01-29-2019, 07:44 PM | #51 |
Re: Is 5.3 swap to much money and work?
Funny to see this thread. With my 69 I am at the point that it's time to replace the wore out 350. I have considered a LS swap and did do the research however with what I have to change and price another 350 will be going back in. I will say what has already been said it does depend on what you want from your truck.
I can say personally I like the good ole sbc. I have seen many LS swapped trucks and only a handful have I really liked as they were done looking more like the engine that was in it originally.
1985 C10 shortbed, current project. Member of the Upstate SC GM Truck Club. Last edited by 72LB; 01-29-2019 at 08:38 PM. |
01-29-2019, 08:14 PM | #52 | |
Running in place gets you nowhere fast. -me 1968 GTO 4-spd covnvertible 1970 K-20 4-speed, factory AC. |
01-29-2019, 08:18 PM | #53 |
Nobody is trying to convince you of anything,what I’m saying is the LS isn’t something everyone wants or needs. Seen enough LS swaps to know they are the real deal when you want to build a junkyard engine with a eBay turbo and click off some 9 second et. Not everyone cares about that though. And an Sbc can do it all day long as well if you’re willing to build it.
01-29-2019, 08:41 PM | #54 |
You know I'm always the last one on a bus, but I still want on. I'll take the LM7 off your hands, dirt cheap that is cause its overdone, and let you get back to your roots. Just being a smart a.. don't mind me
2003 Dodge 2500 1969 C10 2014 Camaro SS/RS/1LE |
01-29-2019, 09:39 PM | #55 |
I have since sold my bronze/white 72 that had a bad engine ( kept it and it has since been rebuilt and installed back in the 72 ) and found a used zz3/700r4 to replace the 350/350 which made the truck much better to drive. My 1985 gmc had a 305/700r4 and a buddy of mine and myself finished a 5.7 ls1/4l60e used of course, which which was twice the cost and then some of the 72 swap. However, it is a night and day difference in drivability, twist the key and it fires right up and it runs as smooth as butter!! But once you go ls and do a really nice install job, I have found there is never a reason to have an old school carburetor again.
01-29-2019, 09:56 PM | #56 | |
With these systems available today, even old school hardware can be brought to the level of "twist the key and it fires right up and it runs as smooth as butter!!" -klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
01-29-2019, 10:17 PM | #57 |
I had a time deciding which route to go also. I knew when I saw the thread title this was going to be a hot topic that I think has been debated 100 times before. It seems like it’s one of those questions when people ask what’s better, Ford or Chevy, etc. Each obviously has pros and cons.
I still have the old 327 out back and it’s original to the truck. I’ll probably rebuild it just for fun once I have the truck on the road with the ls in it. I know very little about both engines as all this stuff is new to me but engine tech is not. I have a little knowledge mechanically and a pretty good eye for detail. I chose the ls because I got the entire truck for a fair deal, and that gave me a complete platform for a donor. I wanted the beauty of the original truck (one of the best looking pickups ever imo) and the convenience of the newer power plant. In addition to that, because LS Swaps are so common, there are a TON of suppliers for swap parts, conversion kits, etc. Also, threads and knowledge abound about the engine itself. If you want the engine pretty, there are plenty of options there also. I see some they make look more like an older engine, relocated the coils, add vintage looking valve covers and more. Really, it seems the options are limitless. Just depends how much you want to spend. On the other side of the spectrum, you can usually grab a 150k mile engine, do nothing to it, swap it in and go for another 100k. I’ve read plenty of those stories also. Another reason I went with the ls is I can have all the power I want. Slap a turbo kit on and make a minimum of 550 whp on minimal boost. I’ve read the stock junkyard engine has been proven to handle 700 hp in stock form. I decided to do the heads, complete engine rebuild, gap the rings, upgraded valve springs, valve seals, engine cam, cam chain tensioner, new bearings, polished crank, new push rods, new rings, bead hone cylinders, melling oil pump, Siemens injectors, arp rod bolts, arp head bolts, and I think it cost me about 1500. Not bad, I thought. I went a bit overboard just because I usually do, but I know what’s in there and it’s absolutely spotless. It’s not for everyone but I wanted something just a touch more flashy than Chevy orange. I like how it looks so far. I think it will look pretty nice in the cleaned-up engine bay. Last edited by Slowguy; 01-29-2019 at 10:37 PM. |
01-30-2019, 02:22 AM | #58 | |
Post Whore
01-30-2019, 09:21 AM | #59 | |
But to the OP question again. If you don't have an engine LS is almost a no brainer. If you want to show it and care what the engine looks like, maybe old school is better-maybe. But I happen to like the way an LS looks over an orange carbed small (or big) block. But if you want to drive it, if you want mileage, if you want reliability; then an LS swap is a great way to do that. Dollar for dollar you will be hard pressed to beat an LS swap for power. A complete bone stock small block rebuild done right will be $2500 or better with doing the heads right and build the carb etc. You can buy the LS engine AND transmission for less than that. A performance build can easily double that. But, there is no universal wrong or right answer. You have to figure out what is right for you.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
01-30-2019, 11:19 AM | #60 |
What about the benefits after the swap? Once you get all the auxiliaries taken care of such as fuel tank, fuel pump, exhaust, motor mounts, ECM, etc. done right you shouldn’t have to mess with them. So let’s say you wear out your gen1 sbc...likely you will replace it with an L31 costing around 2k just for the long block. If you need to replace an LS in a truck that is already set up for it you go to the junk yard and put in another 100k mile 5.3. Just thinking about the looong game.
