9
Dustmaker65
LOL...just insulation hanging down. How many inches of floor pan? And how do I ship these?
Jimmy Hoelzel
Old 07-28-2016, 07:11 PM   #10
Bennett68C10
Bennett68C10's Avatar
Interested in one of the firewall sections under the heater box and up to the wiring gutter just above heater box. Some pics of where mine is rotted for reference.
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 07-28-2016, 07:14 PM   #11
Bennett68C10
Also need some patches for the lower front windshield channel on both sides. Thanks.
Keith
66 Suburban
IG: bennett68c10
Old 07-28-2016, 07:19 PM   #12
Dustmaker65
Hi Kieth. One of the cabs has a perfect firewall... Just wasn't sure how to remove it in one piece. And how is the best way to ship?
Jimmy Hoelzel
Old 07-28-2016, 07:29 PM   #13
Bennett68C10
Jimmy, I probably only need about a 15x15 section of the firewall where the heater box is! A cutoff wheel or sawzall would make quick work of it if you don't mind cutting it up. I think ups or fed ex would be fine for shipping. On the lower window channels, I would need about a 8" section on each side of the cab where the factory seem is.
Keith
66 Suburban
IG: bennett68c10
Old 07-28-2016, 07:50 PM   #14
Dustmaker65
Don't mind cutting any of it up at this point. I just need to make sure I can ship the pieces. I only have one that has the bottom of the windshield intact. I will go get a couple pics.
Jimmy Hoelzel
Old 07-29-2016, 06:29 AM   #15
Bennett68C10
Thanks Jimmy, let me know!
Keith
66 Suburban
IG: bennett68c10
Old 07-29-2016, 09:16 AM   #16
gmc 2500 4x4
what year and what do the gmc tags look like? i could use a bottom one
gmc 2500 4x4 is offline   Reply With Quote
Old 07-29-2016, 09:26 AM   #17
Dustmaker65
Not sure there are any on these cabs that I have left. I will check tonight when I get home and let you know.
Thanks!
Jimmy
Jimmy Hoelzel
Old 07-29-2016, 09:31 AM   #18
gmc 2500 4x4
thanx
Old 07-29-2016, 12:28 PM   #19
michael bustamante
im thinking the floor about 8 inches in (towards the gas pedal) and all the way to the where the floor has that vertical hump under the bench seat right in front of the seat. if you have a cell that gets pics ill send you a pic of what im looking for.
505-907-6836
1967custom
Old 07-29-2016, 01:01 PM   #20
Dustmaker65
505-907-6836
Yep...text me at 309-231-4082
Jimmy Hoelzel
Old 07-29-2016, 01:27 PM   #21
michael bustamante
ok ill do that when i get offa work
1967custom
Old 07-29-2016, 01:58 PM   #22
6T7NCHVYC10
6T7NCHVYC10's Avatar
Could I get a cut of the gas fill hole. Mine was welded shut, and not very good. I would like to get it to look original again. Could also use a cut of the filler neck and a cap if you have that. Thanks
6T7NCHVYC10 is offline   Reply With Quote
Old 07-29-2016, 02:09 PM   #23
Dustmaker65
I will see what I have, some have been welded up already. I know I dont have any spare tanks or caps.
Jimmy Hoelzel
Old 07-29-2016, 02:14 PM   #24
6T7NCHVYC10
Thank you
Old 07-29-2016, 03:33 PM   #25
wahl4m
need a cut around the heel of the gas pedal area say 8" right .left ,up & back of the 2 ball sockets of the gas pedal area ! anything good there in a cab ?
wahl4m is offline   Reply With Quote
