#51 |
![]() Join Date: Feb 2002
Re: My Own Vice Grip Garage - Getting the 250 i6 Running Again
Pertronix insists you use their proprietary Flamethrower coil with their Ignitor modules.
Ignitor - Flamethrower Ignitor II - Flamethower II Ignitor III - Flamethrower III
#52 | |
![]() Join Date: Jul 2000
Pertronix sometimes gets a bad rap, but I understand that many module failures are due to using a coil with the wrong resistance.
Mike 1969 Custom/10 LWB -- owned for 37 years. 350/TH350, 3.08 posi, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. Hedman stainless headers. Old Air installation in progress. 1982 Custom Deluxe 10 SWB -- converted from 250-six to roller cam 350 w/ Vortec heads -- sold 1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it! 1969 C10 (not the current one) which I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 26 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
#53 | |
![]() ![]() Join Date: Feb 2009
I could be mistaken, as I remember it vacuum at the highest point with some consideration for how it's running, so it's not stalling or starved for lack of better experience, rather so it's not running like I've never done it but plan to, and will link to page.
Tony 1971 C10 Custom Deluxe SWB 402/400TH A/C I developed an assembly information kit for restoring my truck from nuts and bolts. It's written in Assy. order, short & simple, packed with all OEM hardware ID; castings; part ID; 100s of part numbers; wiring simple - Resource, and trivial too. Much info. applies to all 67-72 GM, A/C vehicles, esp. trucks W/O saying. Full search ability, including to 700+ images of illus., parts, charts, Assy., points of interest, cab, bed, & front clip cart plans- Specials and cores were serviced out and R excluded e.g. front/rear glass, body/paint, engine core, rebuilt hinges, steering box, trans, etc. The project was in-line with long former professions developing process, policy, specs, demo, written for novices, admin., policy, engineers, development, systems & test - Public & govt 2, gross. Sell soft copy cheaply, PM if interested.Build thread:https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
#54 | |
Lost all respect for Pertronix. Genuine GM HEI is better and parts are available everywhere.
#55 |
![]() Join Date: Jun 2022
This is pretty thorough, starting with dwell and timing(as it should)
You can skip to about 25:00 for the vacuum gauge tuning https://www.youtube.com/watch?v=TPX6n-5ETxo&t=754s
1970 C10 Custom longbed 350/350 “Carburetors are forgiving, timing is not” — Thunderhead289 Last edited by Rust_never_sleeps; 09-18-2025 at 02:04 PM. |
#56 | |
The MSD module in my 69 truck has to be at least 20 years old. Of course, that means only around 20K miles, if that. As for Pertronix, a guy I used to work for part time has a muscle car & hot rod shop. He swears by their stuff. Also, a friend of mine just bought two module/coil sets for Ford 302 engines in his two cars. Guess we'll see how they work out.
#57 | |
After the inventor sold out, the company expanded their range to Ignitor II and III. The II having coil boost above 3000 RPM, with no Key ON burn out, and the III being a sort of multi spark discharge. I once bought an MSD red HEI distributor cap for a tune up. The inside 8 contacts were too big, and it clacked while running. Poor QA has steered me away from that brand. On my '71 GMC Jimmy K/1500 w/350 V8 and HEI, I had several module failures until I swapped in a 12SI Alternator with internal Voltage Regulator. Spikes from the EVR were killing the modules. On my '68 C/10 Stepside w/292 L6 and HEI, I had several ''lifetime warranty'' EVRs fail me, until I cannibalized one from my dormant '67 K/10 Suburban. It was from 9/98, a Borg/Warner regulator from when they were quality built. Much of the aftermarket replacement parts are placebo quality. They look right and vintage, but they were never meant for real world road duty. Manufacturers do not take our vintage seriously anymore. They are considered toys, garage queens, and towed car show ponies. Add in the Chinese-ium factor and corporate greed and you have disaster.
#58 | ||
#59 | |
Corporate Greed is the primary function of private equity.
#60 | |
Then again, their business plan might be to reduce personnel and raise prices (and profits) until customers simply vanish. We've seen literally 50%-100% price increases in Holley products since Covid. Even with inflation in check, they are still jacking up prices. A carb I was looking at earlier in the year cost $440, on sale for $390-something. It's now $500. Do you know of anyone who is making 50%-100% higher income than 5-6 years ago? For me in retirement it's more like 15%-20%
#61 |
I'm 75. I can't afford to retire. Friends who did retire, died. No pension from my small local union.
