#76 |
Re: 68 Four door build
You should come by some time to check it out Im in scripps ranch by Poway.
#77 |
![]() Join Date: Nov 2007
Im in for the ride... I cant wait to see the progress
72 C20 Longbed 05 1500 Z71 |
#78 |
Here a few night time picture of the front end,rear end,and splitter on the suburban, if any one can tell what they are let me know please. thanks
T |
#79 |
I don't want to start a hi-jacked discussion on if its better to use 2 truck cabs or a suburban , so maybe someone can start a link before all the good subs are gone.
Having said that if you look at the crew that 'Young Frankenstein' is modeled after, the space between the doors show that they must have used 2 cabs. http://67-72chevytrucks.com/vboard/s...d.php?t=426382 I myself bought a suburban (I had 2 cabs already) for a crew build because I like the look. Someone on this forum said how much more practical a sub is and I decided , having owned a '88 & a '99 suburban and own a '05 crew now, that they were right. Maybe this build is extra hard for me since I tried to get the seller to contact me for at least 6 mos.. |
#80 |
![]() Join Date: Sep 2009
Looks like the front is a Dana 44, I beleive the 68 3/4 ton still used the closed knuckle version. The transfer case looks to be Rockwell divorced unit which I think was still used in 68. The rear appears to be an Eaton. If your not using the 68 frame I would be interested in the front 4 spring hangers that are rivited to the frame. I want to convert my 70 Longhorn to 4x4 but will need to try to find out if the spring hangers are the same from 68 to 70. I'm not sure but I think the 68 3/4 ton used different front springs than a 70 possibly requiring different hangers.
#81 | |
6>8 Plugless........
![]() Join Date: Sep 2007
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
#82 |
Haminator got that all right off the bat. On the hangers, I'm not sure if they're the same, but I'm sure you can use them on your 2wd swap anyhow.
#83 |
On the hangers I just want to be able to use stock spring which I allready have. Which frame is being used for the four door? I think I missed that part.
#84 | ||
Posted via Mobile Device |
#85 |
I have done a long horn 4x4 swap before. It turned out nice and was very easy using the original long horn frame and 4x4 parts under it.
#86 |
Does any one need a 67-72 front motor cross member out of a 4x4? I have one if so.
#87 |
Re: 68 Four door build (burban is coming apart)
I had a few hours to start pulling it apart today.
#88 |
Does any one want that roof rack for free? very well built.
#89 |
VA72C10
![]() Join Date: Mar 2008
Nice progress! Didn't see where you mentioned which front end you'll be doing? Will it be a 68 (the one pictured) or something else?
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#90 | |
this is the plan |
#91 |
Spid
#92 |
#93 |
I have a 71 3/4 ton front end that is currently in my 70 short bed that I will be using as well as a transfer case etc. Did you move the engine back or leave it the 2 wheel drive location? I think the main things I need are that cross member and spring hangers. If you can't get rid of that frame I'd like to buy the hangers. Also how'd you deal with the rear drive shaft? did you stay with the 2 peice? Your rendition of the 4 door is sharp, I like the choice of colors. Iv'e though of doing that for over 20 years but adding step side fenders to the fleetside and running a wide dually rear and 1 ton stuff up front of course.
#94 |
Great progress and sweet rendering!
#95 |
#96 |
Love that color choice!
1972 factory 2 Wheel Drive Blazer-Sold 1972 K10 4X4-Sold 1971 Chevrolet Cheyenne/10-Sold 1970 Chevrolet C/10-Sold 1968 GMC 4X4-Project 1968 Chevrolet C/10 Pro Street 1970 GMC 3/4 Ton-Parts 1997 2WD 2DR Yukon-Sweet http://67-72chevytrucks.com/vboard/s...d.php?t=335664 |
#97 |
#98 |
Wow, what an awesome project. Good Luck.
72 Cheyenne shorty "CheyLow" 72 3/4 long 4X4 69 SWB "Prospector" 68 C/10 shorty - "Picacho" http://67-72chevytrucks.com/vboard/s...d.php?t=428379 sold to "93redsled" ![]() ![]() |
#99 |
Wow!
Best Regards, Leon M. Instagram: @TheDirtyDianah
Bagged | 6.0L LS | T-56 (6-Speed Manual) | Turbo Burnout/Rolling Video: Chevy C10 Stepside 6.0L LSx & 6-Speed Manual |
#100 |
I was gonna build a '67 GMC shorty a while back and go that color(ish) with a grey interior, what's your vision for inside?
