Old 01-24-2025, 12:56 AM   #51
Kalums
Re: 71 GMC engine swap-arino
Anyone know the "tall" Acdelco water pump part # all the websites Ive tried keep telling me it is supposed to be "short" but my current one has a 2 belt pulley and 3 on the crank.. maybe had a smog air pump at one point... Idk, thanks in advance.
Also will there be a problem in the TBI 350 with the back 2 water ports in the head being blocked by the Intake manifold? I don't see a crossover in any of the rear parts of a Carb intake (I think because of the HEI) ideas?
Kalums is offline   Reply With Quote
Old 01-24-2025, 10:09 AM   #52
MARKDTN
Need a photo of your current water pump installed. Delco 252-595 is a square body long pump so pulleys should be easy to source.
I don't see any issues with blocking those back ports with the intake. The Q-jet intakes used on those longblocks in the last carbureted Caprices only cross in the front.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 01-24-2025, 11:33 AM   #53
Kalums
Ask and ye shall receive
Old 01-24-2025, 04:14 PM   #54
MARKDTN
Looks like a short pump to me? 3rd groove is for A/C.
https://67-72chevytrucks.com/vboard/...d.php?t=729685
See post 19
'83 K20-TPI
'73 C10
'14 Suburban-DD
Old 01-24-2025, 04:20 PM   #55
Kalums
See post 19
I thought the long shaft pump was roughly 7 inches from the mating surface(block) to the fan mounting surface... That is what mine is... You tell me *shrugs*
Old 01-24-2025, 05:13 PM   #56
MARKDTN
Short water pump is almost touching the timing cover and the lower pulley is flat.
Long water pump there is a roughly 1" gap to the timing cover and the lower pulley has an offset away from the balancer.
I would agree that the upper pulley looks odd for a short pump, perhaps there is a spacer between the pump and pulley?
Also I have never seen a factory LH alternator mount for a long pump.
'83 K20-TPI
'73 C10
'14 Suburban-DD
Old 01-24-2025, 05:21 PM   #57
Kalums
This is why it got the name "Frankie" it was Frankensteined by one or more previous owners... *facepalm* I will check the gap in a minute thx for that info
Old 01-24-2025, 05:36 PM   #58
weq92f
weq92f's Avatar
If you go with that salvage yard serpentine system posted earlier, you can do away with that pancake compressor with these brackets. They allow using a robust Sanden 508 compressor in its place...
https://www.dirtydingo.com/shop/prod...oducts_id=1622
These brackets only work on the small block, GM aluminum serpentine system.
-Kevin
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 01-24-2025, 05:42 PM   #59
Kalums
-Kevin
Nice! Thank you for the link.
Old 01-24-2025, 05:58 PM   #60
Kalums
So here is what I got... The current pump is literally touching the timing cover.. And the block to pump distance is 1" almost exactly. Where the new 252-595 "long" pump is 1.5" leg length roughly but the fan has about a 3" gap between the fan and radiator and hangs out of the shroud by about 1/2-3/4". I'm wondering if it was a Frankensteined rebuilt WP... that bubba's cousin rebuilt as a "favor". The over all height is only off by what looks like 1/16"...*shrugs* Also for some reason I just noticed I have a 2 belt on the WP and a 2 belt on the crank with a gap where the "2nd" belt for A/C would normally be.
Old 01-24-2025, 06:17 PM   #61
Kalums
Not going to lie... This is becoming a headache.... *facepalm*
Old 01-24-2025, 10:22 PM   #62
slikside
slikside's Avatar
Hang in there, man. Step away, take a break, come back with fresh eyes and thoughts.
You'll get r dun!
1972 Chevy C-10, SWB, Fleet, 350/350, PS, PB, HEI, mostly stock, Survivor.
slikside is offline   Reply With Quote
Old 01-24-2025, 10:30 PM   #63
Kalums
You'll get r dun!
Thank you for the encouragement, took me two months to firgure out the rear axle and drum brakes... I know there are ppl on here who have been wrenching on one truck for years. I was just hoping to have this swap done by early February... But it isn't looking like that is going to happen... *sighs* Every one in here is being amazing help, don't get me wrong, I just don't understand why ppl(the previous owners) do such hack job bull. I've always been of the mindset do it right and do your best, the first time.
Old 01-25-2025, 04:08 AM   #64
Kalums
I really appreciate those of you who are helping me out and answering all my incessant questions... Well it turns out I have no idea where/ how I measured the existing water pump... Apparently I may have been 90% asleep *facepalm* I went back and measured everything one more time... I do have a short shaft pump currently. All of the other observations I was making about the fan, the fan cowl and radiator... Is because all of those items had shifted and were not where they belonged. The radiator wasn't even in the bottom channel/brackets which pushed the bottom of everything else sideways and back... The whole setup was twisted kinda like a potato chip... But it wasn't noticeable from the topside(unless you were actively looking for it). Either way new measurements are exact for a short shaft, and I will be getting a 3 belt crank pulley for the new engine so eventually I can slap a vintage air system in this originally non-air conditioned truck. Oh and the long pump goes back in the morning.
