My Own Vice Grip Garage - Getting the 250 i6 Running Again
Hi guys, some of you may be aware that I acquired a ‘69 c10 last year (250 i6, 3OTT). The truck sat for years with the previous owner before he decided to list it for sale. It was shipped from Washington to California and was able to get onto the trailer and off the trailer under its own power, but barely.
Since then, life happened and believe it or not I actually haven’t started it since it was driven into the garage last year. Today I finally managed to remove the Rochester MonoJet carb for rebuild. It looks pretty rough as you can see from the pics. Being new to carbs, I’m hoping you may be able to help me identify several parts of this carb. I’ve numbered the pictures for reference: #1: what is this screw? It can’t be the idle screw as that’s on the back of the carb. Anyone know what it does? #2: what is this capped vacuum line? Am I correct to assume that when I do power brake conversion, this is the vacuum port I will utilize for that upgrade? #3: this port was connected to the vacuum advance. By the way, should I replace the vacuum advance? Do these have a wear out and go bad? #4: what in the world is this? It looks to be a plate with 3 holes and it swivels. However, it wasn’t attached to anything. I wonder if that’s right or if I’m missing some connection? By the way, one of the two nuts that holds the carb to the manifold was finger tight. That can’t be good :-) Beyond the carb, I have a set of new plugs, wires, coil, cap, rotor, condenser, points, and fuel filter. I am about to order a new gas tank and replacement lines. I’ll get those items replaced, crank it, and see where we are. I hope to utilize this as a progress thread to get this engine running again (I hope). At some point I’ll ask for help with verifying timing, checking vacuum, and setting points. Big thank you guys for the help!
1969 C10 Shortbed |
Ram-A-Lam-A-Ding-Dong
![]() Join Date: Jan 2013
Re: My Own Vice Grip Garage - Getting the 250 i6 Running Again
Not all parts in pic are on your carb.
https://www.carburetor-parts.com/mon...g1ElE4Y6XI5Her
#1 Idle Mixture screw. Not idle speed screw.
#2 Could have been available for some option such as auto trans. power brakes generally use a much bigger hose. Square head, tapered thread plug in manifold at very bottom, center of first image would be good for P. brake. #3 Vacuum advance diaphragms do go bad and leak. Apply vacuum to test. #4 High speed idle cam. Part of your manual choke. It may be missing a choke rod.
'67 GMC 2500, 292, 4spd, AC Last edited by RichardJ; 07-06-2025 at 10:25 AM. |
Here's a link to Mike's carburetor parts. It has good photos and descriptions of the choke system. Shows the missing linkage from your #4.
https://www.carburetor-parts.com/Mon...Tsm2VC1pqOgehf
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
Great information, thank you all. Mike’s carbs looks to be a great resource, wow.
This total carb newbie now knows where his idle mixture screw is and that his carb apparently is missing a choke rod (fast idle). I’ll be sure to get that during the carb rebuild. Question: what’s the procedure for setting the idle speed and the mixture? My understanding is that you warm up the engine with the choke engaged, then set idle speed, then tune the mixture to the sweet spot. Any tips on that? Thank you Luke
1969 C10 Shortbed |
#6 | |
![]() Join Date: Jul 2000
Mike 1969 Custom/10 LWB -- owned for 37 years. 350/TH350, 3.08 posi, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. Hedman stainless headers. Old Air installation in progress. 1982 Custom Deluxe 10 SWB -- converted from 250-six to roller cam 350 w/ Vortec heads -- sold 1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it! 1969 C10 (not the current one) which I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 26 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
Very good summary.
I assume this procedure only applies once timing has been set and confirmed stable vacuum?
1969 C10 Shortbed |
#8 | |
![]() Join Date: Jun 2005
(CCW) until the vacuum reaches it's highest point. You will have to reset the idle speed screw after this is done. Don't forget, disconnect the vacuum advance and plug the port on the carb while setting the initial timing.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Sliding Rear Window Power Windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
Nice! I am in to follow this thread since I too have an old i6 that I will attempt to revive. Good luck!
