07-27-2010, 09:26 AM | #76 |
Re: C10Slim's 66 Build Thread
that's lookin nice. i've got several cans of easy off for when we do the frame on our truck
07-28-2010, 01:43 AM | #77 |
Redneck Hillbilly
Hey Slim, looking at the photos of your header instal, it almost looks to me like a header designed to fit a '68-'72 GM A-body (Chevelle, Cutlass, GTO, etc) would work good in there. Might this have been a design you tried in your previous attempts, or was it just different manufacturers of parts specifically for the '60-'66 pickups?
07-28-2010, 11:16 AM | #78 | |
1967-74 Camaro 1968-74 Chevelle 1968-72 Chevy II, Nova 1968-74 El Camino 1965-70 Passenger Car, Wagon 1965-66 Chevy C10 (don't ask me why 65-66??) The biggest issue was finding a header that would clear the CPP perches. The #1 tube dipped to low and would hit the driver side perch. First, I tried a set of Patriot ''Clippster'' Style headers, no where near right. Then I tried a set Hedman headers that were very close, but would not quite clear perches. I could probably have massaged them a bit or shaved the perch to fit. Then I saw these in the CCT mag article, had tons of room around the perch and were more of a long tube design (the others were shorty). |
07-29-2010, 03:55 AM | #79 |
Redneck Hillbilly
Good to know, thank you.
08-01-2010, 10:04 PM | #80 |
Getting closer to start... The brakes are completely juiced and ready to go now. Gas pedal is installed and hooked up. Radiator and trans cooler mounted. Started running the trans lines but need a few more clamps to finish it up.
08-05-2010, 10:33 PM | #81 |
Cooling system is done! All trans and rad lines plumbed, fan and shroud mounted, ready to go!
08-16-2010, 08:40 PM | #82 |
Steering column, steering wheel and gauges ready to go. Going to wire the truck up this weekend I hope.
08-16-2010, 09:05 PM | #83 |
Got any more pics? that is looking great Slim. What are the details on the Rad and shroud you are using?
08-16-2010, 09:15 PM | #84 |
Thanks. More pics to come. Radiator is a dual core 1" tubes off of ebay, the fan is a Zirgo 3000cfm and the shroud was made by us radiator.
08-16-2010, 09:24 PM | #85 |
Thanks for the info, it sure looks like it all fits really good. Nice and clean.
08-16-2010, 10:36 PM | #86 |
Do those alum gauge panels simply swap in place of the OE clear lens? Do they have all the standard OE 'locating' holes for the outer cluster housing?
08-16-2010, 10:44 PM | #87 |
Yep:
08-16-2010, 11:18 PM | #88 |
What manufacturers panel is that?
08-17-2010, 01:26 AM | #89 |
08-22-2010, 08:12 PM | #90 |
This week end I got the new custom 1 piece driveshaft is in, Front clip back on, and started the wiring and dynamat. Big thanks to my bud Brian for crawling in to the engine bay and doing most of the work in there.
08-22-2010, 08:14 PM | #91 |
more pics...
08-22-2010, 08:17 PM | #92 |
Few more
08-27-2010, 02:14 PM | #93 |
I LOVE this build, man.
08-27-2010, 04:30 PM | #94 |
Looking good!!
09-05-2010, 03:17 PM | #95 |
09-06-2010, 12:57 AM | #96 |
60-66 Nut
That sounds good
09-07-2010, 10:35 PM | #97 |
Rollin' Old Skool
sounds great!
09-08-2010, 09:48 AM | #98 |
Truck is looking great-
09-08-2010, 12:55 PM | #99 |
Old and crusty
Sounds very gnarly!! Your build is coming along very nicely.
09-16-2010, 12:31 AM | #100 |
Could you give me some info on your steering column and wheel. Part numbers/IDIDIT??/dealer/ is it a retro fix column? Was looking at the IDIDIT colums from summit and wanted to see if there others out there that may be cheaper is all. Thanks for any info you might have for me.
66 short wide fleet sbw = Gave to my best friend 66 short wide fleet bbw |
