Old 12-13-2006, 01:23 PM   #76
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Re: Can you please post pics of your lowered '67-72?
[QUOTE=71see10;1940402]2 1/2 drop spindles
5" drop rear springs
Gives a more level look!!!
I love pictures!!
What size rubber you running on this truck, the tires look pretty stout!!
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 12-13-2006, 01:47 PM   #77
boraxman
Keepin an eye out
boraxman's Avatar
3-5 spring drop, 15x8.5 wheels with 3.75"BS 275-60-15 rear 255-60-15 front tires.
1970 Chevy C10 SWB 5.3
1996 Toyota Tacoma SR5 4x4
2007 Vespa GTS 250 Scooter
ZIP 91351
boraxman is offline   Reply With Quote
Old 12-13-2006, 02:37 PM   #78
Rokcrln
Rokcrln's Avatar
It is body dropped 2" , 3" drop spindles, bagged front and rear, rear frame stepped 2" and notched 2+", bed floor raised 6", mini tubbed 7" I think. 17" ralleys with 335/35/17(26") out back and 245/40/17's (24")in front. I will be going to a 27" in front and 29"-30" or so out back.
The tilt hood pic is the curent state of the body soon to be completed. I just fired up the vett LT1 last night for the first time so we are moving ahead little by little!
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 12-13-2006, 03:53 PM   #79
1lowdiesel
1lowdiesel's Avatar
kevin is that it fully laid out?
1lowdiesel is offline   Reply With Quote
Old 12-13-2006, 04:52 PM   #80
71tahoe
71tahoe's Avatar
My son's before paint, then wreck, then start over. 2.5 spindles and bagged 4 corners. 225/60/15 on 8.5 wide centerlines.
71tahoe is offline   Reply With Quote
Old 12-13-2006, 08:56 PM   #81
71see10
Worthless
71see10's Avatar
[QUOTE=Already Gone;1942622]
Originally Posted by 71see10 View Post
2 1/2 drop spindles
I love pictures!!
They are 255/70r15, there a little taller than I like ,but are new and until the funds are right for new wheels gonna run them bald if I have to!!
71see10 is offline   Reply With Quote
Old 12-13-2006, 10:15 PM   #82
gringoloco
A guy with a truck
gringoloco's Avatar
Damn, this thread is almost five years old!
My pair of hellions:
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 12-13-2006, 10:42 PM   #83
bagged70
here is my body mockup and frame
bagged70 is offline   Reply With Quote
Old 12-13-2006, 10:43 PM   #84
Rokcrln
Rokcrln's Avatar
Almost, the front arms are on the ground but the rear would have needed a bigger notch to lay this low once I go with larger tires. Right now the rear plate sits on the ground but it is hitting the frame at the same time.
Kevin
LFD Inc.
Old 12-13-2006, 10:50 PM   #85
Hart_Rod
Hart_Rod's Avatar
My 69 Burb.
Hart_Rod is offline   Reply With Quote
Old 12-14-2006, 03:25 AM   #86
Kenneth_CS87
Originally Posted by steveo10 View Post
heres my bedless beast if anyone has a solid pass. side bedside around indiana let me know.
sorry for the huge pic
Any more pics of the setup? Are you running a 4 link?
Kenneth_CS87 is offline   Reply With Quote
Old 12-14-2006, 02:32 PM   #87
steveo10
steveo10's Avatar
yea its a super lift 4 link from suicide doors. heres some more pics before i put my panhard bar on.
steveo10 is offline   Reply With Quote
Old 12-14-2006, 02:52 PM   #88
el curioso
el curioso's Avatar
Do you have any aired up pics??
1969 Chevy C-10 350/700r4
el curioso is offline   Reply With Quote
Old 12-20-2006, 11:03 PM   #89
2500HD
2500HD's Avatar
Here is mine.Name:  DSCN0651c.JPG
2500HD is offline   Reply With Quote
Old 12-20-2006, 11:15 PM   #90
68cajun
68 C/10
68cajun's Avatar
Here's mine.
(2009) GMC Sierra Denali 6.2 AWD
(67 C/10 fleetside SWB)
(2018GMC Yukon Denali) Wifes Car
68cajun is offline   Reply With Quote
Old 12-20-2006, 11:34 PM   #91
1LoC10
Insert Title Here
1LoC10's Avatar
I guess ill show mine, I didnt think it was that low, but it sits the same as others....so ill post
BOBBY
_69 SWB_
1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all <<
1LoC10 is offline   Reply With Quote
Old 12-20-2006, 11:47 PM   #92
camaro__thunder
Epoxy Primer Friendly
camaro__thunder's Avatar
Does mine count ?? 18" drop front and 20" in the rear. LAYS DOOR
It's the last pic since the sandblasting/take apart put back together phase ..
My Project 69 SWB
SHAVED BAGGED DOORED
camaro__thunder is offline   Reply With Quote
Old 12-21-2006, 12:05 AM   #93
abadsvt
abadsvt's Avatar
Damn Bagged70! Your truck looks sweet!
(Project truck)
1970 C10 under complete transformation
My current build thread http://67-72chevytrucks.com/vboard/s...d.php?t=212871
Other project: C5 corvette swap into 70 c10 http://67-72chevytrucks.com/vboard/s...=1#post2413517 On Hold
abadsvt is offline   Reply With Quote
Old 09-27-2007, 01:59 AM   #94
toomanytoyz
Luv the Crewcabs
toomanytoyz's Avatar
How About Some More ...............
Thanks, Rick
toomanytoyz is offline   Reply With Quote
Old 09-27-2007, 04:26 AM   #95
svgould
Active Member
svgould's Avatar
Ok here is mine.Front: 2.5 spindles/1 round of spring Rear bags/no c-notch
1971 SWB SOLD
  • LT1 motor / 4l60E transmission
  • ECE front dropped spindles with stock height springs
  • 4" rear springs
  • Coys Wheels 18 x 8 all the way around
  • Hydratech hydroboost brake system
svgould is offline   Reply With Quote
Old 09-27-2007, 05:22 AM   #96
smoky02
Location: Sunny, Florida, some might call it South Alabama
Hey pat, what color blue is your truck?
Just sold my C10...sad day...
Looking for a 1972 Blazer to hopefully fill the hole in my heart.
smoky02 is offline   Reply With Quote
Old 09-30-2007, 01:31 AM   #97
EAST SIDE LOW LIFE
EAST SIDE LOW LIFE's Avatar
This is my 70' GMC LWB.
esll.
Tomorrow is for doing today's stuff.
This truck has just the right amount of energy for me!
Author: Warren Lake .... (member)
EAST SIDE LOW LIFE is offline   Reply With Quote
Old 09-30-2007, 01:48 PM   #98
crzngmychvy
&quot;1972 C5&quot;
crzngmychvy's Avatar
Mine:
- 72 2wd Blazer ...sold...
2wd Blazer Page
crzngmychvy is offline   Reply With Quote
Old 09-30-2007, 02:40 PM   #99
Nobby
Nobby's Avatar
Here's a couple of mine.
Nobby is offline   Reply With Quote
Old 09-30-2007, 02:47 PM   #100
cstm68
cstm68's Avatar
how low can i go without z ing the front?
bags or no bags
68 swb fleet bagged on 20's 327 with 4 speed http://67-72chevytrucks.com/vboard/s...d.php?t=223308
2014 Chevy 2500hd duramax CCLB
cstm68 is offline   Reply With Quote