Posted via Mobile Device |
01-30-2019, 04:08 PM | #61 | |
Each to his own, boys, but my engine does everything I have ever asked of it, and its failures have been a question of service parts.
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt. |
01-30-2019, 04:10 PM | #62 |
A mystery engine/tranny out of a junkyard, maybe, but not a fresh set ready to go.
01-30-2019, 06:07 PM | #63 | |
You can buy a new basic crate 350 for less than you can rebuild it-if you do it right. And have better heads and less leaky. Again, I'm not against gen 1 small-blocks. I have 2 running. But the OP question is an LS swap worth it, I say yes.
02-01-2019, 10:18 AM | #64 |
I did an LQ9 6.0 swap from a slightly cammed and fuel injected 350 with 60909 Edelbrock heads. The Edelbrock EZ Street fuel injection was a nightmare and never ran right...so no good example to compare performance from.....but the swap did produce a very smooth running truck with plenty of power from a rock-solid stock engine....(and a $4k paperweight unless I can sell the heads and cam\intake)
I paid about $2.5k for the swap with all the necessary hardware and tune, and $1800 for the motor with 74k on the clock Last edited by Signkutter; 02-01-2019 at 10:25 AM. |
02-01-2019, 10:31 AM | #65 |
I have a mid-mileage 99 5.7 sitting out back I'll be pulling when the weather's better. Don't know what I'll do with it but an employee smashed the van so I have yet another engine to add to the collection that I have nothing to do with!
02-01-2019, 07:36 PM | #66 |
I have been following this thread and I think LS or gen 1 depends on preference. I have seen some really nice engine compartments for both. I was thinking I would go with a gen1 on my build just because I am not sure if I could figure out how to get an LS connected up. I have heard the wiring can be complicated. It might be a good option for me dollar wise since I need a motor and all the manifolds, alternator, accessory drives,etc. I can get an LS with everything at a reasonable price. How easy is it to get the harness connected?
02-01-2019, 08:22 PM | #67 | |
All about them K’s
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 |
02-01-2019, 11:52 PM | #68 |
Thanks for the info. That does not sound as bad as I was expecting. That gives me something to consider.
02-04-2019, 08:54 AM | #69 |
I have a combination of old school small blocks and LS engines. Each has its place but after driving with LS power that’s all I am doing in future builds or replacement stuff.
They work so good and the driving experience is awesome. Here are a few pictures for you to see what I have in my trucks.
HSRACER Slammed 53 5 window Blown/Bagged 54 Pickup Patinaed 67 LS stepside Supercharged 67 Nova Bagged 69 Suburban Turbo'ed 5.3 LS Last edited by HSRACER; 02-04-2019 at 09:00 AM. |
02-04-2019, 04:05 PM | #70 |
Not hard to find around here, at least.. and for decent prices!
1970 Chevy C-10 Stepside My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=528167 |
02-04-2019, 08:48 PM | #71 |
FWIW I went through this and there is no right answer, best answer is it depends.
I have a very nice 93 Suburban so I have TBI. 230K on the engine and still runs great. Uses about a quart every 3K miles. If it were not or the rod knock before oil pressure builds I wouldn't do anything. I looked at all the options. LS is interesting and i would like to do the swap. But since I want to tow with it I didn't want to go smaller so I really wanted to 6.0. Installation is much more work, a lot more work. All the adapting and wiring. Then as a buddy who has done 3 conversions pointed out they can nickel and dime you death. All the little things you don't foresee. When I totalled up the cost and even going low on the unexpected it came out to 3,000-3,500 if no major surprises. That is a used engine I know nothing about. I can buy the L31 engine which comes with roller cam, one piece rear main and it is a new engine, not rebuilt and with a warranty for $1,800. Install is so much easier. I want to keep the TBI so there is a little extra work there. But all the accessories, wiring, ect work. So labor is much less. Weighting the cost, extra work and it just didn't make sense. Sure it is cool to have an LS but I just don't see the gain being anywhere near worth the extra effort and cost for me. |
02-05-2019, 11:32 PM | #72 |
Roto Reuter thats the name...
There is no right or wrong answer here. I was torn with making the same decision. It all depends on what you plan to do with your truck and if going LS makes sense for your use. You could justify it either way. The bottom line is what YOU want to do.
I have a friend with a 64 Chevelle who was kicking around the idea of doing a LS swap. In the end he said it just didn't make sense for him. His car has an older Edelbrock crate engine, but it's dialed in so nice and runs great. Why would he want to change it? His case may not be like others, since his engine is running so strong it doesn't make sense. Good luck with your decision.
~ Dan My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232 My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394 1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt 1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project "Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977 |