Old 01-25-2025, 10:46 AM   #65
Kalums
Anyone know the "short" ACdelco water pump part number? I keep getting 252-581 but alot of sites say it is a "reverse rotation".... Not sure if that means counter clockwise rotation or reverse flow? I'm so confused
Old 01-25-2025, 11:35 AM   #66
Steeveedee
Ram-A-Lam-A-Ding-Dong
Steeveedee's Avatar
You might want to go with the serpentine system at this time, because it has a reverse rotation water pump. You'll have to replace whatever pump is on the engine when you make the change over.
~Steven
Simi Valley, CA
Steeveedee is offline   Reply With Quote
Old 01-25-2025, 12:21 PM   #67
Kalums
I want to... But the cost is killing me, to swap to serpentine would cost at least 325 for the brackets + a new Alternator +either an A/C compressor or the pulley to go in it's place... Which the $$$ varies widely... So I want to but... The cost is crazy. Where if I just put the V-belt system back on for now I can get it running and save for the serpentine and/or Vintage air system.
Old 01-26-2025, 12:43 AM   #68
Kalums
No real updates today lubed up the rocker arms, push rods, springs, lifters/seats, cam to distributor worm gear, timing chain and the few cam lobes I can get at from the engine valley with a hand oiler full of assembly lube. Pretty much any thing I know that moves during engine operation and could get to with the spout of the hand oiler. Other than that had to send back the amazon intake, it had no markings on it anywhere and it was supposed to an Edelbrock 2104...what I got was a square bore... They are supposed to exchange it, we will see how that plays out. But most of the day was spent with the minion.
Old 01-26-2025, 11:32 AM   #69
jaros44sr
jaros44sr's Avatar
Have you checked the metalergies of the distributor gear and the camshaft pretty sure reman people would have figured that out
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 01-26-2025, 12:27 PM   #70
Kalums
Not exactly sure what you are referring to the "metalergies"? If you are asking if the 2 mesh they seem to well, I've got an MSD "Flamethrower" HEI, but I'm going to swap over all The stock GM/Delco internals from my old distributor. I got it "open box" and only wanted the main shaft/stem. Oh and they both appear to be black oxide coated metal?
Old 01-27-2025, 08:54 AM   #71
MARKDTN
Flat Tappet cam should be fine with your original distributor gear.
It looks to me like you have all the pulleys and brackets for a/c except the compressor and I would swap to a Sanden compressor anyway.
You don't need a reverse rotating water pump unless you go to a serpentine system. 252-581 appears to be the correct Delco p/n for a 67-72 (and earlier) SB water pump. Can buy from Amazon or Rock Auto
'83 K20-TPI
'73 C10
'14 Suburban-DD
Old 01-27-2025, 09:00 AM   #72
Kalums
Awesome thank you. I'm probably just going to do that, slap it all back together and run it till either I can't stand the heat or I get the 2k+ for the vintage air system.
Old 01-28-2025, 12:32 AM   #73
Kalums
So... I found a Cardone reman power steering box for my truck today for $12... I really couldn't pass that up even if it only lasts a few years. According to Cardone it should have the 3.25 lock to lock ratio, so that will be an improvement on the 900 turns I currently have *laughs* mine isn't currently leaking g or making noise (since I flushed it not too long ago). But I figured I might as well for $12. Only thing that stinks is they charged me $70 for a core!?!? I'm not really enthusiastic about taking. My current one off till the engine swap... I've been looking around for a garbage one but even the trashed/thrashed ones ppl want "big" money for... *facepalm* might end up being an $82 dollar steering box.
Update!! Found a junk steering box for $5 on OfferUp... Score!! Got my $70 core - $5 = 65 back *thumbs up*
Old 01-28-2025, 10:42 PM   #74
Kalums
So while perusing OfferUp I found a guy with S10 "parts" including the serpentine brackets he wanted $100 and it came with the R4 compressor (not gonna keep it, besides the clutch is shot and it's been sitting in the weather for who knows how long) and all idler pullies crank pulley and power steering pump and pulley... Now for the negative, no hardware(bolts) and the power steering pulley looks like the guy tried to take it off with a "BFH".
Does anyone have a list of the bolts I need? And where they go, please. It came with the 3 bolts for the compressor and bolts that hold on the idler pullies, but nothing else. Nothing to mount it to the block and nothing for the power steering pump. And yes my new block does have the correct holes in the head and block. Thank you in advance.
Old 01-29-2025, 10:23 AM   #75
MARKDTN
Guy on Ebay has a set of bolts for $29
https://www.ebay.com/itm/26570646780...EaAvkJEALw_wcB
Looks like mostly 3/8-16 stuff that you can get at the hardware store. The lower pulley to balancer is 3/8-24 x 1" I believe. I would just use what you have on your truck or order new in a kit.
'83 K20-TPI
'73 C10
'14 Suburban-DD
