Old 11-22-2005, 08:09 PM   #1
mcmlxix
Collector of Projects
mcmlxix's Avatar
Who has Impala SS rear disc brakes ??
I remember seeing pics on the board, but I can't remember who did this.. .. I tried a search but come up with nothing .... Looking for info on brackets and installation... (and lots of pictires) . . . . . . .
Rich
1972 K5 Blazer CST Click HERE
Old 11-22-2005, 08:17 PM   #2
raggedjim
raggedjim's Avatar
Re: Who has Impala SS rear disc brakes ??
This is the only one I remember, hope it's right.
Rg
http://67-72chevytrucks.com/vboard/s...d.php?t=108923
raggedjim is offline   Reply With Quote
Old 11-22-2005, 09:38 PM   #3
mcmlxix
mcmlxix's Avatar
Those are the pics I remember.... I am addeng them to this post... I will PM 383 Stroker to find out more details... Here's a quote from his original post."There mid 90's Impala caliper and rotor with a custom made backing plate."
Rich
Old 11-22-2005, 10:25 PM   #4
Longstep70
Junior Member
Are those calipers the same PBR calipers found on Camaros and Corvettes?
Longstep70 is offline   Reply With Quote
Old 11-23-2005, 03:08 AM   #5
roj2323
i'm very interested in hearing more about this "custom backing plate" as i'd rather use the ss calipers rather than the wimpy s-10 ones.
ondrew
roj2323 is offline   Reply With Quote
Old 11-23-2005, 08:17 AM   #6
mcmlxix
mcmlxix's Avatar
According to CarPArts.com the corvette and the camaro have a different part number then the Impala SS ... Now this is not 100% but it would lead me to believe that they are different...
Rich
Old 11-23-2005, 11:24 AM   #7
383 Stroker
383 Stroker's Avatar
Here are some pictures of the backing plate I made. I also attached a drawing of the bracket with specs. This setup does not have a E-Brake because it's built into the stock backing plate. If you want a E-brake you can use the Camaro caliper as it has the E-Brake built into it.
Video's of my Truck Racing
1967 C-10, 383ci Sbc, TH350, 3200 stall, 3.73 gear
383 Stroker is offline   Reply With Quote
Old 11-23-2005, 12:53 PM   #8
beaterC10
Did you have to modify the the axles or discs? What master cylinder are you using. It seems like most of the braking action with the stock brakes is in the front. Is there a noticeable difference in braking with the rear discs.
beaterC10 is offline   Reply With Quote
Old 11-23-2005, 01:14 PM   #9
roj2323
thank you for the extreemly valuble information. i will be using it.
ondrew
Old 12-02-2005, 04:45 PM   #10
roj2323
well i'm working on it. there will be a slight delay since my rear end is completly disassembled but when i get these working properly i will explore the idea of selling them to the board.
ondrew
Old 12-02-2005, 07:09 PM   #11
mcmlxix
mcmlxix's Avatar
Is this bracket going to make it possible to use the E-brake?
Rich
Old 12-02-2005, 08:50 PM   #12
383 Stroker
No, I didn't have to modify the axles or discs. I'm using a stock 71-72 master cylinder. It stops a lot quicker with the rear disc. It makes a huge difference when slowing down from high speeds. I have front disc also, so the truck stops good. It's a night and day difference from the 4 wheel drums that came on the truck.
Old 12-02-2005, 08:54 PM   #13
383 Stroker
I've had a few people PM me about what master cylinder I'm running, so I will post some pictures of it.
Old 12-02-2005, 10:18 PM   #14
FormerMember
Using a line lock for the parking brake?
The impala caliper brackets look like they will fit an old school 10B. I want a mechanical parking brake.
Yours is a 12B, right?
FormerMember is offline   Reply With Quote
Old 12-02-2005, 10:55 PM   #15
383 Stroker
No, I use the line lock for burnouts at the drag strip. Yes I have a 12 bolt rearend. I have no need for a parking brake.
Old 12-02-2005, 11:34 PM   #16
383 Stroker
Here's what I use my line lock for. Burnout Video
Old 12-03-2005, 12:24 AM   #17
screamin_c102
screamin_c102's Avatar
OK, thats just wrong.....
wheres the rest of the video?
I wanted to see you stomp that S10s ass :lol
screamin_c102 is offline   Reply With Quote
Old 12-03-2005, 11:36 AM   #18
383 Stroker
Here's the rest of the video. Racing S10 Video
Old 12-03-2005, 11:47 AM   #19
Inthuwind
Straight jacket required
Inthuwind's Avatar
JESUS!!!! I could watch those ALL day--Awesome!!
1968 C10 Short Stepper
350/350 A/C P/S P/B Front disc
3/5 static/ 12bolt rear 3:73
1979 Pontiac Trans Am
10th Anniversary/455/4spd
2011 H-D Street Glide - CAMMED n lowered
Dad always said,"Son, if you can't be good...be good at it."
Inthuwind is offline   Reply With Quote
Old 12-03-2005, 01:49 PM   #20
chopped 71
I used camaro calipers and caprice on two of my trucks the swap was easy. [IMG][/IMG]
chopped 71 is offline   Reply With Quote
Old 12-03-2005, 02:34 PM   #21
chevyguy_72
Vintage Evil
chevyguy_72's Avatar
Are the caddy calipers the only one that have an ebrake?
chevyguy_72 is offline   Reply With Quote
Old 12-03-2005, 08:14 PM   #22
FirstGen
Just Don't Stop!
FirstGen's Avatar
What year camaro calipers are these from and what thickness is the caliper?
Thanks.
1968 C10 build in process
TT LSA/6L90e/9"
FirstGen is offline   Reply With Quote
Old 12-03-2005, 08:53 PM   #23
chopped 71
The Caliper Is From A 96 Camaro And A Rotor From A Caprice.i Don't Know What Thickness Your Looking For On The Calipers
Old 12-09-2005, 04:11 PM   #24
beaterC10
Do have any dimensions or sketches for those brackets? One is for Camaro calipers, the other is for Impala calipers?
Old 06-06-2006, 11:29 PM   #25
Inthuwind
Inthuwind's Avatar
TTT--need dimensions if possible of both brackets