Things are bad all over. I'm lucky most of my '67/'72 treasures, I collected early. Before we descend further down a rabbit hole and things turn political, I think we should get back on topic about tuning up an L6 with points. With all due respect.
#62 |
Gas tank ready to go in
I need to decide whether upgrade to the 3/8” lines now, or just keep the 5/16” as is.
1969 C10 Shortbed |
#63 |
double post *
1969 C10 Shortbed |
#64 |
![]() Join Date: Dec 2009
In my opinion.
![]() I would go with 3/8 fuel line.
________________________________________________________________________________________ ____________________________________________ The early bird gets the worm, But the second mouse gets the cheese 85 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
#65 |
From what I understand the i6 and 2bbl 350 had 5/16” (what my truck has)
350 4bbl had the 3/8”… going to this larger line means I’d need to buy some of the 3/8” hardline. It would save me some work when I eventually go LS swap
1969 C10 Shortbed |
#66 |
Ram-A-Lam-A-Ding-Dong
![]() Join Date: Jan 2013
If your LS swap includes fuel injection, you'd be wasting your time on fuel lines at this time.
#67 |
That’s right, fuel injection is high pressure, requiring different lines (and a return)?
1969 C10 Shortbed |
#68 |
Also, does anyone have any recommendation on how to test a sending unit good or bad before installation?
1969 C10 Shortbed |
#69 | |
Shoud be 0 Ohms when empty/down and 90 Ohms(or whatever yours is spec'd for) when full/up
1970 C10 Custom longbed 350/350 “Carburetors are forgiving, timing is not” — Thunderhead289 |
#70 |
Perfect, thank you!
1969 C10 Shortbed |
#71 |
Mine was a 307 2bbl from the factory with a 5/16" line. I've never felt a fuel starvation problem with its current 350 4bbl, or even a 383 that I'd occasionally rev to 5500 RPM. Sustained high RPMs might be a different story. FWIW, my fuel pump to filter to carb is 3/8".
But if things are torn apart and easy to access, I'd go with 3/8" and use a sender with a second nipple in case you ever need a return line for EFI. Is that correct, guys?
Mike 1969 Custom/10 LWB -- owned for 37 years. 350/TH350, 3.08 posi, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. Hedman stainless headers. Old Air installation in progress. 1982 Custom Deluxe 10 SWB -- converted from 250-six to roller cam 350 w/ Vortec heads -- sold 1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it! 1969 C10 (not the current one) which I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 26 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! Last edited by MikeB; 02-01-2026 at 12:59 PM. |
#72 |
Today I had some time with the distributor. I took off the cap, rotated the little 250 engine by hand to the high spot and measured the points gap using my trusty feeler gauges.
0.007” (my understanding is that 0.019” is the spec). When the points contacts wear, doesn’t the gap open up? Any theories as to why the gap was so small? Anyway, I took a points file to the contacts and reset the gap to 0.019” but now I’m wondering if I should just replace the points… I also have a Blue Streak condenser sitting in my tool box. From what I recall, one full crank rotation is half a rotation of the distributor. So the points would open three times with one rotation of the crank, I think. Let me know what you guys think. Luke
1969 C10 Shortbed Last edited by Luke87gt; 11-16-2025 at 03:20 AM. |
#73 | |
#74 |
Thank you for the reply.
Im reading that the points rubbing block wears down over time as the distributor cam rubs against it (that’s why distributor cam lube is recommended). So it would make sense that the gap may get smaller over time. Interesting that the truck was able to start and drive into my garage off the trailer at that gap (even though it was sputtering, dying, shutting off). Not to mention other ignition parts in terrible shape, like the rotor. Also, what distributor cam lube do you guys recommend?
1969 C10 Shortbed Last edited by Luke87gt; 11-16-2025 at 11:07 AM. |
#75 |
![]() Join Date: Jun 2005
I used a Pertronix Ignitor, not sure which series, for years with a stock/stock replacement coil, with no issues, in a 250.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Sliding Rear Window Power Windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
| Bookmarks |
