02-21-2010, 12:18 AM | #76 |
Member of the longbed union.
Re: Look what I found
good to see you working on it Alan, throw some bags on it and get it running good, and drive it like you stole it. And dont worry about the wood missing.
Paul 88 GMC Crew Cab dually, 454/T400 64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it! 92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759 |
02-21-2010, 01:42 AM | #77 | |||
1 thing at a time is progress.
I rebuilt the carb a while back. The fuel lines had a lot of rust in them. I wanted to redo the entire system to prevent problems. We had to drag it in. Quote:
Can't afford much on this project. My priority is just get it driving.
Alan
Philippians 2:14-16 |
02-27-2010, 09:02 PM | #78 |
Progress
Got time to work on the fuel system. Here are the new fuel lines. The main line from pump to the tank fit great. But the second line wasn't long enough to go to the tank. It looks like I might be missing something or ordered the wrong line set. I ordered PN 55-084201 from the Truck shop. Removed seat What are people charging to redo their seats? I know it's a vague question. Just an idea. Removed sending unit. I couldn't blow air thru it even 90 psi gave just a little hiss. I thought I knew how to use a meter to check to see if it reads anything, but couldn't get any continuity anywhere. The filter is brittle. I guess it's time for a new sending unit.
Alan
02-28-2010, 10:30 AM | #79 |
Got the lines finished up and tank installed. Gonna order a new sending unit.
Alan
02-28-2010, 11:44 AM | #80 |
We've had 3 seats done by the same guy in the last couple years, and he charged 300 buck apiece for them in two tone vinyl.
'57 Chevy Pickup '56 GMC LCF Cummins '38 Chrysler Royal '57 2wd change http://67-72chevytrucks.com/vboard/s...light=speedway |
02-28-2010, 02:36 PM | #81 |
Any suggestions for a new name for the thread?
Alan
02-28-2010, 04:54 PM | #82 |
In the Seattle area the going rate is 85$/hour and most stuff is easily factored by the hour.
"I feel the need for speed!"... as soon as I am done with my nap. |
02-28-2010, 05:04 PM | #83 |
SSN 706
No ideas. I get all my ideas from you.
03-15-2010, 11:44 PM | #84 | |
Got the new sending unit installed tonight.
Alan
03-16-2010, 12:05 AM | #85 |
SSN 706
Thats going to be the next thing I buy. Mine has never worked very good. In fact I'm going to get it now. Should have done that awhile ago.
Daverods 64 C10 Daily driver 292 3 speed "Driver" Daverods 66 Build C10 Bags 350/350(On Hold) Daverods 52 Build 3100 S10 chassis,Bags, 350/700r4 "Click it" Last edited by daverod; 03-16-2010 at 12:13 AM. |
03-17-2010, 11:46 PM | #86 |
Worked a little more. I used my vacumm pump to pull the fuel from the tank to the carb.
It not only did that, but it also flushed some junk out of the lines. Tried to start it, but no luck. The fitting at the carb is dry even after cranking several times. When I got the truck it had an electric fuel pump on it. I'm sure it was there because the mechanical pump was shot. Just hope I can find the correct fuel pump so I don't have to rework my lines. I searched online at Advance auto, O'Rileys and the truck shop. The pics they had didn't look like the one on the truck. Maybe they were generic pics. If I remember right this is a 235 engine.
Alan
03-18-2010, 08:16 AM | #87 |
Under Construction
nice progress....
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
03-18-2010, 09:24 AM | #88 |
SSN 706
That's funny my vacuum pump looks a lot different.
Daverods 64 C10 Daily driver 292 3 speed "Driver" Daverods 66 Build C10 Bags 350/350(On Hold) Daverods 52 Build 3100 S10 chassis,Bags, 350/700r4 "Click it" Last edited by daverod; 03-18-2010 at 09:26 AM. |
03-18-2010, 10:47 AM | #89 | |
The Few, The Proud
Remember the process for building these things.....1 step forward, 2 steps back. J/K I hope it works out where you don't have to rebend new lines.
Shannon |
03-18-2010, 04:43 PM | #90 |
I'M TRUCK CRAZY!
I'm subscribed. It's going to feel good when you get to drive it. For you anyway.
03-18-2010, 09:35 PM | #91 |
Alan if you cant find the correct one, Could you get away with getting a block off plate and building a bracket to mount the eletric pump. Hopefully you wouldn't have to rebend anything.
03-23-2010, 11:49 PM | #92 | |||
Tried to fire it but no spark. With some basic checks we determined to replace the plugs, coil, points/condensor and rewire some things. I had already replaced the cap and rotor. I had 12v to the coil. Hopefully this will get it running. You can see the coil in this pic and it looks to be as old as the truck.
Alan
03-25-2010, 12:02 AM | #93 |
It Runs!! Replaced the points, condensor, coil and plugs. Also replaced this wire from the coil to the distributor. Tried to figure out how to set the timing. Never done one like this before. It says set the octane selector to zero. How do you know it is at zero? I'm guessing it is the knob above the timing scale. Where is the hole in the flywheel housingand the steel ball?
Alan
03-25-2010, 12:10 AM | #94 |
Registered Chevy Owner
Glad to hear that she's runnin'. How does she run?
Love is fleeting, but Chevy trucks are forever!!!! 1970 Chevy CST C10 long box 350/400 2008 Chevy Silverado short box 4x4 Had; 1951 Chevy short box 307/T5 1988 Chevy shot box 4x4 350/350 1971 Chevy C10 long box 4x4 350/350 1971 Chevy C20 long box 350/350 1971 Chevy C10 long box 350/350 |
03-25-2010, 10:56 PM | #95 |
I put a thread up trying to figure out how to set the timing. Here is the LINKY
She runs fair. Hard to start and stumbles when I gas it a little. Have not drove it yet. Still have to put the seat in and a few other things.
Alan
03-25-2010, 11:41 PM | #96 |
who needs a seat when you can get a egg crate
glad that it runs
03-30-2010, 11:42 PM | #97 | |
Here she is running. And here is the stumble off idle. Here is a good link to some help I got on timing it.
Alan
03-31-2010, 01:32 AM | #98 |
Resistance is Futile
That stumble, if I heard it correctly sounds like the accelerator pump..can you adjust it to shoot in a little earlier when you step on it?
I've never seen this thread before; no wonder the '65 isn't done!! At least I'm not the only one jumping back and forth.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
03-31-2010, 08:17 AM | #99 |
Rottenwood Garage Member..Yes!
I had a similar problem with mine.. if the choke lever is pulled out a little bit it would help... I ended having to adjust the mixture screw on the side of the carb. Don't know if its the same problem, I thought that it was timing.. but after a little trial and error it runs great... Good luck
Can't wait to see it running down the road..
When interests become diversified, not all can be Barrett Jackson. Budgets and Accountants get in the way. My 65 (SOLD) http://67-72chevytrucks.com/vboard/s...d.php?t=317013 My 51 (SOLD) http://67-72chevytrucks.com/vboard/s...80#post3551880 Racetruck III (SOLD) http://67-72chevytrucks.com/vboard/s...72#post4254972 Rottenwood Garage and Speed Shop.....where everything must be racy! Gone to dark side for a while...1966 F100 in the stable |
03-31-2010, 11:57 PM | #100 |
SSN 706
That sounded just like my 64 before a bought a rebuild kit and changed out the accelerator pump rubber seal. They like to dry out when nobody drives them for awhile. When you going to drive that thing to work?
