Old 07-14-2007, 03:02 PM   #76
kevncar
Active Member
kevncar's Avatar
Re: Stagger wheel size or not? 18" & 20" or 20" all the way, What do you think?
Bigsky71, what are your tire specs?
Kevin
72 Chevelle
67 C10...454/TH400
Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=193961
kevncar is offline   Reply With Quote
Old 07-15-2007, 03:27 AM   #77
BigSky71
LAIDOUT
BigSky71's Avatar
Originally Posted by 72 Cheyenne402 View Post
Why do you regret the 18 & 20 stagger your truck looks awsome? I have heard 20" wheels age hard on front rotors??? I don't know one way or the other. I am having a hard time finding a matching set of tires. The only set I have found are the Toyo Proxes 4 in the sizes I need
Thanks 72Cheyenne. Now that the truck is assembled I think the front ones look small, but its all relative I guess, if it had 18s on the rear too, the fronts would not look so small... I am going to stick with the current 20/18 setup. Laid out the front tires already rest on the inners, so another 1.5-2" would just make that worse, plus the way it is now I could conceivably drive with less pressure in the front, at least when doing the fairgrounds crawl.
The tires are Toyo Proxes STs. 315/35/20 rear, 255/45/18 front. I wanted 245/45 for the front but those don't come in the ST line. On the tire calculator at 1010tires.com the fronts are supposed to have a sidewall height of 4.51", and the rears 4.34", so .17" of an inch, but as you can see in reality the difference is more than that. I am going to live with it. Its mid July and I want to drive this truck before that white stuff comes back again!
67 2wd Shorty
Build Pictures
BigSky71 is offline   Reply With Quote
Old 07-15-2007, 03:52 AM   #78
72 Cheyenne402
72 Cheyenne402's Avatar
These are the trucks that influenced my setup
I got to tell you choosing rims and tires is a hard thing. I hope I am happy with the setup I have when it is done. If I had your truck I would just drive and enjoy it. It looks Killer!!!
1972 Cheyenne 402 LWB
2005 Silverado X-Cab 5.3L
2004 John Deere L120 20HP B&S
72 Cheyenne402 is offline   Reply With Quote
Old 07-15-2007, 04:11 AM   #79
Raguemoe
Junior Member
Raguemoe's Avatar
Ok, now that I have my truck assembled I can say I wish I had gone with 20s all around instead of 20/18. I plan to call my tire guy and see about swapping out my unused 18s for some 20s, that is if the wait is not too long. Just got the bed on two nights ago...
I like your set-up! I had a 67 SWB that I was going to use that set-up on (maybe smaller front tires.) Lookin good!!!
Raguemoe is offline   Reply With Quote
Old 07-15-2007, 08:31 AM   #80
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
I tried to buy this truck a few weeks ago, it's a 18/20 set-up also
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 07-15-2007, 11:29 AM   #81
BigSky71
LAIDOUT
BigSky71's Avatar
I appreciate the compliments, and that is the plan now, finish and drive!
I get my bedliner in today, then wire tail lights, diagnose and fix sticky front brakes, then cruise .
67 2wd Shorty
Build Pictures
Old 07-15-2007, 08:48 PM   #82
72 Cheyenne402
Got my rotors back from the machine shop on Friday and now it looks like i'll be able to use myCenterline caps. looks like I am good to go.
Old 07-15-2007, 08:59 PM   #83
itsmike2k
Looks good dude.. You buy tires yet?
Mike
1972 LT1/4l60e Short Bed
ART Front and Rear Strong Arms
http://www.67-72chevytrucks.com/vboa...50#post2151750
itsmike2k is offline   Reply With Quote
Old 07-15-2007, 09:07 PM   #84
72 Cheyenne402
working on finding a tire dealer that can set me up with the right sizes for the right price. I am also replacing my pads and wheel bearing at the same time.
Old 07-15-2007, 09:20 PM   #85
SactoJim
SactoJim's Avatar
I'll say this.....that deep back rim looks fricken great with the tire all tucked in that wheel well.
You must of narrowed your rear a little and widened you bed wheel wells?
Truck looks great now and will look fantastic when all back together.