Builds: Green Gus the 68 C10 | Bluey the 72 1500 | Lowly the 70 C10 | Oscar the 70 C10 - C10 Concept/Development Photos: Master Thread |
I debated rebuilding the carb myself but given that I’ve never done that before and I’m trying to get this old engine running, I decided to send the carb out to CarburatorUSA in New Jersey. Should have it back in a couple weeks.
1969 C10 Shortbed |
Do you do any kind of model building, such as scale plastic or some such? You'd be able to rebuild that carb, if so. That monojet is dead simple, as is a Quadrajet, believe it or not. I'm really a 2-pound hammer kind of guy, but even I can rebuild a Q-Jet carb and make it work properly.
![]() Join Date: Jun 2022
Gotta pick your battles if you want to stay on schedule
1970 C10 Custom longbed 350/350 “Carburetors are forgiving, timing is not” — Thunderhead289 |
#13 |
Thank you for the encouragement.
Given that this engine is tired and needs no shortage of help, I want to take the carb out of the equation and leave it to a pro this time. Next time, I will rebuild it!
1969 C10 Shortbed |
#14 | |
Be sure to send us pictures and tell us how well it works.
#15 |
Carb shop called and said that the carb was in really bad shape but looking new and back in transit to me.
When I replace the spark plugs, should I give the spark plug holes a spray of any oil since the car been sitting for so long? If so, what oil and amount is advisable?
1969 C10 Shortbed |
#16 |
Definitely share pics of the rebuilt carb when it gets back to you.
#17 |
I'd just make sure the oil looks good on the dipstick. I guess spraying some kind of lubricant into each cylinder would help, but I don't know what to suggest.
#18 |
>>carb was in really bad shape but looking new<<
Not sure what that is supposed to mean. Be conscious, that rebuilt carbs ARE NOT PLUG-N-PLAY . You still have to adjust the mixture screw. You still have to adjust the idle speed. You still have to adjust the choke cable so that you have full choke on-off and check that high speed idle works properly. Bench adjustments on a carb only go so far. It then has to be adjusted for your engine, running and warmed up. >>give the spark plug holes a spray of any oil<< If the plugs are already out, what is that supposed to do. If the plugs were really carboned up or hard to get out you probably should run a plug thread chaser. Aluminum heads call for Anti-Seize compound, but that is controversial. Be sure you have the correct plug type. Some heads use tapered plugs and earlier have gasketed plugs. Various reasons why you could have the wrong ones, so it doesn't hurt to check. For reference - https://67-72chevytrucks.com/vboard/...t=tapered+plug
'67 GMC 2500, 292, 4spd, AC |
#19 |
Are you asking if you should lube the spark plug threads or cylinders?
Mike 1969 Custom/10 LWB -- owned for 37 years. 350/TH350, 3.08 posi, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. Hedman stainless headers. Old Air installation in progress. 1982 Custom Deluxe 10 SWB -- converted from 250-six to roller cam 350 w/ Vortec heads -- sold 1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it! 1969 C10 (not the current one) which I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 26 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! Last edited by MikeB; 09-17-2025 at 10:50 AM. |
#20 |
Cylinders
Sorry for not being clear.
1969 C10 Shortbed |
#21 |
Here are some pics of the rebuilt Monojet.
Thing looks new, will install it soon. After that replacing the tank, sending unit, and lines…
1969 C10 Shortbed |
#22 |
Nice plating job! May it extend to the operation, thereof.
#23 |
Thank you sir, let’s hope
Still have the plugs, wires, coil, cap, rotor, and points to replace. Just not sure what the health is of the engine itself yet. The truck did get off the trailer and into the garage on its own power, but barely… I guess that’s promising right?
1969 C10 Shortbed |
#24 |
What was it, 3 weeks turn time on the carb? Seems pretty good
#25 |
Just over 2wks
1969 C10 Shortbed |
| Bookmarks |
