Stagger wheel size or not? 18" & 20" or 20" all the way, What do you think?
Stagger wheel size or not? 18" & 20" or 20" all the way, What do you think? This is the only thing between me and a new set of wheels. Any Ideas or oppinions are welcome.
Here is a pic to help ![]() ![]()
1972 Cheyenne 402 LWB 2005 Silverado X-Cab 5.3L 2004 John Deere L120 20HP B&S Last edited by 72 Cheyenne402; 06-11-2007 at 10:46 PM. |
Re: Stagger wheel size or not? 18" & 20" or 20" all the way, What do you think?
I did the staggered sizes because I was going to drive everyday & didn't want to worry about potholes tearing up the front rims/tires. I would prefer the same diameter wheels all the way around but it's tough to get the right size needed up front & not be too big because you're limited by manufacturers sizes.
If you can get the wheels in the right widths, 255-40/20's on 8.5's & 295-40/20's on 10's work very well & the fronts should survive common road conditions.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 06-11-2007 at 11:06 PM. |
who makes the wheels you are going to use
either centerline or Boyd
1972 Cheyenne 402 LWB 2005 Silverado X-Cab 5.3L 2004 John Deere L120 20HP B&S |
#5 | |
Biggies and smalls all the way. Looks really good on these trucks. I am going to run 18 and 20's.
Questionable
i like staggered
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
#8 | |
My fronts drag the a-arms more than I care for & on the 73-up body style you can get away w/less BS & still keep the wheel 'tucked' fairly well. IMO 5.00" front BS would work better for my 74 but I already had the wheels from another project.
I have 18-8 w/4"bs front and 20 9.5 w/4.5bs on the rear on order. I have always liked the was 18's and 20's look...
Mike 1972 LT1/4l60e Short Bed ART Front and Rear Strong Arms http://www.67-72chevytrucks.com/vboa...50#post2151750 |
What rims and size tires are you going with?
1972 Cheyenne 402 LWB 2005 Silverado X-Cab 5.3L 2004 John Deere L120 20HP B&S Last edited by 72 Cheyenne402; 06-12-2007 at 03:42 PM. |
I ordered some centerlines about a month ago, new wheel and they are still building them.. Not for sure on the tire size but i'm thinking 275 40 20's and maybe a 255 45 18? Not real sure yet..
Mike 1972 LT1/4l60e Short Bed ART Front and Rear Strong Arms http://www.67-72chevytrucks.com/vboa...50#post2151750 Last edited by itsmike2k; 06-12-2007 at 04:36 PM. |
Has anyonE stuffed a 315 35 20 under the rear of a 67-72 w/o mods? I think my wheel will be too narrow but a 12.5" tire is great
#13 |
Wich ones did you order? I am thinking about ordering the Voltage series. I'm not crazy about the rear backspacing though and rim size 20x8.5 withe a 5.4 BS. They donot offer these rims in a 20x9.5 or 10 unfortunately
1972 Cheyenne 402 LWB 2005 Silverado X-Cab 5.3L 2004 John Deere L120 20HP B&S Last edited by 72 Cheyenne402; 06-12-2007 at 05:19 PM. |
#14 |
Softtail, Yea 5.4 is a weird BS
#15 |
The LuvShack Garage
I plan to run 18"/20" staggered, I test fitted 20's on all 4 corners, see
pic below, but aired out I did not like the looks of the front. And I plan to have mine drivable aired out, just in case of them oh chit situations. That's air'd out, 2.5" spindles, tall cups, on snubbers in rear, no c-notch
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Big Piggy: "Goliath" 07 Kodiak C4500 Lil Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
#16 |
Yea i agree, i like 18 and 20's.. Just have to decide on tires now...
#17 |
You would want 11 ~ 12" wheels for that tire. W/some mini-tubs & the right front wheel/tire to compliment, it would look nice.
#18 |
Anybody using 5.4 backspacing on a 20x8.5? if so what does it look like? and what size tires are you going with?
#19 |
OK, I have ordered my rims now the tire size is killing me. I went with the staggered look 18x8 & 20x8.5 now I am having trouble finding tire sizes that would work with this stagger. Any advise would be appreciated
1972 Cheyenne 402 LWB 2005 Silverado X-Cab 5.3L 2004 John Deere L120 20HP B&S Last edited by 72 Cheyenne402; 06-14-2007 at 11:00 AM. |
#20 | |
LAIDOUT
I was going to order the 295 wide but my tire guy thought we should try the 315 first. He was right. I thought I would need a wider than 10" wheel but it actually fits really well, the sidewall is vertical, not pulled back like I suspected it may be. This is a 20x10 with 3" BS. I am running 18x8 up front with 4.5 BS and 255/45s. Sorry no side picts yet, garage is too small for that! |
#21 |
Looks great.. I might check and see if 295's will fit with my setup.. I could always run shorter axels i guess and do some small tubs.Just have to wait and see, still need a bed to do all the fitting
#22 | |
![]() Join Date: Aug 2005
#23 | |
Go to Tirerack.com & select tires. Enter the rear tire size & it will give you several choices. The best options would be based on sidewall/overall height. Once you select a tire, click the 'specs' for a listing of other sizes in the same tire. I would try Eagles RS-A in a 235-50/18 (F) & 255-50?20 (R).
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 06-14-2007 at 01:23 PM. |
#24 | |
#25 |
The LuvShack Garage
For tires I use the BFG site, I pic out a Tuner tire, sorry, and it gives
me sizes and spec's on everything they carry in a chart. You can get overall diameter measurements, section width, RPM's, etc .............