72 Cheyenne SWB Fleet
Nut & bolt frame off in progress...99.9999%
- supercharged 383
- 4 wheel discs
- relocated fuel tank
My Build Thread
SactoJim is offline   Reply With Quote
Old 07-16-2007, 12:04 AM   #86
BigSky71
LAIDOUT
BigSky71's Avatar
Yes, I copied Kxmotos baby blue 67 truck; 8" narrower than stock 9" F*rd rear-end, added 5.5 to wheel wells, 20x10s with 3" BS. Hope to be driving it this week, then on to installing the obnoxious stereo .
72Cheyenne - I am excited to see those wheels on, good luck on the tire hunt!
67 2wd Shorty
Build Pictures
Old 07-17-2007, 09:56 AM   #87
72 Cheyenne402
Originally Posted by itsmike2k View Post
They already have my money so i think i'm locked in... They sure do run that card fast when you order ... Did you get your center caps figured out? I wonder if i'll have the same problem... I'm gonna call them today and see if they know how much longer until they are done..
Mike,
Have your wheels came in yet?
Old 09-05-2007, 12:19 PM   #88
BigSky71
LAIDOUT
BigSky71's Avatar
Ok, resurrecting this thread because I have some driving time on my truck now.
I am running the stagger 20 rears/18 fronts. For the look I wished I had gone with 20s on the front, but now that I am driving the truck and have found what air pressures I like, I am glad that I have 18s. I say this because even with the 18s the tires are pretty close to the inner fenders at 82-85 psi, about 2.5" I'd say. If I was running 20s with this pressure I'd be near 1.5" before bottoming out. I have driven the truck with 90-95 psi in the front and its just too rough riding for my tastes.
Of course, this would not be an issue if you don't run the stock inner fenders. If anyone would like pictures of my truck at ride height, I will be happy to shoot the appropriate picts and post them...
67 2wd Shorty
Build Pictures
Old 09-05-2007, 01:06 PM   #89
action
Active Member
action's Avatar
I would love to see pics of ride height. I would love to run the 315 but would like a little more side wall. Your truck looks good.
Jack
68 Chevy Long utility bed.
Now swb/Bagged
Soon to be 468 (Maybe 496) BB/Turbo 400
action is offline   Reply With Quote
Old 09-05-2007, 01:32 PM   #90
HUEVUDO
HUEVUDO's Avatar
I went with 20 's all the way around. You want that stance. Buy some lowered coils and or drop spindles. I have that stance but when it comes to the tires I can rotate them. I have drop coils , 2.5 drop spindles with disc brakes and a front sway bar. It rides very nice. Here is a bad pic..
HUEVUDO is offline   Reply With Quote
Old 09-05-2007, 01:55 PM   #91
BigSky71
LAIDOUT
BigSky71's Avatar
Mines bagged with 2.5 drop spindles, no coils here. Couldn't rotate my tires even if they were all 20s, rears are much wider. I went for the muscle car type look rather than the dragging rockers look.
New picts coming.
67 2wd Shorty
Build Pictures
Old 09-05-2007, 08:39 PM   #92
72 Cheyenne402
Softtail, Yea 5.4 is a weird BS
Mike,
Did you get your wheels from CL?
Old 09-06-2007, 11:38 AM   #93
BigSky71
LAIDOUT
BigSky71's Avatar
New picts coming.
Ok here they are... All these are at ride height, 82/83 front 49/50 rear. I have found these settings the best for the ride quality I want. Fwiw, I am running the GR2 shocks from Early Classics, which may have some effect on the ride and what air pressures work best. I already had the GR2s so I did not buy the ART shocks.
Hard to judge depth in the closeup picture, but that is about 2.5" of clearance.
67 2wd Shorty
Build Pictures
Old 09-06-2007, 02:09 PM   #94
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Lots of great looking trucks guys!
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 09-06-2007, 06:49 PM   #95
1sik7t2
dave
1sik7t2's Avatar
i like both looks as long as their BIG i have 20's and 22's on the burb HOT ROD STYLE ROCKS but if you can pull off the same big wheels GO FOR IT
check out my build "DIRTY BURB"
1sik7t2 is offline   Reply With Quote
