#76 |
Re: New guy with truck
Welcome; Nice truck. Were in sw Washington are you ? I know you probably want to do the welding yourself but there is a guy in washougal wa that is really good and really fare priced. His shop is called Mad Max Creations.[ Just a thought ] I'm Doing a 56 Big window also With a 350 motor and 350 trans. Good luck.
#77 | |
Thanks for the suggestion but I am almost don with my welding I got allot of welding in with this project.
1996 Dodge 3500 4x4 1977 F250 Camper specal 4x4 1956 Chevy 3100 truck |
#78 |
I have a question, I had my Buick roadmaster drive shaft cut and rebalance and I just installed it today, when the shaft is in the tranny how far back can it go, is there a set spot, if I put the shaft all the way in the tranny it gos back 1 and a half inches to the u joint. Is that to far back???
#79 |
You should have about 4" minimum total travel before it falls off the trans output shaft, so 1" or so sounds about right unless you have a lot of rearend travel that will push it in more.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project Last edited by OrrieG; 06-13-2010 at 11:27 PM. |
#80 |
Looking good 56.
#81 |
OK thanks OrrieG, I just wasn't sure..
#82 |
Hey thanks 52, I got my gas tank in to its off a 1996 z28
#83 |
#84 |
52 yes it did thanks for your help,I cut a hole in the frame and then reinforced it. I all so made some straps and got it all in there the only thing with the sending unit I had to make a ring for the hold down. The Buick was bigger with 6 holes and the camaro had 5 holes.
#85 |
well got my drive shaft cut and balance and new u joints cost me $340
#86 |
Also toke my cab in to get sand blasted its costing me $260 just for that no primer they what $600 for sand and primer?? So i need to get home and start to primer right away!!! is that a good price should i have them primer??
#87 |
got my cab home...from sandblast
#88 |
cab looks good. Were did you have it done I'm looking for a sand blaster
#89 |
![]() Join Date: Mar 2009
You've come a long way with the truck, cab looks great! I'm a little concerned about your rear suspension though, do you plan to add some extra bracing on those control arm mounts? Not trying to knock your work, just want it to be safe.
1962 Chevy blue SBFS 1957 Chevy yellow SBSS 1956 GMC red SBSS Nov 2017 ToTM https://www.facebook.com/groups/Cana...geChevyTrucks/ |
#90 |
Your progressing along very nicely. You can get a gallon on Shop Line brand Epoxy Primer and catalyst for around $105. Its a PPG product that is similiar to DP 90/50. It comes in gray,black and I think maybe white, not sure on the white. Shop Line is more of a cheaper line. I have used it allot and it works pretty good. Use a good carbon filter paint mask. These primers/paint can really mess you up, w/isocyanates, so use all possible safety precautions. I buy my materials from APS, Automotive Paint Specialties, they have one in Portland.
I also think you should have someone with some fabricating skills look at your trailing arm mounts. The vertical strength may be adequate, but I'm not sure on the horizontal strength. Like Bob said, not trying to dog your work, just make sure you and your loved ones riding in this are safe. Keep up the good work, and continue to learn. Scott |
#91 |
Thanks robgrin I had it don at WHELLERS in Longview, WA.
1996 Dodge 3500 4x4 1977 F250 Camper specal 4x4 1956 Chevy 3100 truck Last edited by 56ClassicTruck; 01-24-2011 at 03:14 PM. |
#92 |
Thanks for your concern bobinbc, ya me too I am having a local car builder come over and look it over for me....
1996 Dodge 3500 4x4 1977 F250 Camper specal 4x4 1956 Chevy 3100 truck Last edited by 56ClassicTruck; 07-07-2010 at 12:44 PM. |
#93 | |
#94 |
Aren't we all a little crazy to be doing this????
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
#95 |
LOL!! Sorry I didn't any one new Spanish..LOL!
#96 |
How is your build going?
#97 |
Coming along finishing all my patch panels so welding and grinding.
#98 |
Need some help with the location of the tips of the frame?????? How far forward under the lower grill bar if at all? Does the grill bar ride on the frame? is the radiator core support the only thing holding up the front clip???
#99 |
Well after running in to some issues with my camaro sub, like my front end not being low like I wanted it. I installed it straight on to my frame looks nice but to high. And clearance issues with ac pump. I decided to start over with frame and sub. First I bout a new straight 56 frame for $ 20.00 and I am going with the 1994 buick roadmaster sub, lt1 will be at home........for hight I am ofsetting sub to frame by 3" that should give me the look I want....... Pics soon......
#100 |
![]() 1953 BBC 3100 427 T-400 12 Bolt ![]() ![]() Al |
