06-30-2011, 07:08 PM | #76 |
Re: 57 Step Side
06-30-2011, 07:12 PM | #77 |
Certified Car Nut
Re: 57 Step Side
07-04-2011, 06:59 PM | #78 |
Re: 57 Step Side
Fan belt finally back on again,weld up the exhaust this week and i'll be down to water and wire.
07-05-2011, 12:44 AM | #79 |
56 - autocross
Re: 57 Step Side
Nice!
07-09-2011, 05:11 PM | #80 |
Re: 57 Step Side
exhaust system done,built on a creeper what a pain in the *ss.It looks so much easier on tv when they have the truck on the lift and pipe stands holding up the whole system as they put tack welds on.
07-09-2011, 07:07 PM | #81 |
A320 Pilot/USAF Retired
Re: 57 Step Side
Nice work! What mufflers are you running?
JJ My 1957 build: http://67-72chevytrucks.com/vboard/s...d.php?t=334552 http://www.trifive.com/forums/showthread.php?t=22037 Instagram - Chuckdriver57 |
07-10-2011, 01:00 AM | #82 |
Re: 57 Step Side
Looks real nice.
Kim |
07-10-2011, 08:03 AM | #83 |
Re: 57 Step Side
Magnaflow ,when i opened the box and saw that they were straight open mufflers i said well its going to be loud but i hope not to loud.Brought the rounds so i had more room when mounting them,but i think i have enough pipe on the end of them to kill some of the sound.
07-10-2011, 09:45 AM | #84 |
Re: 57 Step Side
Thanks! We'll be waiting for a sound clip ASAP!
07-11-2011, 08:13 PM | #85 |
Re: 57 Step Side
Cross over pipe work out well and e-brake hooked up.
07-12-2011, 12:34 AM | #86 |
Re: 57 Step Side
That stuff looks real sharp.
Kim |
07-16-2011, 03:47 PM | #87 |
Re: 57 Step Side
Got my steering column back from ididit had them cut 3" off,now i have enough room between the headers and steering shaft.Just wondering if the heat from the header to the shaft will keep my steering wheel warm in the winter!!!!
Trans cable is hooked up and the column shifter actually works. |
07-16-2011, 04:21 PM | #88 |
56 - autocross
Re: 57 Step Side
nice!
07-17-2011, 12:22 AM | #89 |
Re: 57 Step Side
Looks good.
Kim |
07-21-2011, 07:41 PM | #90 |
Re: 57 Step Side
carburetor is on with linkage hooked up and tv cable.
07-22-2011, 12:20 AM | #91 |
Re: 57 Step Side
That sure looks nice.
Kim |
07-22-2011, 07:56 AM | #92 |
Re: 57 Step Side
07-22-2011, 01:22 PM | #93 |
Re: 57 Step Side
You are moving too fast, stretch it out a bunch of years like me to keep yourself occupied.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
07-31-2011, 07:06 PM | #94 |
Re: 57 Step Side
Radiator came in this week so we started to mount it up busy weekend so only had a few hours to play with it.Going to mount the condenser on the outside of the radiator,need all the room on the engine side for a electric fan.
07-31-2011, 07:43 PM | #95 |
Re: 57 Step Side
Pretty.
07-31-2011, 07:53 PM | #96 |
Re: 57 Step Side
Looks very nice.
Kim |
08-01-2011, 01:17 AM | #97 |
Re: 57 Step Side
Wow, You don't mess around. This thing is looking good.
I have a couple of questions. What headers did you end up using? And could I get more information on your E-Brake setup. Looks like Lokar stuff but I just wanted to get some specifics. Thanks, and again fine work your doing
-Aaron '15.5 Chevy Duramax LTZ/Z71, LML, CC/SB '77 Chevy K10, 4" lift, 33-12.50, 350/350 '55 Chevy Short Box (In Pieces)MII,4-link,Bagged,383 Stroker,700r4,3.73posi (SOLD) My 55.2 Chevy 3100 Build Last edited by Flames97; 08-01-2011 at 01:18 AM. Reason: added |
08-01-2011, 01:30 PM | #98 | |
Re: 57 Step Side
08-01-2011, 02:16 PM | #99 |
Certified Car Nut
Re: 57 Step Side
Everything is looking great man, keep up the good work.
08-01-2011, 07:30 PM | #100 |
Re: 57 Step Side
Thanks Kabwe, i was going to tell you yours look good primed and its time to hit the sanding block.I think everyone wants to see that body with some color on it,did you chose one yet?????
Condenser on so the hot box should be cool when it gets hooked up. |
