#751 |
Sofa King Crazy!!
Re: 1967 C10 Custom Big Window
You found the Tater. ![]() My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650 My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650 67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS. ![]() 1972 2wd Blazer "Porterbuilt and Sloshed" ![]() |
#752 |
Sofa King Crazy!!
A little fun with my B-day present, a camera. Too bad I couldn't get them larger on here.
#753 |
well first i wanna know somthin did you drive it out or did you roll it out
#754 |
Junior Member
Wow! Looks great man. How's that landscaping business coming along? I've been thinking of doing something like that. Just see too many people getting into the biz and making $$$.
#755 |
![]() Join Date: Nov 2008
The camera, the right angles and the right truck....Perfect combo!
Now, Put that hood on!!....Sweet truck bro! |
#756 |
HAPPY BELATED B-DAY BUD. happy birthday to you, happy birthday to you, happy birthday to David. happy birthday to you, and many moooooooore!
Anyways, what kind of camera did you get? me curious I like cameras. Also the truck is jsut stunning, you are so hitting my Jealous bone with this truck. That is just one SLICK looking truck. LOL, had to use a pun. oh well, she is slowly getting there, but at least she is getting done right!
James 1968 GMC "HAVOC" 1986 GMC "Frank" J.J.R.H. Design & Consulting My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300 A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238 1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361 Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390 Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100 1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587 |
#757 | ||||
Sofa King Crazy!!
#758 |
Sofa King Crazy!!
Finally.....a hood!!!! Here are some pics!!! Give me some feedback on getting the back of the hood down.....maybe new springs???
You found the Tater. ![]() My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650 My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650 67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS. ![]() 1972 2wd Blazer "Porterbuilt and Sloshed" ![]() Last edited by Slick67; 07-23-2010 at 10:26 PM. |
#759 |
GEARHEAD
From what I have read here before, loosen the rear bolts of the hood hinges. Then lift the hood and push it up as far as you can, then tighten the bolts (takes 2 people). Hope it works for you.
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 ![]() 72 ![]() HG's Plow Truck '78 ![]() Bigass Farm Truck HG's thread of miscellaneous stuff |
#760 |
Sofa King Crazy!!
Thanks bro, but we tried it but it didn't go down enough to close the gap at the cowl. Maybe time to call the bodyman back for some quick help!
#761 |
VA72C10
![]() Join Date: Mar 2008
Looks good. Did you paint the hinges? Could be paint binding them from going all the way down....
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#762 |
VA72C10
Oh, and as far as pic size....put them on photobucket and they're much larger...
#763 |
Sofa King Crazy!!
Thanks VA. The hinges were painted about 7 years ago by my buddy. I have not thought of that but there is a chance that could be it! I'll check it.
#764 |
well put thetailgate in and THE OUTSIDE IS DONE
#765 |
truck is looking awesome keep plugging away!
"The way it is" truck build http://67-72chevytrucks.com/vboard/s...d.php?t=359200 ![]() |
#766 |
Under Construction
Nice progress David....... Truck is Bad@$$
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
#767 |
man looks nice even with the hood not lining up it still looks awesome
#768 |
Damn this thing is just Beautiful.
69 c-10 BBC ![]() 462ci, forged crank, H-beam rods, 10.5-1 KB forged pistons, Dart Iron Eagle 308cc, Straub Cam, Comp Cams chrome moly full rollers, Weiand Team G, Prosystems 950, TH400/3500 Dalenzie stall, Currie 9+ Detroit Locker w/31spline axles. ![]() |
#769 |
VA72C10
hey, quick ????
Got my antenna installed today in the cowl but don't see the hole for the grommet....do you remember where it's located since you just installed that mac daddy antenna??? ![]()
#770 |
did your truck have a antenna from the factory or dealership if not then you will need to drill a hole but if you did then it should be there i would take the cowl panel off and put it all the way you want it then bolt the cowl back on
#771 | |
VA72C10
#772 |
Ya might remove the springs and then see if you can get it aligned, but I'm thinkin and from experience yur hinges are worn out You can find good used ones, cant vouch for repops tho.
#773 | |
http://www.tandscustomcars.com/ ![]() IT"S GOT A ROOF NOW WHOO HOO!!!! ![]() 65 GTO Build (If you wanna check it out) ![]() |
#774 |
DO NOT USE REPRO HOOD HINGES! They will fold up due to thin metal and damage your hood and fenders. GMpartsdirect.com has Original GM Hood hinges, so they are probably still available from a local GM dealer (special order, I'm sure). GMpartsdirect shows the parts numbers and prices like below:
LH Hood Hinge 3911705 $66.64 RH Hood Hinge 3911706 $45.46
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build Last edited by smbrouss70; 07-27-2010 at 11:55 AM. |
#775 | |
Tags |
1967, custom, lwb |
