#76 |
Re: Who has Impala SS rear disc brakes ??
I think one of the biggest issues with the Cad setups,(aside from core charges) is the constant need to apply the e-brake to keep the calipers adjusted. I think all the pieced together setups have some issue though, some people can't get over no e-brake on the Impala ones.
Chris 74 Custom Deluxe SWB 350/350/3.73’s 99 2wd Silverado RCSB 5.3/4L60/3.90’s http://www.classictrucks.com/feature...short_bed.html |
#77 |
![]() Join Date: Jul 2006
My other thought was this: Integral drum emergency brake?
Don't most of the newer vehicle (at least GM) that have rear disc brakes and use a drum brake as an e-brake have the same axle flange bolt diameter as the old 12-bolts...that was my other thought but the rotors for that kind of setup are substantially more expensive.
Project Family Values Build Thread Vehicles/Projects: -1971 C10 SWB Fleetside! Gathering parts now, will begin frame-off resto soon... Pleasure in the job puts perfection in the work. -Aristotle |
#78 |
I'm in the process of installing the impala rear dics on mine. I got the brackets from Glock35ipsc. I think the caddy calipers are old school. Newer style impala ss calipers fit like a glove. I haven't used an emergency brake yet so I don't see the need for one with an auto. Most of the time the e-brake doesn't work anyway. Glock35ipsc has put alot of time into these brackets and it shows they look like a factory install.
#79 | |
#80 |
Next project: 1970 K10
![]() Hehe, thanks guys! ![]()
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
#81 |
Straight jacket required
To keep this fresh, here are the dimensions for Caprice caliper mounting plate.~
1968 C10 Short Stepper 350/350 A/C P/S P/B Front disc 3/5 static/ 12bolt rear 3:73 1979 Pontiac Trans Am 10th Anniversary/455/4spd 2011 H-D Street Glide - CAMMED n lowered Dad always said,"Son, if you can't be good...be good at it." ![]() |
#82 |
I got my cores yeeehaaaaaa!!http://cgi.ebay.com/ebaymotors/Impal...spagenameZWDVW
#83 |
Can this be done on 1973-1987s?
Thanks Shane |
#84 |
#85 |
Wonder wow good this would work with hydroboost
![]() Shane |
#86 |
What thickness does the mounting plate need to be?
#87 |
#88 |
www.car-part.com for your rear calipers
#89 |
OK so I need to get impala ss rotors and camaro calipers if I want the e-brake. Will the deminsions in #86 work for the camaro calipers as well?
#90 | |
#91 |
I agree new is the way to go with brakes. I just need to know if the bracket listed in #86 will work with the camaro brackets before I pay a buddy to make them.
#92 |
Well if you are going to powdercoat them like I am going to do it would be dumb to buy a new set and have to take them apart. I will rebuild them when I get them powdercoated. I don't much care for the finish on the new ones. Thanks for the info though.
#93 |
How much are ya'll paying for the cores and the new ones?
#94 |
The cores can be up to $90 each from what I have seen. I think the least amount for a core I found was about $45 if I remember right. The brackets in #86 are only for the impala ss calipers.
#95 |
What year Impala rotors? Are these 5-on-5 if not can they be redrilled to 5-on-5? What year Camaro Calipers?With Impala rotors and Camaro calipers will I have to modify my axle shafts?
Thanks Shane |
#96 |
Just to chime in here. For you guys looking to add the internal drum parking brake on the disk swap, I have seen on more than a few occasions that if you do not use or apply the brake very often the internalls(shoes and clips) rot and fails. They are in a confined space but not protected to well. I have had them fall apart when replacing the brakes on more than one truck. I also find the drum surface is shoot. I wiould tend to agree that if you wan a parking brake I would go with the Camaro or Caddy setup. It's much easier to swap out a caliper than the rotors and all the drum hardware. my 3 cents
#97 | |
As for the parking brake, No need for it as I can see. Majority of the time they don't work anyway. Last edited by Ram-Man; 12-23-2006 at 09:50 AM. |
#98 |
Here is how my calipers looked after I powder coated them. I may go back and do them black, I can't decide if I like the chrome.
#99 |
In my 20+ yrs of driving, I've only used the emergency brake in an emergency situation twice...... I shudder to think what would have happened those 2 times w/o one.
#100 |
jkade, those look nice. Here are what your brackets look like if you got them from glock.
