08-08-2016, 01:43 PM | #826 |
Re: A 15 year old's project. Rusty 62 stepside
02
08-08-2016, 01:43 PM | #827 |
03
Nik...................____ 62 lwb c10 step-side 261 5 spd .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ my build thread. Sending unit solution |
08-08-2016, 03:22 PM | #828 |
Engine looks great.
Craig 1966 Chevrolet C10 - Supercharged LS3 1968 Chevrolet Camaro 1957 Chevrolet 2dr Hardtop "It makes sence if you don't think about it" Mesquite 1966 C10 - LS3 W/ Air Ride http://67-72chevytrucks.com/vboard/s...=1#post4989763 |
08-08-2016, 05:48 PM | #829 |
All the little details are looking good together. Now you can scare the deer with your spotlight so you don't hit them.
08-08-2016, 05:53 PM | #830 |
I always say, "It don't matter what the truck looks like long as you have a perrty engine." lol Looks great man! And spot lights rock! I have been able to pick up 2 so far. One a GM and the other an S6 universal.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
08-09-2016, 01:48 AM | #831 | |
Thanks Craig, took a lot of work to get it this nice
Thanks tj, your sure right about a Pertty engine! This spotlight is a unity s6 almost identical to the factory 60-63 spotlight, just a little earlier.
08-10-2016, 03:03 AM | #832 |
Spent some time disassembling and polishing the spotlight and boy does she ever shine now! Chrome came out way better than I ever would've thought
08-10-2016, 05:19 AM | #833 |
Very nice.
08-10-2016, 06:22 AM | #834 | |
I have one as well. Desperately want it on my truck but in two minds about cutting a hole in my cab. Probably will fit it though.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE. |
08-10-2016, 09:30 AM | #835 |
08-11-2016, 12:44 AM | #836 | |
Thanks bill
08-14-2016, 02:56 AM | #837 |
Well after contemplating about the motor mounts for a while an I decided after all to adapt the front mount to the new crossmember. So the first step was to take a bunch of measurements and then grind and drill out all the rivets to remove the perch from the crossmember, this was quite the chore but I finally got them all out. Next I will finish the last lower control arm so I can begin the crossmember swap.
08-14-2016, 02:56 AM | #838 |
And the perch
08-20-2016, 03:49 PM | #839 |
Engine is just about all buttoned up, I painted and reinstalled all the little odds and ends, she's looking good! Also ran some other lines
08-20-2016, 04:07 PM | #840 |
Can't wait to see that thing start up, great work.
08-20-2016, 05:28 PM | #841 |
08-20-2016, 10:24 PM | #842 |
Thanks, Neither can I
08-21-2016, 10:40 AM | #843 |
Awesome job Nik! Your motor is looking great How's the motor mounts and front end coming?
08-21-2016, 04:08 PM | #844 |
Thanks Anthony, in one of my past posts I mentioned that I decided to adapt the front mount to the new crossmember after all since it would be a lot less work than building side mounts from scratch. Now all I need to do is track down a rubber motor mount as mine has a large chunk missing and they are not reproduced. I'm actually in the kootney's right now and I have a couple leads on some
08-22-2016, 12:33 AM | #845 |
Looking great dude!
08-22-2016, 09:37 PM | #846 |
Been a while since Ive been on here man, its came a long ways, looking good!
http://67-72chevytrucks.com/vboard/s...d.php?t=698214 my '62 build |
08-23-2016, 10:05 AM | #847 |
Thanks a lot guys!
08-26-2016, 12:16 AM | #848 |
While on my ten day fishing trip I picked up this wilwood 3/4" clutch master cylinder, this is the same one that captainfab uses for his kit
08-29-2016, 05:22 PM | #849 |
While passing through the middle of nowhere in northern B.C. I was able to track down and purchase a 60-62 v8 Bellhousing with the v8 horseshoe and other stuff for $75, this is just in case I ever decide to go with a v8 in the future, since these Bellhousings are hard to find and it was a good deal I couldn't pass it up. Oh and I have been searching while on the road but still haven't found a motor mount
09-05-2016, 09:59 PM | #850 |
I've been pretty busy and lacking in updates recently but this weekend I decided to take advantage of the picknpull half priced sale. I got a set of springs from a half ton to cut down one coil ( my donor 78 had 3/4 ton springs), and a 8" brake booster from a s10, this is because my bigger booster from the 78 wouldn't fit in the engine bay with the oilbath aircleaner.
