#8051 |
Re: What did you do to your truck today!
Wiring can be fun at times.
1987 Green n Green machine. 5.0 4spd std. 7" lift w 35's. |
#8052 |
![]() Join Date: Jun 2012
Taped off and painted my new to me wheel covers for my 72
United States Marine Corps 2000-2011 Iraq and Afghanistan veteran Just living life now and enjoying it and my wife, daughter and son ![]() Last edited by tommys72; 10-02-2013 at 02:44 PM. |
#8053 |
Looking good...
62 Willys 4wd Pickup : 72 C-10 swb 504 stroker ![]() |
#8054 |
I appreciate it... that was alot of tape and time, and they are still 10 footers
United States Marine Corps 2000-2011 Iraq and Afghanistan veteran Just living life now and enjoying it and my wife, daughter and son ![]() |
#8055 |
Cluster King
![]() Join Date: Nov 2012
They look really good Tom. Do you need any of the fake lugs? I have some for you here. Let me know and I will mail them to you.
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com I am also a dealer for Counterpart for gauge cluster parts only. Also see my facebook page, CG&C |
#8056 |
Got my new Lokar floor shifter installed after having to repair the mess on the floorboards from the PO. Installed new reverse light switch, replaced broken antenna, replaced broken speedo cable, fixed horn button and popped in some turn signal cancel springs. Was actually on sunday, but spent the entire day working on the beast..haha
Chris Mead Tattoos |
#8057 |
#8058 |
Installed a new steering wheel and found out that the steering wheel shaft and nut are all but stripped out.
71 swb 350/4sp manual 5/7 static drop |
#8059 |
![]() Join Date: Sep 2013
Looks Great Tow Strap !
Hope, Faith and Strength
**Deestrong** |
#8060 |
Started putting it back together..
![]() Posted via Mobile Device
Shawn 68 chevy K/20 05 chevy 3/4 4x4 71 short step-sold ![]() 71 chevy Beauville van My build. http://67-72chevytrucks.com/vboard/s...d.php?t=633039 |
#8061 |
I got into a minor chingaso and wound up with a broken windshield , I need to find a L.A. Metro area glass shop that'll know how to replace it ~ All Star Glass in GaRDENA TOOK ON THE JOB THEN CALLED ME BACK AND SAID they're too incompetent and cancelled the job .
A little help please .
-Nate Geezer '49 3100 235 W/ Muncie SM420 SOLD '69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH ![]() |
#8062 | |
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
#8063 |
![]() Join Date: May 2012
if ya'll remember several months ago ole dollor went through a bad storm and got some paint damage on the hood, top , and left side, well I got it sanded down and am in the process of repainting the hood , top and left side, got some painted yesterday and will do more today, hope it all turns out good. I will try and post some pics later.
#8064 | |
RAT1968 '68 Cab/'71 Parts
How about some "before", "during", and "after"? Like while you were doing the first paint.
M17 Coarsegold, CA RAT's shiny now. But always a rat. |
#8065 |
a lot of the pic's of the first paint job should be on here, and I posted the damage of the storm. my computer crashed so I will have to look and see if I still have them some where, I will get the new ones some time later, maybe today. I will try and get some of the old and new if that's possible. still need to cut and buff the new paint, so it all will match once I am finished....
#8066 |
Made two inch lowering blocks and dropped the rear down. I like the stance now and even the traction seems to have improved
#8067 |
I have been disappointed with the power and fuel mileage with my 72 Cheyenne Super. I have only recently bought it. I like all cars/truck but I have been into Fords a long time. I really couldn't understand why this 350 was such a pooch. I know it's about 4,000 lbs. and only a 3.07:1 rear gear but come on! Then I calculated my gas mileage yesterday and it was 7.4 mpg! So I decided something had to be wrong. The PO had converted it to HEI and I put a Holley 600 vacuum secondary on it because the quadrajet was long gone when I bought it. Today I decided to check the timing. First, I noticed that the timing didn't change with the vacuum line unplugged, so I got the vacuum gauge out and had 18 inches at idle. So my vacuum advance does not work. Then I checked initial timing and it was about 7 degrees BTDC. I revved it and it didn't change. I pulled the cap and rotor and saw right away the weights were so sloppy that one was kind of on top of the other so they couldn't move. I jiggled them enough to get them freed up. Put it back together. Set initial timing at 12, winged the throttle and it went off the scale (I don't have a timing light with a dial). So I took it for a drive. WOW
married to TARA, that makes me the TARA-fied1 Last edited by tarafied1; 10-03-2013 at 08:53 PM. Reason: add details |
#8068 |
Nice work! Most folks overlook the basics, looks like you nailed it.
#8069 |
thanks, I must admit I often over think things too. The truck had been sitting in a field for a while so I was expecting a lot of things to be wrong. So far nothing major.
married to TARA, that makes me the TARA-fied1 |
#8070 | |
I have an extra windshield you can have. Dano
![]() ![]() It ain't yours, if you didn't build it! |
#8071 |
![]() Join Date: Feb 2011
Got my brake light troubles sorted out....now on to replacing the trailing arms
#8072 |
Towstrap that is awesome! Love orange!
Heat pressure washed my frame, engine, and tranny yesterday before the snowstorm hit. High pressure steam is a great asset.
1988 1 ton 3+3 custom delux Coming soon(stroked 496) TH400, NP205 14 bolt rear, 60 front 4.56 gears, 6 inch lift 35inch dynapro MTs, pro comp 52 16x8 2.5 backspace |
#8073 |
Thanx Guys ;
I now have two places to call . The glass I broke was new Grrr..... I don't want a used one Dano , thank you all the same ! you've been a real lifesaver .
#8074 |
Fixed the right front parking light, witch wasn't coming on when I pulled the headlight switch, just for the parking light. I had to ground the light housing, and that's all it took. All lights work as they should.....
#8075 |
Ordered my flip kit
